 BAJA SEARS BUILD
upnorthkid
the old guy
Carshowkid
Deluxe66
jonjunk
jeremynitro
ThatOneTeen
Mitch'sgarage
dwcopple
CornShuck4CE
Angchor
rarbaugh07
goesman
Bigal
bry_93
the54
Moose
Craftsman1998
MowBandit
jsisti845
mrkadage
T-Dub13
WellThatsSurprising
TroyBilt Pony
camomanusa
45 posters
Go to page : Previous  1 ... 7 ... 10, 11, 12, 13, 14  Next
BAJA SEARS BUILD - Page 11 Empty
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 8th 2015, 2:37 pm
BAJA SEARS BUILD - Page 11 Test_p19
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 8th 2015, 10:09 pm
Thats basically how our weekend will go, guaranteed.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 9th 2015, 10:10 pm
the old guy wrote:
I really like the tach , didn't think they would be that simple to hookup. You do good work.
Thanks. I tried hooking that tach up a year or so ago to a chinese minibike engine and it jumped around a lot. Seems to work good on this engine. I don't know if the coil on the chinese engine has a weird electrical pulse or something that messes it up, or maybe I just had it hooked up backwards? This time when I tried it, it was nice and smooth and stayed right where you would expect it to be, so I guess it's ok. Kind of good to know, because junk snowmobiles with electical tachs should be pretty easy to come across, at least up north.
I hope not exactly like that, but anyway...I was thinking I could quiet the sears down even more if needed pretty easy by making an oval plate from aluminum or something with a 1" hole in the middle and then rivet onto the screen that I welded across the end. I think that would really cut it down. High speed chase, doug fackler vs. fish and game...
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 10th 2015, 6:09 pm
Essentially. Maybe I should hold off on sticking ATLTF and my Youtube stickers on lol.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 10th 2015, 7:08 pm
Where y'all gonna be riding at?
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 10th 2015, 8:24 pm
My families place upstate, where I shot my last two train riding videos.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 10th 2015, 9:06 pm
Thats if the rally doesnt die... MTD playing tow truck.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 10th 2015, 10:53 pm
Nothing is going to pull a broken down 700lb baja sears up a rocky hill. That 820 transmission case might as well be made out of wet tissue paper. Besides, I'll just have my chase helicopter drop off some spare parts if I need anything.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 13th 2015, 8:57 pm
I might have accidently fibbed about the tach working good. I had the sears running again and rigged up the tach temporary like again. This time it kind of jumped around a lot. Before it was nice and smooth right where it was supposed to be. I don't know if I just had a bad connection or if the tach pics up some kind of electronic "noise" from somewhere. I'm just going to hook the wires up good and then I'll see how it goes. Maybe some kind of ballast or resistor in the line would help.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 14th 2015, 9:04 pm
Removed transaxle.
BAJA SEARS BUILD - Page 11 IMG_4080_zpsiktmasaf
All the spots I didn't paint up too good during the build off.
BAJA SEARS BUILD - Page 11 IMG_4081_zps0winmcb0
BAJA SEARS BUILD - Page 11 IMG_4082_zpskq8v5onl
BAJA SEARS BUILD - Page 11 IMG_4083_zpsnkajj9gp
Wheel hub is froze on the bottom axle, I assume. I never tried getting that side off. So, I couldn't take the entire axle out to lock it. Needed to bend a wrench to fit the bolts under the differential.
BAJA SEARS BUILD - Page 11 IMG_4086_zpsggalg0vm
All I did was flip the spider gears around so that two were locked on one axle and two on the other. Normally of course, those two gears are opposite, one up, one down. Here you can see they are both at the bottom.
BAJA SEARS BUILD - Page 11 IMG_4088_zps8dbdmpsr
Side view showing the gears on the ends of each axle and the spider gears.
BAJA SEARS BUILD - Page 11 IMG_4093_zpsmr53vdvi
Cleaned it up a little and gave it a quick paint job. Should be about ready to go back in.
BAJA SEARS BUILD - Page 11 IMG_4094_zpsvslhl1ui
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 14th 2015, 10:20 pm
Super fancy dancy pantsy rantsy.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 15th 2015, 9:02 pm
Painted up the drive pulley and put that back on. Put some set screws in the hub on the brake rotor side, because I guess I never put them in. Then I put the trans back in the tractor. So at least that part is done.
BAJA SEARS BUILD - Page 11 IMG_4095_zps3vqdqrl0
Took the engine off to remove the governor parts, since I had the mounting bolts out already. You can't get the belt off of this thing without taking the engine loose. Kind of a bad design on my part if you want to change a belt. I could probably run a longer belt through a couple of idlers and get around that.
BAJA SEARS BUILD - Page 11 IMG_4100_zpseud3qemd
Got tired of trying to block these engines up on something to drain the oil without getting it all over.
