 18hp Opposed twin cooling and flywheel q
Craftsman1998
Krawler86
7 posters
Krawler86
Krawler86
18hp Opposed twin cooling and flywheel q Empty
PostSubject: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 8:48 am
On this Craftsman II GT 18hp Briggs, the way im orienting it, i need it to be skinnier on the inlet fan side. Stock, the fan faced the center console and had a pulley in front of it. So airflow was limited, which is why im guessing the extra fan was added. The fan itself is also kinda heavy, not iron heavy, but its a little weight.
Stock, without the drive pulley.
18hp Opposed twin cooling and flywheel q Img_3043
Im wondering if i can run it like this with no ill effects. Il make a mesh guard that mounts either to the frame or to the shroud to protect that inlet, but it will be on the left side of the tractor with ample airflow, il also put a grill on that side of the sheetmetal for cooling intake as well. Do you think it would be ok to run like this? It would make my life much easier if i could.
18hp Opposed twin cooling and flywheel q Img_3044
Craftsman1998
Craftsman1998
PostSubject: Re: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 9:32 am
If it was my mower i would just run it the way it is. if it makes it easier. im sure its not the best thing to do but i would do it.
PostSubject: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 10:42 am
go ahead and leave it off, my opposed twin just has the fan in the last picture.
T-Dub13
T-Dub13
PostSubject: Re: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 12:20 pm
I can't see any reason why it wouldn't work. Should work better than stock too because you're feeding it fresh, cool air now.  Smile
MowBandit
MowBandit
PostSubject: Re: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 2:52 pm
I normally wouldnt recommend it but the way you got your engine setup go for it i see no harm if anything i see it being able to pull more air in
PostSubject: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 2:54 pm
jay_rod is the expert on opposed twins..... he has a thread on here somewhere
PostSubject: Re: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 6:22 pm
It will be fine, as pictured.
matt-man
matt-man
PostSubject: Re: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 6th 2014, 8:24 pm
Ive ran engines like that for a few years and they still run just fine so I wouldn't worry about it
Krawler86
Krawler86
PostSubject: Re: 18hp Opposed twin cooling and flywheel q   18hp Opposed twin cooling and flywheel q Icon_minitimeJanuary 7th 2014, 1:07 am
Awesome, exactly what i wanted to hear, thanks guys. Saves me from new hood mounts or deformed sheetmetal on that side. That fan just sticks out too far. Now it can be almost flush with the sheetmetal on that side.
» Briggs Opposed twin Starter and Flywheel issues
» 18HP briggs opposed twin
» 18.5 hp opposed twin
» 18hp briggs twin cylinder opposed power problems. PLEASE HELP!!!
» 18hp opposed twin model 422707, older model
