 Unknown oil leak
Thecrazyoldcraftman
8 posters
Thecrazyoldcraftman
Thecrazyoldcraftman
Unknown oil leak Empty
PostSubject: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 11:06 am
I recently have been running my tractor alot more than usual and i checked the oil when I got home I checked the oil and it was completely empty. I Had recently changed my oil so I checked my plug and everything was tight. No oil leaks around the motor. It doesn't burn any oil so the fact the it was empty is puzzling me. it is a older 11 horse briggs flathead. any idea on what it can be? Thanks
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 11:07 am
Is you want to pull the head and/or compression test it.
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 11:16 am
I would be betting its the bottom main seal.
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 11:30 am
Well- it had to go somewhere. Either leaking, burning, or both. So-
Top it up, take it for a good ride to get everything nicely warmed up, and park with the engine over a sheet of cardboard for several hours. Even let it run over the cardboard for 20 or 30 minutes, then leave it there overnight.
If it ain't leaking, it's burning. What grade of oil are you using?
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 3:41 pm
Prob around bottom crank bearing.. Could be something as small as the governor.. Is it smoking? Oil can be sent into your carb and burned through your sump tank and you barely know it.
Thecrazyoldcraftman
Thecrazyoldcraftman
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 7:21 pm
as far as I know it isn't burning so ill have to check the the seal. I used 10w 30.
xxXMowerdudeXxx
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 10:50 pm
Bottom crank seal, or ur carb is floating geting into oil making it look like nothing in it
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 11:00 pm
Please tell how you carb float could effect your oill.. im quiet interested.. if its running.. his carb isnt that high..
xxXMowerdudeXxx
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 11:39 pm
I had a 10hp briiggs dipstick ddint look like it had anything on it, pulled the drain plug i got over half a gallon of oil and fuel mix out...
Thecrazyoldcraftman
Thecrazyoldcraftman
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 20th 2013, 11:53 pm
hmm I did just rebuild the carb I will need to check that as well.
crazykid1994
crazykid1994
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 1:53 pm
my 17.5 i think has a slight leak in the bottom seal... so who knows
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 3:12 pm
Check the blowby and the dipstick my 12.5 has a leak on bottom also tighten the the oil drain
http://www.lastdropgarage.com
Thecrazyoldcraftman
Thecrazyoldcraftman
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 4:17 pm
ok so I checked the seal and nothing. my thoughts are since it is an older motor (1986) and I have been running it so much that I may be burning oil in small amounts to where it is not visible but still, a whole quart in just a month??
crazykid1994
crazykid1994
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 4:20 pm
might be getting past the piston rings. try pulling it aparts and making sure the rings are still good and the openings on the rings dont line up
xxXMowerdudeXxx
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 8:42 pm
dude a quart a months not that bad, i have a 12.5 that burns that in 3weeks, and i rarely see smoke, only comming off a high rev sometimes, or steep hills
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 9:01 pm
The fact that it's older is certainly a contributing factor. Now- the reason I asked what grade oil you were using is because many factory owners manuals DO state that while 10W30 is preferable under certain temperature conditions, oil consumption will likely increase compared to the usually specified SAE30.
Top it up, and keep a closer eye on it.
Thecrazyoldcraftman
Thecrazyoldcraftman
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 9:04 pm
I know it isn't That bad but I had the old oil in there for over 4 months and had the same amount in there when I dumped it so jumping from very little to no oil burn to a quart a month right after an iil change is a bit odd I believe.
Thecrazyoldcraftman
Thecrazyoldcraftman
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 21st 2013, 9:31 pm
what temperature conditions does it say to use 10w30?
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 22nd 2013, 7:29 am
Torn from the page of the Briggs flatty single manual:
"Air cooled engines run hotter than automotive engines. Use of non-synthetic multi-viscosity oils (10W-30, ect) in ambient temperatures above 40F (4C) will result in high oil consuption. If multi-viscosity oil is used, check oil level more frequently to prevent engine damage due to lack of lubrication.
SAE30 oil, if used below 40F (4), will result in hard starting and possible engine damage due to inadequate lubrication."
Thecrazyoldcraftman
Thecrazyoldcraftman
PostSubject: Re: Unknown oil leak   Unknown oil leak Icon_minitimeSeptember 22nd 2013, 10:01 am
oh well due to the fact I only use this in warm temps this might be the issue.
Unknown oil leak
» Sarge's first run after oil leak
» Help, small gas tank leak
» Briggs 12HP Compression Leak?
» Unknown oil plug question
» unknown Murray 18hp