BAJA SEARS BUILD - Page 11 IMG_4097_zps7avs0c18
So...after messing around trying to get the side cover off with some rust on the crank, I find out this thing has a couple of ballance shafts. They don't have any kind of timing marks on them. What I think they probably want you to do, is line up the timing marks on the camshaft and crank. Then just put the side cover back on. The weights spin to the bottom easily because they run on roller bearings. If you did it this way, the counter weight on the crank would be about at the 8:00 position looking into the block. Or maybe they want you to put it at top or bottom dead center. No idea. There's no way to see where they end up, so it must rely on just putting the crank in the right spot and sliding the cover on. I've never seen any small engines with ballance shafts like this. For the time being I left them out and I'm going to see how bad it is without them. I know the vertical shaft engines with the eccentric driven weights are supposed to vibrate badly with them removed. But I figured they pull directly on the crankshaft. With these, the pressure or force is applied to the block. So even if the vibration is a lot worse, I don't see how any engine parts would have more stress than before. Except maybe the mounting bolts and block. If it's really bad I can just put them back in.
BAJA SEARS BUILD - Page 11 IMG_4098_zpsjqhfyhoc
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 18th 2015, 9:47 pm
Hey, Just a quick heads up, we locked 3 of the sears in our group just like you did and two blew the diff gears out and cracked the bottom of the case. the strange part is the one thats never broken has the biggest motor and tires of all, and gets used the most. We flip and weld now, no more breakages. We all run much more aggressive tires than you, so you might never have a issue.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 19th 2015, 11:42 am
i think my 600 pound bolens might give it a good run for its money.. but its blown up ATM. dont think the GT would do much
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 20th 2015, 2:06 pm
I should actually weigh this thing. Feels pretty hefty.
Interesting, did you guys take them apart and see what failed? I figured it puts the stress on the plates that hold the gears and the bolts. I have two other transmissions available if this one breaks. I thought I would give it a try and see how it goes. Maybe I'll start working on another one and weld that one up. Thanks for the info.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 21st 2015, 10:43 pm
More stickers
BAJA SEARS BUILD - Page 11 IMG_4106_zpslbr5rsnr
Vibration proof engine bolts. Double nutted with loctite
BAJA SEARS BUILD - Page 11 IMG_4107_zpsw3iucqas
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 22nd 2015, 11:05 am
I wonder how the briggs will handle the water splashing. I know I'm going to make something to go over my air filter so it doesn't get wet being up front.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 22nd 2015, 11:17 pm
I figured the stock air box would keep things pretty good. I forgot you've got that open air cleaner.
Made an adjustable foot brace to prevent jerky throttle operation on rough ground. Rest your foot on it when using medium throttle for cruising.
BAJA SEARS BUILD - Page 11 IMG_4114_zpsumvkbbym
Or if you want full throttle, move your foot off the rest.
BAJA SEARS BUILD - Page 11 IMG_4115_zpsz12cofyk
Just used a bolt with a nut on both sides of the bracket so you can adjust it where you want. I'll find out if it's too close to the throttle pedal once I drive around some, if so I can just put a hole out farther away.
BAJA SEARS BUILD - Page 11 IMG_4113_zpspicwlkdq
On the lift.
BAJA SEARS BUILD - Page 11 IMG_4116_zpsxk6sngcy
Handy "mess free" drain plug setup.
BAJA SEARS BUILD - Page 11 IMG_4118_zpsb0gsbnip
Bunch of clutch springs hooked up. Clutch almost done, couple more small things to fix up.
BAJA SEARS BUILD - Page 11 IMG_4124_zpsyynauame
The start of a medium duty skid plate. Will bolt to the frame on all four corners.
BAJA SEARS BUILD - Page 11 IMG_4123_zpswptpyydi
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 23rd 2015, 9:25 am
I like the skid plate alot. I wouldnt worry to much, the guy that tore em out was running 25x8x12 black mambas. Yep, we took em apart, one ripped the teeth of the planetary gears (the ones you flipped) and then the broken teeth got in the rest of the tranny and destroyed it. The other one ripped the plate that the bolts that hold the planetary got though. a chunk got between the bull gear and the case and blew the case apart.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 23rd 2015, 10:02 pm
Those gears and everything are fairly heavy pieces. I guess after a while they stress. I know a guy that might have a couple more sears tractors around too if I frag more than the two extras I have on hand. I'll give it a good testing.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 28th 2015, 8:56 pm
Major progress! Got the original baja sears tie rod at the bottom and the parts sears suburban tie rod on top. Same tractor, but maybe different year and sears got a deal on tie rods from someone else at the time. I don't see why they would need to be twice as heavy in a stock situation. At any rate, going to install the heavier ones and keep the light ones for spares.
BAJA SEARS BUILD - Page 11 IMG_4125_zps1c35dbmv
Joints are bigger too, same threads, so they fit right in. The rod from the steering shaft to the front was the same on both tractors, but I took that off for a spare too.
BAJA SEARS BUILD - Page 11 IMG_4126_zpschcossv8
Gotta have fenders for water crossings, so I cut some out of the back of a mercury sable.
BAJA SEARS BUILD - Page 11 IMG_4128_zpsvpy4ulww
They seem to fit pretty good, tried to match them side to side as good as possible.
BAJA SEARS BUILD - Page 11 IMG_4129_zpszi2crta0
I'll paint them blue to match everything else, then re-install with some large washers so the bolts don't pull through the plastic. Welded brackets to the seat and they attach with two 1/4" bolts.
BAJA SEARS BUILD - Page 11 IMG_4130_zpssphaf0di
Aluminum number plate, so people know who just past them. Grab bar protects the gas tank neck from overly hyped up racers trying to pass you and also gives you a place to pick up the back end.
BAJA SEARS BUILD - Page 11 IMG_4132_zpsxnovhnhy
Once the paint dries, I'll grease up the joints a little and bolt these on.
BAJA SEARS BUILD - Page 11 IMG_4133_zps9lmbfqti
Brakes are back on. Still have to:
Finish skid plate
Lengthen brake pedal 2"
Install alternator, clutch, gas tank, tie rods
Solder wiring
Paint
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 28th 2015, 9:05 pm
You're still going to get a ton of water spray, but way better then.... no fenders. Plus they look really good for using some car bumper too.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeMarch 29th 2015, 10:23 pm
Thanks. Yeah they don't offer 100% coverage, but I had to stay with the baja look. I figure just keep water from pouring directly onto the seat. Also maybe keep your hands from getting caught between the tires and the sharp edge of the seat. Could possibly hurt pretty bad.
Painted the fenders. Probably add some stickers. Seat painted back up where I welded the brackets.
BAJA SEARS BUILD - Page 11 IMG_4138_zpsxj2urr4d
Painted rear bumper again and added some silicone spots to the gas tank cradle for the heck of it. Now I can put the tank back in and bolt on the number plate ect.
BAJA SEARS BUILD - Page 11 IMG_4147_zpsk2frmral
Got two free dunlop atv tires at my super free tire getting location. That rusty sears rim on the right will get cleaned up and painted, then I'll mount the tire with the thinner knobs which I already cleaned up. Neither tire has exactly the same tread as the matching set already on the tractor, but the one I cleaned up is closest.
BAJA SEARS BUILD - Page 11 IMG_4148_zpswei61cdh
Only things left to do now is finish soldering some wire connections, put seat/fenders on, and weld up the skid plate. Brakes completely done, tie rods greased up and swapped over, spare tie rods painted up a bit. Painted up my belt idler and bolted back in. Even touched up a bad spot on the front bumper where it was too close to the garage door when I opened it...Should be some testing next weekend.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeApril 4th 2015, 6:44 pm
Just a few small details to finish up.
BAJA SEARS BUILD - Page 11 IMG_4149_zpsy7o2ullw
Light weight plastic fenders installed.
BAJA SEARS BUILD - Page 11 IMG_4156_zps22vfvnr3
Cracked steering wheel taped over and sears cap installed.
BAJA SEARS BUILD - Page 11 IMG_4152_zpssd4slaqm
Gas tank back in, number plate bolted on, and adjusted the fuel line situation slightly.
BAJA SEARS BUILD - Page 11 IMG_4154_zpsgmy8neoy
New gas tank vent line runs up the side of the dash to the highest spot on the machine to keep it above water.
BAJA SEARS BUILD - Page 11 IMG_4155_zpsyh6bjwfq
Skid plate during contruction, now painted. It was tough to get a good picture showing the whole thing. A couple rods come out and protect the brake caliper. At least somewhat.
BAJA SEARS BUILD - Page 11 IMG_4158_zpssd12budn
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeApril 5th 2015, 9:41 pm
Skid plate painted
BAJA SEARS BUILD - Page 11 IMG_4160_zpskjobbbuw
Skid plate installed
BAJA SEARS BUILD - Page 11 IMG_4163_zpszjnvo6w7
Partial coverage of the brake caliper, mostly the brake hose.
BAJA SEARS BUILD - Page 11 IMG_4165_zpslmweam0v
Spindles braced up.
BAJA SEARS BUILD - Page 11 IMG_4166_zpsjpjnnesl
Fire extinguisher with removable mount.
BAJA SEARS BUILD - Page 11 IMG_4167_zpsjcvrlzjj
Two hose clamps per side will hold it down.
BAJA SEARS BUILD - Page 11 IMG_4168_zpscmigchel
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 11 Icon_minitimeApril 6th 2015, 12:07 am
What kind of speed have you geared for?
I looked through the thread, I could have missed it.
BAJA SEARS BUILD
Page 11 of 14Go to page : Previous  1 ... 7 ... 10, 11, 12, 13, 14  Next
» Baja sears suburban
» Baja Mini Bike Build
» Sears Build
» Hutch's Sears LT-10 Build
» Sears Hot Rod Gasser Build
