| Does any one know how to make 4 bolt hubs for 1 inch axle? | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| | | | Chunk Established Member
| Subject: Re: Does any one know how to make 4 bolt hubs for 1 inch axle? May 18th 2010, 3:13 pm | |
| Cant be hard to make. All you;d need a some 1" ID tube wit a key way. Then a fairly thick circle of metal, with 4 bolt holes, and on the in the centre for the tubing to go through. Getting it centred is the tricky part though! | |
| Subject: Re: Does any one know how to make 4 bolt hubs for 1 inch axle? May 18th 2010, 4:59 pm | |
| Shouldnt be too hard - like Chunk suggested - flat piece of 3/8 - 1/4" steel , some wheel studs, piece of thick wall black pipe , might be easier to cut a strip out of the pipe to put a steel keyway to weld in. Finding center wouldnt be too hard - draw some straight lines across the hub, center the pipe and draw a circle around it, use a metal hole saw a lil bit smaller for a tight fit.
I bot a couple 5 bolt hubs for 1" ( fit most atv/golf kart wheels) - the rear ones were $35 each - the front tapered bering hubs were $45 each. | |
| | | arild365 Member
Age : 29 Join date : 2010-02-11 Points : 5810 Posts : 320 Location : Canada, BC
| Subject: Re: Does any one know how to make 4 bolt hubs for 1 inch axle? May 18th 2010, 6:41 pm | |
| i got mine made for TORQUE. i just found old lil lawn tractor hubs and used the pipe with the key way ( cause i couldnt find any keyd pipe) and made some plates for the tires and got them welded on. il do a vid on it soon. Olny costed me 20 bucks | |
| Who is online? | In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests
