| BAJA SEARS BUILD | |
+41upnorthkid TheBeal MatthewD the old guy Doug Carshowkid Deluxe66 jonjunk jeremynitro ThatOneTeen Mitch'sgarage dwcopple kawasaki220 CornShuck4CE Angchor rarbaugh07 craftsmancole richie thomas willis923 goesman Stretch44875 Bigal bry_93 TheRainbowBoxer Lawren Wimberly the54 Moose Creepycrawler Craftsman1998 Thunderdivine MowBandit jsisti845 mrkadage T-Dub13 WellThatsSurprising LAWN MOWER MUDDER TroyBilt Pony camomanusa 1997 Murray redlinemotorsportts mr.modified 45 posters |
camomanusa Member
Age : 34 Join date : 2013-11-02 Points : 7172 Posts : 2910 Location : New Jersey USA
| Subject: Re: BAJA SEARS BUILD June 17th 2014, 10:22 pm | |
| Bumper tubing front, rear, and the rub rails on the side will be blue. The frame and some of the other stuff bolted to it will be rustoleum safety yellow. I think maybe some black pickup bed liner on the top of the running boards. I've thought about the seat. I thought maybe it would be neat to paint the seat the same blue as the bumpers, but I don't know if it would look too wild or not. Otherwise I will paint it black. Of course, I could try the blue and paint over it if it looks wierd or I get tired of it. Front shocks will be white. I kind of decided to not make any fenders just now. They were going to be yellow plastic if I could find it. Might not be totally done on the 30th, but it'll be pretty bright looking I think painted up. | |
Age : 23 Join date : 2014-01-22 Points : 4574 Posts : 546 Location : north carolina
| Subject: Re: BAJA SEARS BUILD June 18th 2014, 8:31 am | |
| you should put those nice atv fenders on it, just cut some off a atv at the junkyard | |
Mitch'sgarage Member
Age : 25 Join date : 2014-03-24 Points : 3945 Posts : 46 Location : Omaha, Nebraska
| Subject: Re: BAJA SEARS BUILD June 18th 2014, 9:09 am | |
| Nice work man, I like the hood and dash. Can't wait to see it done. | |
| Subject: Re: BAJA SEARS BUILD June 18th 2014, 9:30 pm | |
| no prob man about fenders but when somone says baja i think of atvs so i thought atv fenders, that would be cool | |
| Subject: Re: BAJA SEARS BUILD June 18th 2014, 9:43 pm | |
| I may put them on later. I'll see how it looks painted up. | |
| Subject: Re: BAJA SEARS BUILD June 23rd 2014, 7:49 pm | |
| Paint! Got a suzuki kind of theme going on. Running boards need some bed liner on top or black paint. Rear bumper, gas tank straps, seat spring mount. Decided on black for the seat. Shocks painted up, high heat stuff on the exhaust. Reassembly starts tommorrow. | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4239 Posts : 337 Location : Woodville Al
ThatOneTeen Member
Age : 26 Join date : 2014-05-22 Points : 3999 Posts : 144 Location : Illinois
| Subject: Re: BAJA SEARS BUILD June 23rd 2014, 9:04 pm | |
| Thanks, the yellow almost burns your eyes doesn't it? I think once everything else is on there, it'll even things out a little. | |
ThatOneTeen Member
| Subject: Re: BAJA SEARS BUILD June 23rd 2014, 9:05 pm | |
| - mr.modified wrote:
- Thanks, the yellow almost burns your eyes doesn't it? I think once everything else is on there, it'll even things out a little.
I like the yellow, It really makes things noticeable | |
| Subject: Re: BAJA SEARS BUILD June 25th 2014, 8:41 pm | |
| Got some of the stuff bolted back on. Getting there. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4582 Posts : 467 Location : Greensburg, PA
| Subject: Re: BAJA SEARS BUILD June 25th 2014, 9:42 pm | |
| Well thanks a lot. That's what I was kind of thinking. Of course it will need some more stickers once it's all back together. Only thing is, today I realised that my clutch is on the tension side of the belt instead of the slack side. Some time i'll have to reconfigure that, but there isn't much room to change it. No big deal, i'm sure a solution will present itself in time... | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5155 Posts : 1068 Location : New jersey
CornShuck4CE Member
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6546 Posts : 2101 Location : Norway, Europe
jeremynitro New Member
Age : 40 Join date : 2014-06-19 Points : 3824 Posts : 11 Location : IN, in the sticks
| Subject: Re: BAJA SEARS BUILD June 26th 2014, 10:11 pm | |
- Thanks
That paint job LOL Looks good man! Where is the SUZUKI logo at? | |
| Subject: Re: BAJA SEARS BUILD June 28th 2014, 6:41 pm | |
| Things look a bit untidy aft, but everything back here is hooked up. Got your tail light ground and power, fuel line and filter, and your vent line. Used mikuni fuel pump, guess somebody had it on a racing cart or something at one time. That's bolted down, just have to run the fuel line to the carb and the vaccum line to the manifold. Brazed a piece of brake line into the intake. Now there's a place to hook up the fuel pump. | |
Age : 23 Join date : 2013-04-08 Points : 5212 Posts : 913 Location : Central Pa
| Subject: Re: BAJA SEARS BUILD June 28th 2014, 11:37 pm | |
| Heck no, whole bunch of stuff yet to get rigged together. Plenty of time, I've got till midnight sunday...pllllllllllenty of time... | |
