| BAJA SEARS BUILD | |
+41upnorthkid TheBeal MatthewD the old guy Doug Carshowkid Deluxe66 jonjunk jeremynitro ThatOneTeen Mitch'sgarage dwcopple kawasaki220 CornShuck4CE Angchor rarbaugh07 craftsmancole richie thomas willis923 goesman Stretch44875 Bigal bry_93 TheRainbowBoxer Lawren Wimberly the54 Moose Creepycrawler Craftsman1998 Thunderdivine MowBandit jsisti845 mrkadage T-Dub13 WellThatsSurprising LAWN MOWER MUDDER TroyBilt Pony camomanusa 1997 Murray redlinemotorsportts mr.modified 45 posters |
jeremynitro New Member
Age : 34 Join date : 2013-11-02 Points : 7130 Posts : 2907 Location : New Jersey USA
| Subject: Re: BAJA SEARS BUILD June 29th 2014, 4:39 pm | |
| Thanks. Just a couple more things here and I'll be good more or less. Just about to see if this thing will run on it's own. Fuel lines and wiring are good. I'll have some video on here in a few hours if all goes like it's supposed to. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6366 Posts : 1434 Location : east dublin georgia
Age : 23 Join date : 2013-04-08 Points : 5175 Posts : 913 Location : Central Pa
| Subject: Re: BAJA SEARS BUILD June 29th 2014, 10:03 pm | |
| Dood, this thing is awesome!! My money is on you!!
That IS the best sounding single cylinder motor ever!! I LOVE IT!!!
Good luck!
Last edited by LAWN MOWER MUDDER on June 30th 2014, 6:01 pm; edited 1 time in total | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4202 Posts : 337 Location : Woodville Al
| Subject: Re: BAJA SEARS BUILD June 29th 2014, 11:10 pm | |
| WHAT NO DONUTS OR BIG JUMPS!!!! I wont ta see you thrash it some. Great job. | |
jsisti845 Member
jonjunk Member
Age : 31 Join date : 2014-03-21 Points : 3942 Posts : 66 Location : Montrose, MN
| Subject: Re: BAJA SEARS BUILD June 30th 2014, 12:30 am | |
| Very cool, lots of cool features especially the hydraulic brakes. | |
| Subject: Re: BAJA SEARS BUILD June 30th 2014, 1:05 pm | |
| Thanks, yeah the test drive had to be kind of mild with the clutch not figured like it should be and the throttle will only open up about half way. Needs to be adjusted a little. Everything else seems to be ok more or less. | |
Deluxe66 Member
Age : 47 Join date : 2014-05-23 Points : 3927 Posts : 120 Location : Finland
| Subject: Re: BAJA SEARS BUILD July 1st 2014, 3:34 pm | |
| Looking really good. You may have an shifting problem if you use gloves | |
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4385 Posts : 491 Location : Index, Washington
| Subject: Re: BAJA SEARS BUILD July 1st 2014, 6:58 pm | |
| The only thing really messed up with this thing is the stupid clutch. If I could figure out something that would work better, I'd be in good shape. Slack side of the belt is on the top, and there isn't much room between the belt and the frame. Even if my current clutch was on the slack side, I don't think it has enough movement. I don't have any guides on it yet either, but it's got to lay on there pretty loose to disengage. I can hold the clutch in while it's in gear and drag the wheel with the brake across the concrete floor. What would be nice is if you could have some sort of disk style clutch or something right on the transmission. Can't mess with the engine side with the alternator pulley there. Yes, the alternator turns backwards too, but it does put out voltage, so that's ok except the fan on it blows in the other direction. | |
Guest Guest
| Subject: Re: BAJA SEARS BUILD July 9th 2014, 3:06 am | |
| so since this build has been extended have u figured out the pulley ordeal yet |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4545 Posts : 467 Location : Greensburg, PA
| Subject: Re: BAJA SEARS BUILD July 9th 2014, 9:46 am | |
| - MTD2fst4u wrote:
- so since this build has been extended have u figured out the pulley ordeal yet
Take advantage of this time to fix all the little things (Paint on the numbers, paint the hood if desired etc.,) i just seem it now it looks amazing!!!! | |
| Subject: Re: BAJA SEARS BUILD July 11th 2014, 11:31 pm | |
