| 5 bolt wheel hub help | |
D.U.B.S. New Member
Age : 28 Join date : 2013-03-19 Points : 4306 Posts : 22 Location : Central N.H.
| Subject: 5 bolt wheel hub help July 30th 2013, 2:36 pm | |
| Hi, I am looking for a 5" on 5.5" wheel hubs that will fit on a 1 or 1 1/4" axle. I know that older tractors have wheel hubs that are 5 bolt, (wheelhorse etc.) but I do not know if one is made with the specs listed above. Can someone help me? I am looking to build a monster mower, with an axle like a go kart, and I cannot find a wheel hub that I need. Thanks, D | |
| | | dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4812 Posts : 141 Location : central Wisconsin
| Subject: Re: 5 bolt wheel hub help July 31st 2013, 11:21 am | |
| The older tractors with 5 bolt hubs are 4 1/2 inch circle. If you have to have 5 1/2 inch you will have to make your own. | |
Age : 23 Join date : 2013-04-08 Points : 5213 Posts : 913 Location : Central Pa
| Subject: Re: 5 bolt wheel hub help July 31st 2013, 11:28 am | |
| I would check BMIKARTS.com because they have hubs sorta like that. | |
Join date : 2013-06-01 Points : 4814 Posts : 578 Location : West Virginia
| Subject: Re: 5 bolt wheel hub help July 31st 2013, 12:08 pm | |
| Make your own.. just use a set of old stock wheels then cut a circle out of the center out of it and drill your bolt holes.. Very simple.. then tack weld some sturdy bolts in it and use sturdy nuts as lugs or actually lugs but if you use regular lugs, be sure lock tight.. | |
| | | D.U.B.S. New Member
| Subject: Re: 5 bolt wheel hub help July 31st 2013, 4:54 pm | |
| Thanks, i did not want to hear that, but I guess that is what I have to do. | |
| | | dked41 Member
| Subject: Re: 5 bolt wheel hub help August 1st 2013, 12:23 pm | |
| You can always go with the 4 1/2 inch setup, hubs are easier to come up with. | |
| | | MowKartEnvy New Member
| Subject: Re: 5 bolt wheel hub help November 6th 2013, 5:19 pm | |
| Finally something I can add some $.02 to. I took the rear brake drums from a Ford F150(5x5.5"),cut the center circle out and welded some 5x4.5" GT hubs to it. Worked out great! | |
