| | 18HP briggs opposed twin | |
greener179 Member
![greener179](https://2img.net/h/i1169.photobucket.com/albums/r507/mudmower16/profile_zps224b9c20.jpg)
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | Subject: 18HP briggs opposed twin February 28th 2013, 8:10 pm | |
| i just bought this opposed twin and it has compression spark and is getting fuel, but wont start any idea what it could be? | |
| ![Go down](https://2img.net/i/empty.gif) | | Chopperhed Moderator
![Chopperhed](https://2img.net/u/2812/37/66/46/avatars/469-45.jpg)
Age : 58 Join date : 2012-10-14 Points : 5180 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | greener179 Member
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Chopperhed Moderator
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | Subject: Re: 18HP briggs opposed twin March 1st 2013, 3:49 pm | |
| Try a 1/2 teaspoon down the carb with the choke off and throttle wide open. Keep your face away from the carb in case it backfires. | |
| ![Go down](https://2img.net/i/empty.gif) | | Marines2621 Member
![Marines2621](https://2img.net/u/2812/37/66/46/avatars/537-64.jpg)
Age : 27 Join date : 2012-12-31 Points : 4509 Posts : 215 Location : Mountainburg, Arkansas
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | Subject: Re: 18HP briggs opposed twin March 1st 2013, 6:09 pm | |
| Spark plugs nice and clean? Have bad carbon build up in the cylinder? Or the intake port. Intake may be clogged. If It don't run. Take the carb and intake off and check that stuff. Clean the spark plugs. Someone could have messed with it and the timing is off or the gov has been messed with. A lot of reasons. Just throwing some out there | |
| ![Go down](https://2img.net/i/empty.gif) | | tractorboy567 Member
![tractorboy567](https://2img.net/u/2812/37/66/46/avatars/562-12.jpg)
Age : 26 Join date : 2013-01-02 Points : 4383 Posts : 121 Location : PA
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | Subject: Re: 18HP briggs opposed twin March 1st 2013, 6:21 pm | |
| spark plug could be shot, or a common problem is the timing is off, is air pushing out of the carb? | |
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | Subject: Re: 18HP briggs opposed twin March 1st 2013, 8:00 pm | |
| i took the carb off to clean it so we will see if that helps i think my problem is i put to much fuel in the carb | |
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | Subject: Re: 18HP briggs opposed twin March 1st 2013, 8:13 pm | |
| - greener179 wrote:
- i took the carb off to clean it so we will see if that helps i think my problem is i put to much fuel in the carb
One of the reasons I prefer carb cleaner for starting | |
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | Subject: Re: 18HP briggs opposed twin March 2nd 2013, 1:14 am | |
| i will hs the engine mounted tommorow so that will make it easyer to work on my problem | |
![18HP briggs opposed twin Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | 18HP briggs opposed twin | |
| Who is online? | In total there are 137 users online :: 1 Registered, 0 Hidden and 136 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
