| engine will not run right | |
+5Doc Sprocket 1997 Murray TheBeal bbuckler murrey and me 9 posters | Author | Message |
murrey and me New Member
Age : 24 Join date : 2013-06-02 Points : 4206 Posts : 7
| Subject: engine will not run right December 30th 2013, 7:30 am | |
| hello i have a 12.5 Briggs and Stratton that will not run right it will not idle and it smokes like crazy out of the exhaust. Another thing that it dose run perfect with out the air-filter. So please help thanks.
| | | bbuckler Member
Age : 32 Join date : 2013-12-07 Points : 4074 Posts : 58 Location : Killeen,Tx
| | | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5714 Posts : 1402 Location : Central PA
| | | | 1997 Murray Veteran Member
| Subject: engine will not run right December 30th 2013, 11:37 am | |
| the carb may be suspect. if it is smoking it may also have bad rings, or the muffler may have oil in it. | |
| | | Doc Sprocket Site VIP
| Subject: Re: engine will not run right December 30th 2013, 11:52 am | |
| Before taking any other steps- verify oil is correct type, filled to correct level, and uncontaminated. | |
| Subject: Re: engine will not run right December 30th 2013, 11:53 am | |
| Could be rings, carb, too much oil could be causing the smoke, scored cylinder? But I would def start checking oil and a thorough carb cleaning. | |
Age : 57 Join date : 2013-12-21 Points : 4802 Posts : 744 Location : Salem Illinois
| Subject: Re: engine will not run right December 30th 2013, 1:43 pm | |
| It's common to find engines with too much oil in 'em. I had a neighbor bring me one complaining of the same symptoms... they had filled the oil to the top of the filler nech... It was amazing that the crap wasn't hydro locking the piston in the up position. I drained most of it out, and ran it till the oil that had leaked into the muffler burnt out. Took of the head, cleaned the top of the piston and combustion chamber, bolted her up and it ran fine. Told the ladies to let ME service the oil from then on.
First stop in checking running issues is air filter, fluid levels, carb, and spark plug. | |
| | | simplicity14twin Member
Age : 26 Join date : 2014-01-13 Points : 4111 Posts : 112 Location : New Hampshire
| | | | the54 Member
Age : 30 Join date : 2014-01-12 Points : 4023 Posts : 51 Location : Ontario Canada
| | | | Sponsored content
| Who is online? | In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests
