| What to do when you brake a bolt off in aluminum? | |
Guest Guest
| | | | Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5462 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: What to do when you brake a bolt off in aluminum? September 8th 2010, 5:48 pm | |
| I learned my lesson many times.... If a bolt is remotely stubborn, use some heat. I've broke soooooooo many bolts in bad places and on other people's vehicles lol. But yeah the welding technique is my favorite way. Good luck if you can try it! | |
| | | Guest Guest
| Subject: Re: What to do when you brake a bolt off in aluminum? September 9th 2010, 12:16 am | |
| - Ford Boi wrote:
- I learned my lesson many times.... If a bolt is remotely stubborn, use some heat. I've broke soooooooo many bolts in bad places and on other people's vehicles lol. But yeah the welding technique is my favorite way. Good luck if you can try it!
Yeah, i remember hearing the welding trick but never tried it, i will next time though. |
| | | Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6214 Posts : 779 Location : Angus, Scotland
Age : 54 Join date : 2010-02-10 Points : 7070 Posts : 1726 Location : Florida, USA
| Subject: Re: What to do when you brake a bolt off in aluminum? September 9th 2010, 8:38 am | |
| Now that Ford Boi mentioned the welding trick- that reminds me of what the ford dealer had to do on my 99 when the starter bolts broke- the mechanic welded a nut on the broken bolt ( what was left out) heated it up gently and removed it w/o wrecking it.
| | | Guest Guest
| | | | Webmaster Webmaster
Age : 14 Join date : 2010-02-09 Points : 5729 Posts : 332 Location : Here!
| Subject: Re: What to do when you brake a bolt off in aluminum? September 12th 2010, 7:49 am | |
| This happed to me. I broke off a head bolt when I wanted to do a valve job on my non i/c 12.5. It was what had come on the tractor originally. I tried to use an "easy out" to get it out, but that broke too. I got really pissed off and bought a new "used" 12.5 i/c from a shop near me. It was missing a carb and starter. I swapped everything over with all new gaskets and put in an ohv piston and connecting rod. Lots of porting, torquing, never seize and loc-tight... lol
But it's a tough little motor. The new block cost me $10. All the gaskets and other stuff cost another $15-$20. | |
| Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests
