| 1974 rover colt 5, one for australia :) | |
+8richie thomas TheRainbowBoxer willis923 Thunderdivine Lawren Wimberly 1997 Murray Doc Sprocket mrkadage 12 posters |
1997 Murray Veteran Member
| Subject: 1974 rover colt 5, one for australia :) February 4th 2014, 1:22 pm | |
| yeah, I guess you are right. I just hate it when you have to stop and go get different wrenches cause it is 12 mm not 1/2 or 7/16 | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4948 Posts : 919 Location : Defiance, Ohio
Age : 57 Join date : 2013-12-21 Points : 4802 Posts : 744 Location : Salem Illinois
| Subject: Re: 1974 rover colt 5, one for australia :) February 4th 2014, 4:44 pm | |
| It's rare to find standard and metric used for the same piece of equipment... I keep a metric toolbox and a standard toolbox... depending on the tractor or other item I'm working on, I grab the appropriate tool box. Yes it's annoying, particularly if you don't have a complete set. Personally, I recommend having 2 of every size... sometimes you need to hold the back of the bolt to tighten or loosen. A good quality adjustable wrench can help in the case of missing tools... One of my favorite things to do to noobs in the shop was to tell them to find me the METRIC adjustable... (I actually HAVE an adjustable wrench with metric markings on the jaws LOL | |
mrkadage Member
Age : 35 Join date : 2014-01-12 Points : 4075 Posts : 103 Location : queensland, Australia
| Subject: Re: 1974 rover colt 5, one for australia :) February 4th 2014, 5:29 pm | |
| I only started learning the imperial system when I started this build. its a pian in the arse to use but is sure as hell more accurate than metric lol | |
| Subject: Re: 1974 rover colt 5, one for australia :) February 4th 2014, 5:36 pm | |
| Imperial measurements are basicaly based on 1/2 's... No mater what the bottom of the fraction, if ya need smaller, measurements, double the bottom number and work from there. This gives a much easier manner of measurement when you get differences that are smaller than a millimeter, yet larger than a micrometer. It's simply the diff between analog and digital lol
Thunderdivine Veteran Member
| Subject: Re: 1974 rover colt 5, one for australia :) February 4th 2014, 5:43 pm | |
| - Lawren Wimberly wrote:
- Imperial measurements are basicaly based on 1/2 's... No mater what the bottom of the fraction, if ya need smaller, measurements, double the bottom number and work from there. This gives a much easier manner of measurement when you get differences that are smaller than a millimeter, yet larger than a micrometer. It's simply the diff between analog and digital lol
Nah then we whip out tenth of one millimeter, Like bearing press fit tollerance, whats that in inches? lol Micrometer is a tool http://en.wikipedia.org/wiki/MicrometerEarlier i had a caliper with both mm and inches on, that was schwwwweeet. | |
mrkadage Member
| Subject: Re: 1974 rover colt 5, one for australia :) February 4th 2014, 5:52 pm | |
Earlier i had a caliper with both mm and inches on, that was schwwwweeet. thus tolerances for metric are well and truly too much. like .5mm+- its still alot of space. and thunder, a micrometer is also a mesurement lol. it's .001 of a mm i do the same thing as you to lawren. I have a metric and imperial set of tools. not enough to make up another tool box though | |
| Subject: Re: 1974 rover colt 5, one for australia :) February 4th 2014, 5:57 pm | |
Earlier i had a caliper with both mm and inches on, that was schwwwweeet. thus tolerances for metric are well and truly too much. like .5mm+- its still alot of space. and thunder, a micrometer is also a mesurement lol. it's .001 of a mm :)i do the same thing as you to lawren. I have a metric and imperial set of tools. not enough to make up another tool box though I don't follow you with the .5mm+- thats alot yes. what have those tolerances? and .001 of a mm is only used in maybe watches and fine machinery. Not sure what a strand of hair is, and to lazy to google yeah i got my first imperial set when i got the JD 110. | |
mrkadage Member
| Subject: Re: 1974 rover colt 5, one for australia :) February 4th 2014, 7:09 pm | |
yeah i got my first imperial set when i got the JD 110. ok, the .5mm means half of a millimeter and the +- means tolerance, so give or take .5 of a millimeter. and the .001 can be used in cylinder boreing and carby jetting and other small stuff like that | |
mrkadage Member
| Subject: Re: 1974 rover colt 5, one for australia :) February 6th 2014, 8:32 pm | |
| so I'm working on my pedal assy today got the throttle and brake pedal mounted, just gotta finish the clutch assy and put spings on everything... YAY | |
mrkadage Member
| Subject: Re: 1974 rover colt 5, one for australia :) February 13th 2014, 9:50 am | |
| Not a great deal to update as of yet. But I now have a gas tank and.... That's about it. I do however have a start on a mini atv project watch this space. | |
the craftsman mudder New Member
Age : 26 Join date : 2014-01-13 Points : 3984 Posts : 20 Location : North Carolina
mrkadage Member
| Subject: Re: 1974 rover colt 5, one for australia :) February 25th 2014, 8:58 am | |
| - mrkadage wrote:
- sorry its been a while guys, I've been busy as hell lately lol. this weekend i will have a new video up
I understand lol! Can't wait for the new vid! | |
mrkadage Member
mrkadage Member
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5698 Posts : 1091 Location : Galion, OH
mrkadage Member
mrkadage Member
| Subject: Re: 1974 rover colt 5, one for australia :) March 13th 2014, 3:15 am | |
| hehe thanks wait till my next video, I've been really busy... just gotta find a motor though. It's like trying to find a needle in a haystack lol | |
| Subject: Re: 1974 rover colt 5, one for australia :) March 13th 2014, 12:04 pm | |
| Ya know how to do that don't ya? BURN DOWN the haystack... sift through the ashes... Tole ya fire fixes everything... I'm a blacksmith... I should know. | |