| Ok, I couldn't get the thing to run and the float kept sticking and leaking fuel all over my nice exhaust paint. Cleaned the carb, fixed the leak. Turns out the plug was fouled up from running it rich tryin to get flames to shoot from the exhaust. Fixed that too. Now it runs again. I'm really not sure what to do with the clutch. I have a couple ideas, but there isn't much room to make a decent setup without messing up everything I already did. Repainting an area isn't a big deal, but I don't want to cut huge holes in the frame or move the alternator. Slack side of the belt is on the top, and there isn't much room between the frame and the belt. I do have some lettering to do at some point, but I wanted to make sure I wasn't going to mess it up in case I had to weld something for the new clutch. Fixed the throttle too. Now it opens the throttle up all the way in stead of just half. | |
Guest Guest
| Subject: Re: BAJA SEARS BUILD July 11th 2014, 11:39 pm | |
| i wouldnt stress about messing it up none or paint we all know what it looks like now and if something happens and some paint is messed up no biggie i understand tho u want perfection but not all the time can it be that so dont stress lol i am really really wanting to see u out and tearing stuff up and driving im sure the rest of us is just as anxious as me lol |
| Subject: Re: BAJA SEARS BUILD July 12th 2014, 1:38 pm | |
| Well the yellow is just brushed on, so no big deal to fix a spot anyway. I want to see how fast it'll go with the gearing, so maybe I'll get it into high gear and go for a run down the driveway sometime soon. I'll get some footage eventually. | |
| Subject: Re: BAJA SEARS BUILD July 17th 2014, 12:34 pm | |
| - mr.modified wrote:
- Ok, Turns out the plug was fouled up from running it rich tryin to get flames to shoot from the exhaust.
Dang LOL. Did you get success with getting the flames??? | |
jsisti845 Member
| Subject: Re: BAJA SEARS BUILD July 31st 2014, 8:59 pm | |
| I was going to do a little test running and get some footage, but any trucks we or anyone has are currently broke down. So the sears is stuck at the shop. Otherwise, not really any progress, on this project at least. | |
Age : 23 Join date : 2014-01-22 Points : 4537 Posts : 546 Location : north carolina
| Subject: Re: BAJA SEARS BUILD August 18th 2014, 11:08 pm | |
| Yeah, I finally got the mower home from the shop. So as soon as I get a chance, I'm going to get some video. Took it for a ride around and everything seems to work ok. Except the clutch of course. Slips under load, with the pulley on the wrong side of the belt, but it finally does disenguage some after the paint wore off the engine pulley and the belt got worn in a little. I'm going to try a stiffer clutch spring for now and see how it goes. Exhaust needs some window screen jammed inside to keep your ears in one piece though, but after the video maybe. | |
| Subject: Re: BAJA SEARS BUILD November 23rd 2014, 10:23 pm | |
| I finally got this thing back out and started working on it again. This weekend I took the lower half of the exhaust pipe off and tried to quiet the thing down a little. Stuffed some window screen into the very back of the megaphone. Welded a couple of big washers in front of the screen to act as baffles and keep the screen in place. Then I cut out some perforated steel to fit across the end of the megaphone to further baffle the sound...(Ok and to look cool). Spray painted it back up again, I think it looks kind of neat that way. Next is to build a new clutch. I took the old one off. I think I can make one that works without cutting my frame up too bad. I guess we'll see. Tip the tractor on it's side and you can cook hot dogs on it. | |
Age : 27 Join date : 2013-03-18 Points : 7449 Posts : 3131 Location : raleigh nc
| Subject: Re: BAJA SEARS BUILD November 24th 2014, 6:56 pm | |
| Hopefully youll get this done in time for hinkley.... Well, going off the progress rate of the simplicity. lol | |
