| | Throttle body piece broke. | |
+3TheRainbowBoxer crazykid1994 Caleb10123 7 posters | Author | Message |
Caleb10123 Member
![Caleb10123](https://2img.net/u/2812/37/66/46/avatars/1047-85.jpg)
Age : 29 Join date : 2013-07-31 Points : 4190 Posts : 104 Location : Georgia
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | Subject: Throttle body piece broke. August 20th 2013, 12:17 pm | |
| Can anyone tell me if i can replace the white plastic fitting for the throttle cable or do i hav to buy a whole new throttle body? ![Throttle body piece broke. Img_2015](https://i.servimg.com/u/f74/18/45/06/74/img_2015.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | crazykid1994 Established Member
![crazykid1994](https://2img.net/u/2812/37/66/46/avatars/750-21.jpg)
Age : 29 Join date : 2013-03-18 Points : 4851 Posts : 618 Location : loxahatchee, florida
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | Subject: Re: Throttle body piece broke. August 20th 2013, 12:56 pm | |
| super glue or epoxy works wonders. lol. or drill a hole in the middle of it and bend the throttle cable into the hole and than use the epoxy or glue. thats stronger | |
| ![Go down](https://2img.net/i/empty.gif) | | Caleb10123 Member
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | crazykid1994 Established Member
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | Subject: Re: Throttle body piece broke. August 20th 2013, 1:11 pm | |
| i have a gas pedal and i modified the stock cable to work. so i would probably try and make it work first before finding a new plastic piece but that is up to you. i like having a challenge | |
| ![Go down](https://2img.net/i/empty.gif) | | TheRainbowBoxer Moderator
![TheRainbowBoxer](https://2img.net/u/2812/37/66/46/avatars/326-23.jpg)
Age : 49 Join date : 2012-04-23 Points : 5627 Posts : 1091 Location : Galion, OH
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | Subject: Re: Throttle body piece broke. August 20th 2013, 1:47 pm | |
| Funny thing about opinions... We all have them. I would not just bypass the governor. Use it, or pull it.
I think it would be dead simple to drill a hole thru the plastic slide, and fit a screw in it. Put an eyelet on the throttle cable and attach. Or, if you're handy with the needlenose pliers, bend an eye in the cable and attach directly. | |
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | Subject: Re: Throttle body piece broke. August 20th 2013, 2:11 pm | |
| I figure by contradicting Doc, I have just sentenced myself to a Karma induced governor internals failure... but for what it's worth... we (Stretch and I) have never gone spelunking in the engine case to remove the internals after bypassing the governor, and we have not had one fail yet...
pardon me...
*Furiously knocking on wood*. | |
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | Subject: Re: Throttle body piece broke. August 20th 2013, 2:27 pm | |
| - TheRainbowBoxer wrote:
- I figure by contradicting Doc, I have just sentenced myself to a Karma induced governor internals failure... but for what it's worth... we (Stretch and I) have never gone spelunking in the engine case to remove the internals after bypassing the governor, and we have not had one fail yet...
pardon me...
*Furiously knocking on wood*. That's funny right there, I don't care who you are! LMAO Hey- Sometimes you're lucky, sometimes you're not. You may notice in my article that I emphasize 2 things. 1)Nothing is entirely predictable. Might happen, might not. 2)More likely in SOME engines than others due to design and construction. Give the wood a couple hits for me, too. | |
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | Subject: Re: Throttle body piece broke. August 21st 2013, 8:48 am | |
| i dont want to bypass the governor just because of that so i think im going to drill a hole and run my brake cable through and i have an end piece to the cable to hold it in place and put a return spring and hopefullly it will work! | |
| ![Go down](https://2img.net/i/empty.gif) | | willis923 Veteran Member
![willis923](https://2img.net/u/2812/37/66/46/avatars/835-97.jpg)
Age : 27 Join date : 2013-04-10 Points : 5687 Posts : 1408 Location : Galway NY
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Angchor Member
![Angchor](https://2img.net/u/2812/37/66/46/avatars/1672-45.jpg)
Age : 67 Join date : 2014-04-14 Points : 4345 Posts : 491 Location : Index, Washington
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Khal03 Member
![Khal03](https://2img.net/u/2812/37/66/46/avatars/1707-51.jpg)
Join date : 2014-04-29 Points : 3825 Posts : 36 Location : Iowa
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![Throttle body piece broke. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Throttle body piece broke. | |
| Who is online? | In total there are 124 users online :: 0 Registered, 0 Hidden and 124 Guests
