| pulley swap a vari-drive? | |
Jerbear0612 Member
Age : 28 Join date : 2013-04-23 Points : 4340 Posts : 89 Location : Salem ct
| Subject: pulley swap a vari-drive? August 23rd 2013, 11:37 am | |
| Hey guys just wanting some reassurance before I mess anything up. Can you pulley swap the transaxle pulley on mtd's vari-drive setup? Will the vari-drive still function properly will a pulley swapped transaxle? thanks | |
| | | | Creepycrawler Established Member
Age : 37 Join date : 2013-07-02 Points : 5016 Posts : 731 Location : Logan Ohio
| Subject: Re: pulley swap a vari-drive? August 24th 2013, 3:34 pm | |
| get a 6 or 7 inch front pulley, leave the rear pulley alone, make sure you buy a new front belt that is at least 5/8 wide, 11/16 is better due to the action of the vari-drive. I had one I swapped, it worked well, key thing is the belt width, 1/2 belts dont work for poopie.
| | | Doug Site Owner
| Subject: Re: pulley swap a vari-drive? August 24th 2013, 4:48 pm | |
| - Creepycrawler wrote:
- get a 6 or 7 inch front pulley, leave the rear pulley alone, make sure you buy a new front belt that is at least 5/8 wide, 11/16 is better due to the action of the vari-drive. I had one I swapped, it worked well, key thing is the belt width, 1/2 belts dont work for poopie.
Truth. 5/8 works great, its what mine had, but if you run 1/2" belts you will be changing them all the time. When I pulley swapped mine for convenience I went with a 1/2" rear pulley instead of a 5/8 like I should have and I probably spent as much on belts as it would have cost me to buy a 5/8 pulley. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
