 BAJA SEARS BUILD
upnorthkid
the old guy
Carshowkid
Deluxe66
jonjunk
jeremynitro
ThatOneTeen
Mitch'sgarage
dwcopple
CornShuck4CE
Angchor
rarbaugh07
goesman
Bigal
bry_93
the54
Moose
Craftsman1998
MowBandit
jsisti845
mrkadage
T-Dub13
WellThatsSurprising
TroyBilt Pony
camomanusa
45 posters
Go to page : Previous  1, 2, 3, 4, 5, 6 ... 9 ... 14  Next
BAJA SEARS BUILD - Page 5 Empty
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeMarch 17th 2014, 8:19 pm
Thanks for the comments, I guess we'll go with black. I picked up some washers to use for flanges tonight. I should be able to finish the exhaust this weekend.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeMarch 24th 2014, 9:33 pm
Well, I started hooking the exhaust on this weekend...Until I got doing other stuff. You can see the tab welded behind the pipe and bolted to the frame. I guess I'll also make some kind of bracket where the megaphone is and that should handle holding the pipe to the tractor. If I ever get out to the garage tonight, maybe I'll get the holes drilled through the washers for the upper/lower exhaust connection. It'll use the same gasket as the port, that way It's easy to get another one if nessesary.
BAJA SEARS BUILD - Page 5 Img_3314
camomanusa
camomanusa
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeMarch 24th 2014, 9:50 pm
verfy good, cant wait to hear the baja going with that
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeMarch 30th 2014, 9:19 pm
Thanks. This is the second weekend in a row that I really didn't get anything done on this thing. Just when you think your not busy you end up having to do a bunch of other stuff. Anyway, I did get the holes drilled in the washers for the exhaust connection. Now I have all the pieces, they just need to be welded up.
BAJA SEARS BUILD - Page 5 Img_3315
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 5th 2014, 10:02 pm
Finally got some of this exhaust done. Needed a little extra turn, so I welded on another bend before cutting to length.
BAJA SEARS BUILD - Page 5 Img_3316
Tacked to the Briggs flange.
BAJA SEARS BUILD - Page 5 Img_3317
Upper section complete. Now I just have to make the last bend and merge into the lower section.
BAJA SEARS BUILD - Page 5 Img_3318
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 5th 2014, 10:22 pm
looks good man, im jealous of that muffler...
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 5th 2014, 10:51 pm
Thanks, hopefully I'll have the whole system done tommorrow. Minus the gaskets, which I didn't get yet.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 14th 2014, 10:09 pm
Almost done with the exhaust...almost...Got the lower flange and final bend going, with the help of a magnet and piece of wood.
BAJA SEARS BUILD - Page 5 Img_3333
Cut the lower pipe/megaphone section.
BAJA SEARS BUILD - Page 5 Img_3334
Hammered and bent it into shape, just need to start welding it and do a little more hammering. Also, I need to add one more brace/hanger on the megaphone. Picked up a gallon of yellow rustoleum. I guess I'll just brush paint the frame with that.
BAJA SEARS BUILD - Page 5 Img_3335
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 14th 2014, 11:38 pm
Neat! Now i just need to hear it. The true test.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 15th 2014, 2:16 am
Nice job on the exhaust. - Now we wanna hear it roar bounce
Craftsman1998
Craftsman1998
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 15th 2014, 8:38 am
Nice work mr modified  What a Face
T-Dub13
T-Dub13
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 15th 2014, 9:52 am
Video Video Video~!!!!  Laughing
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 15th 2014, 1:13 pm
I agree
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 15th 2014, 5:08 pm
Thanks, as soon as I get it welded up I'll get some video.
T-Dub13
T-Dub13
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 16th 2014, 8:38 am
Try mounting the GoPro in some foam or something to stop the transfer of the noise. Sounds like it's inside a washing machine on spin cycle. I want to hear more motor and less GGGGGGGGG lol! Laughing  Great vids though and the slo-mo is cool!  Wink
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 16th 2014, 9:22 pm
Thanks for the comments.
Yeah, I think there's a lot of vibration transfered from everything when it's mounted on the tractor.
I welded up the lower pipe so that the pipe itself is pretty much done. I just need to add a couple braces.
BAJA SEARS BUILD - Page 5 Img_3339
I was worried that things were going to end up bent out of shape when I welded it, but it ended up pretty close.
BAJA SEARS BUILD - Page 5 Img_3340
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 16th 2014, 9:53 pm
sick exhaust. you can tell some serious thought and fab went into that
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 16th 2014, 9:59 pm
I agree with will, came out great! The cupplet from washers is neat, i attempted that on my single cyl but i made it from sheet metal and it never sealed. More fab then what my duals have thats for sure
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 16th 2014, 10:23 pm
Well thanks. I should be able to test it out this weekend. Should be pretty loud, we'll see.
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 16th 2014, 10:45 pm
seems like it would be loud and throaty
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 16th 2014, 10:59 pm
very impressed with the thought and quality of work, keep it up!
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 19th 2014, 6:01 pm
Welded up the braces. I put the exhaust back on and tested it without gaskets just to see how it sounded. When I started putting it back together I remembered that I never went to buy them. At any rate, it is loud, but not like I imagined it would be. Has kind of a neat sound when you back off the throttle. Sort of sounds like the mustang in the bullitt movie. You can see a bunch of white powder from the welding blow out when I crank it over. Of course when I rev it...well that looks like a bit of smoke. I was actually hoping it smokes just a little, draws attention to where the exhaust exits. Also you can see the pipe jumps around a lot. I didn't tighten up the mounting bolts on the lower pipe.
I welded on a couple pieces of bed frame for the firewall/dash. This will hold your switches and junk, and also the back of the hood.
BAJA SEARS BUILD - Page 5 Img_3341
Next I'll run a rod or piece of pipe from the top to the steering column. That should make a pretty rugged setup out of it. There won't be a whole lot of room to hide your wiring and starter solenoid under there, but I think it'll fit.
BAJA SEARS BUILD - Page 5 Img_3342
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 19th 2014, 6:26 pm
i saw flames Very Happy
rarbaugh07
rarbaugh07
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 19th 2014, 7:29 pm
That's intense= absolutely awesome
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 19th 2014, 7:41 pm
Best sounding single cylinder I've ever heard!
PostSubject: Re: BAJA SEARS BUILD   BAJA SEARS BUILD - Page 5 Icon_minitimeApril 19th 2014, 9:30 pm
Thanks, it came out better than I expected it to.
BAJA SEARS BUILD
Page 5 of 14Go to page : Previous  1, 2, 3, 4, 5, 6 ... 9 ... 14  Next
» Baja sears suburban
» Baja Mini Bike Build
» Sears Build
» Hutch's Sears LT-10 Build
» Sears Hot Rod Gasser Build
