 ELIMINATE your head gasket!
TroyBilt Pony
11 posters
Go to page : Previous  1, 2
ELIMINATE your head gasket!  - Page 2 Empty
PostSubject: Re: ELIMINATE your head gasket!    ELIMINATE your head gasket!  - Page 2 Icon_minitimeDecember 2nd 2013, 6:10 pm
Yeah- the accepted school of thought is that you want the intake tract "rough" on a near-microscopic level. A slight bit of turbulence in the charge helps mix it better, and the flow will "drag" on a super-polished surface.
Having the port too large will cost you velocity too- so I was careful not to enlarge it, just smooth out the restrictions.
GenevaCustoms
GenevaCustoms
PostSubject: Re: ELIMINATE your head gasket!    ELIMINATE your head gasket!  - Page 2 Icon_minitimeDecember 2nd 2013, 6:33 pm
Makes sense, and the Venturi effect of the actual intake port on the head does to, just as a carburetor uses Venturi to increase airflow speed so does this. It doesn't change the actual intake manifold so say you wanted to try it on you vehicle... You'd have to get new heads (probably valve train and such) not the intake manifold, and Doc, I was going to port/polish my intake manifold on the Deere tell me how it turns out for you
PostSubject: Re: ELIMINATE your head gasket!    ELIMINATE your head gasket!  - Page 2 Icon_minitimeDecember 2nd 2013, 6:54 pm
Oh, I will definitely keep this updated.
» B&S Head Gasket Question
» head gasket help needed
» Hacksaw head job
» TRANSAXLE SEALS AND GASKET IDEAS
» Using a digital camera to find bad spots in a gasket
