 BAJA SEARS BUILD
upnorthkid
the old guy
Carshowkid
Deluxe66
jonjunk
jeremynitro
ThatOneTeen
Mitch'sgarage
dwcopple
CornShuck4CE
Angchor
rarbaugh07
goesman
Bigal
bry_93
the54
Moose
Craftsman1998
MowBandit
jsisti845
mrkadage
T-Dub13
WellThatsSurprising
TroyBilt Pony
camomanusa
45 posters
Go to page : Previous  1 ... 6 ... 9, 10, 11, 12, 13, 14  Next
BAJA SEARS BUILD - Page 10 Empty
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 24th 2014, 6:56 pm
Hopefully youll get this done in time for hinkley.... Well, going off the progress rate of the simplicity. lol
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 24th 2014, 11:02 pm
Yeah, Gotta get back to that too. In the last 6 monthes I got a couple of tack welds on the exhaust, pretty good progress.
Carshowkid
Carshowkid
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 25th 2014, 11:08 pm
ha that's what I said when I was working on my racing tractor and mostly stopped for 3 months
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 30th 2014, 7:35 pm
This is what i'm thinking about the clutch. I'll have to make a bracket and bolt it to the engine block via some of those threaded holes you see there. Basicly, that's how it was on the stock engine. Belt should be loose enough to not drag, so I think some guides around the engine pulley should keep it from dragging when disengauged. Space is limited, so I'll have to make a pretty compact setup, but it should actually work this time. Otherwise I just have to finish hooking up the alternator and tighty up some of that wiring that just hangs along the frame.
BAJA SEARS BUILD - Page 10 Img_3815
BAJA SEARS BUILD - Page 10 Img_3816
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 30th 2014, 7:38 pm
Looks like it should work. Isn't there anymore space towards the trans-axle side?
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 30th 2014, 7:47 pm
Clutch itself isnt hard to mount, looks like the linkage is the hard part.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 30th 2014, 7:55 pm
Touche... pardon my french...
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeNovember 30th 2014, 8:30 pm
The trouble is that the belt runs along right under the frame, so there isn't any room for the pulley when disengauged.
As far as the linkage goes, I think it'll be ok. Should be able to run a rod right down to where it was before without any major hassle. I don't know how or where i'm going to hook the spring though, might have to weld something somewhere. Not sure yet. I'll worry about that last.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 1st 2015, 11:11 pm
Decided to mount the clutch directly to the frame instead of on the engine. Turns out there is enough room, so it should work out pretty good. Took the alternator out of the way and welded up some brackets.
BAJA SEARS BUILD - Page 10 IMG_4022_zpsw8rtbzuf
BAJA SEARS BUILD - Page 10 IMG_4025_zpsqumaheu2
Pulley needs to be as far towards the center of the tractor as possible to clear alternator belt.
BAJA SEARS BUILD - Page 10 IMG_4023_zpsauckzxe5
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 4th 2015, 12:21 am
I think the exhaust modifications made it a lot quieter than it was. Still sounds pretty good.
Exhaust with baffles.
Old open exhaust megaphone.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 4th 2015, 9:56 am
Oh look, sears has already been to Baja.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 4th 2015, 11:12 am
Muffler will be good enough for pa.... Laughing clutch looks like a 1 day gig.
You didn't even lay tape down to protect the paint from the slag man!!!
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 4th 2015, 12:52 pm
Oh is that what your supposed to do? Figured I would just scrub things a little and repaint. Also, I found out a snowmobile tach works good with one wire grounded and the other connected to your kill switch wire on the coil. Now I need to find a hole saw big enough for the tach and I'll cut a hole in the dash. Only stupid thing about it is the tach goes to 10,000 and the briggs only runs up to 3500 or so. Still looks neat though.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 4th 2015, 9:00 pm
I had trouble with the starter turning pretty slow as if you had a half dead battery even with a known good battery. I figured the starter was burned up, but turns out the bushings needed some oil. Blew everything out with compressed air, oiled the bushings, and cleaned off the brushes. Now it seems to work pretty good.
BAJA SEARS BUILD - Page 10 IMG_4035_zpscezk4kxh
Throttle before was at a bad angle, cut off the pipe it was mounted to and reconfigured it a little. Works much better.
BAJA SEARS BUILD - Page 10 IMG_4036_zpsj6opbkit
Mocked up a rear fender for the heck of it. My idea before was to mount them to the seat. I guess that's still what I would do, but I don't know if they would look too good or not. Probably cut them out of plastic. Maybe if they were the right color, they would look ok.
BAJA SEARS BUILD - Page 10 IMG_4037_zpscga1a2pn
You can get an idea of what it would look like. You could change the shape and size of them, but go much smaller and there wouldn't be much point to putting them on. It would just keep some water from splashing right onto the seat, wouldn't be nearly as good as full fenders, but we kind of have to stay with the desert look which means something along these lines.
BAJA SEARS BUILD - Page 10 IMG_4038_zpskotmnqat
And lastly, started working on this steel rod scatter sheild to keep the big chunks of cast iron flywheel from flying into your foot. At least it would slow them down some. This will end up bolting to the frame in a couple spots covering the flywheel from straight down to about where the starter gear is. I planned on doing this during the build off but didn't have time.
BAJA SEARS BUILD - Page 10 IMG_4039_zpsblpdcqyj
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 5th 2015, 3:25 pm
you should take a saw to the local junk yard and just saw off some old fenders off a sport quad those would look awesome as heck on this sears
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 5th 2015, 8:17 pm
Yeah something like that might work.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 6th 2015, 9:55 pm
Got the choke installed, switches labeled up with a marker, Tachometer installed!
BAJA SEARS BUILD - Page 10 IMG_4049_zpskjhdfn3o
Tach is from a 1979 or so kawasaki snowmobile. Kind of neat that it doesn't have kawasaki printed on it, just plain. Two wires for the tach itself. Ground one and connect the other to the coil shut off wire, seems to work pretty good. Marked the 4000rpm redline on there for good measure.
BAJA SEARS BUILD - Page 10 IMG_4050_zpsaodaq34s
Light even works. I'll hook it up so it comes on with the main headlights. I was thinking I should have a dash light too, so it shines on the switches.
BAJA SEARS BUILD - Page 10 IMG_4046_zpsnofcz0tq
Finished up the scatter shield today.
BAJA SEARS BUILD - Page 10 IMG_4051_zpsc16qbvox
BAJA SEARS BUILD - Page 10 IMG_4052_zpsrojpa8ps
Not only does it slow down jagged shards of flywheel from turning your clutch foot into hamburger meat, it also keeps your shoe from grinding on the flywheel screen.
BAJA SEARS BUILD - Page 10 IMG_4054_zps1uz2hymp
Some of the tight bends were already in the rod I was using. Kind of went around the starter gear like that for looks more or less. In the event of an actual flywheel failure, I don't know how much it would help, but I'll bet it would be better than nothing. Should absorb a lot of energy even if it bends back a little. The other thing is that it holds the choke cable where it belongs so I don't need to make another bracket for it.
BAJA SEARS BUILD - Page 10 IMG_4053_zps27fi8djo
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 6th 2015, 11:06 pm
My rigs gonna look like fresh crap next to yours in PA lol. Gotta step up my game.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 7th 2015, 9:37 am
Not like everything is in perfect shape on this either. I never painted up the tie rods or the engine. The stock tie rod ends seem to be pretty snug, so I think I'll just leave them for now. I've got spares from my parts sears. Figured I could just keep extra rods on hand with the ends already on them.
the old guy
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 7th 2015, 3:18 pm
I really like the tach , didn't think they would be that simple to hookup. You do good work.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 7th 2015, 4:45 pm
As mentioned, I think ATV Fenders would look really good on this! It would fit the theme quite well.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 7th 2015, 8:46 pm
Cage looks real slick. But will it conquer the creek that ate both of dougs rigs?? We will have to see...
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 7th 2015, 8:53 pm
It might be even deeper in May. WHOOO KNOOOOOOOOOOOOWSSSSSS????
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 7th 2015, 9:47 pm
As doug remembers, not only does he have two weddings and a dentist apointment scheduled for that weekend, but also his tractor is in pieces in his garage... No problem mr. fackler, you don't have to miss your weddings and junk.
Thanks, and it'll handle any stream you've got...maybe. Got quite a bit done the past couple days because I have some time off. I got the clutch mostly rigged up today. Just need to add the springs.
Still need to:
-Lock rear
-Round off back corners of hood for safety...
-Finish wiring
-Rear fenders if I get to it.
-Snug up all the bolts I never tightened.
-Remove governor guts that I just left inside the engine...I know people seem to think they fly apart, I don't see why they would. I guess maybe the weights get slapping back and forth under certain conditions without a load on them. I was thinking for now, maybe find a governor arm off another engine and hook it with a spring. Then I can leave the engine alone.
Everything else mostly good I think. I should probably change the oil, STILL the same oil that was in it when I got it out of a guys back yard. Maybe a couple more stickers on the hood. That oughta cover it I think.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 7th 2015, 11:49 pm
Well if we go into the gamelands theres another stream crossing. They dug it out to deter ATVs. I bet we can figure a way around that lol.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 10 Icon_minitimeMarch 8th 2015, 2:37 pm
BAJA SEARS BUILD - Page 10 Test_p19
BAJA SEARS BUILD
Page 10 of 14Go to page : Previous  1 ... 6 ... 9, 10, 11, 12, 13, 14  Next
» Baja sears suburban
» Baja Mini Bike Build
» Sears Build
» Hutch's Sears LT-10 Build
» Sears Hot Rod Gasser Build
