| Front Spindle Re-enforcement | |
biscuit Member
Age : 57 Join date : 2010-11-29 Points : 5163 Posts : 41 Location : Lincoln, RI
| Subject: Front Spindle Re-enforcement December 3rd 2010, 6:44 pm | |
| i have a 85-91 craftsman 11hp tractor. i am putting on truck wheels on it. was wonderin if the stock spindles will hold up. was wondering if i should weld a short piece of rebar on them. anyone have a problem with this? | |
| | | rex4x4 Member
Join date : 2011-09-16 Points : 4896 Posts : 57 Location : north bay , ontario , canada
| Subject: Re: Front Spindle Re-enforcement September 18th 2011, 6:25 pm | |
| I never even saw this actually..... id say definitely reinforce or build new spindles with tires that big.
On my mod machines im building my own reinforced spindles out of 3/4" steel bolts . Nothing like flying along and have a spindle break on you.
Another good suggestion would be to use bearings in the front wheels- stock steel or plastic bushings would either wear out or cut grooves into spindles ( i have a few that had- and theyre stock). | |
| | | biscuit Member
| Subject: Re: Front Spindle Re-enforcement September 19th 2011, 7:56 am | |
| Well its been a while since I have been here, but I welded the s10 wheels to the stock wheels. I have been using the heavier bushings but I welded bolts to the end of the spindles. got it up to a little over 35. Steering is loose, but it works. prolly won't go that fast again on that rig. but its climbs pretty good. I am doin up a murrat for the ice. | |
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
