| TRANSAXLE SEALS AND GASKET IDEAS | |
mowerheadder New Member
Join date : 2016-04-28 Points : 3156 Posts : 20 Location : New Jersey
| Subject: TRANSAXLE SEALS AND GASKET IDEAS June 7th 2016, 5:40 pm | |
| Howdy folks, quick question, I have a Foote transaxle and I'm gonna run oil in her, she just mows the lawn so its gonna be my oil tranny conversion guinea pig. Now the seals right where the axle shafts come out are not gonna hold up. And being that getting OEM tranny seals is $$ I was wondering if anyone knows which type/where I could get gaskets that would withstand the constant movement of the axle shafts on the rubber. I can find the size of the gasket and I've tried searching online for high wear resistance gaskets but no luck. Thanks guys | |
| | | Rockinator Member
Age : 23 Join date : 2016-01-16 Points : 3406 Posts : 164 Location : Canada
| Subject: Re: TRANSAXLE SEALS AND GASKET IDEAS June 7th 2016, 5:56 pm | |
| Im not sure where you could find seals that size, i would try a shop that specializes in rear ends transmissions etc. And ask about what kind of gaskets to use. As far as gasket sealer goes, go with either ultra black (maximum oil resistance) or ultra copper (high heat resistance along with oil resistance, i use it for exhaust gaskets and carb gaskets) but i wouldnt recommend ultra copper unless you plan on making your mower really go. | |
| | | Off Road Domination Member
2016 Build-Off Finalist
Age : 22 Join date : 2016-02-17 Points : 3279 Posts : 74
| Subject: Re: TRANSAXLE SEALS AND GASKET IDEAS June 7th 2016, 9:00 pm | |
| you will probably have to get the OEM ones because nothing else will work I just took my transaxle out of one of my tractors and it wasnt worth changing the seals so I just put the transaxle back in but im not sure how you would do that | |
| Subject: Re: TRANSAXLE SEALS AND GASKET IDEAS June 8th 2016, 4:03 pm | |
| Yeah i could probably find an oem sub. BUT it'll probably be a pain. I know the size and stuff, I did find a lace that sells to the public but their seals are too thick. Im thinking maybe an O-ring? What do yall thing of that? | |
| Who is online? | In total there are 51 users online :: 0 Registered, 0 Hidden and 51 Guests
