| Briggs and Straton Starters | |
+3FOSWMT k2500life Murray modder 7 posters |
Murray modder Member
Join date : 2012-11-23 Points : 4795 Posts : 356 Location : Somewher in Va
| Subject: Briggs and Straton Starters August 15th 2013, 8:44 pm | |
| Are all of the Starters Briggs uses on their engines the same? Mounting wise? I know the Opposed twins have their own way of mounting, but It seems the other two Briggs I've had used the same mounting pattern. Is this true for every one? | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5365 Posts : 1135 Location : Southern Florida
FOSWMT Member
| Subject: Re: Briggs and Straton Starters September 24th 2013, 4:25 pm | |
| - k2500life wrote:
- Yes they all mount the same except the oppys and some teeth might be different
What teatrh combinations are there please how do you know if what you bought matches what you should have how do you adjust what you have to make it work please? | |
BlackMountian88 Member
Age : 25 Join date : 2012-09-08 Points : 4887 Posts : 399 Location : NH
| Subject: Re: Briggs and Straton Starters September 24th 2013, 5:04 pm | |
| I don't think there are different teeth combinations...
I've switched starters many times with no problems. | |
FOSWMT Member
| Subject: Re: Briggs and Straton Starters September 24th 2013, 5:09 pm | |
| - BlackMountian88 wrote:
- I don't think there are different teeth combinations...
I've switched starters many times with no problems. Do you think I just need to insert a washer behind the bracket then? | |
FOSWMT Member
| Subject: Re: Briggs and Straton Starters September 25th 2013, 10:14 am | |
| Have my starter working turning over with the insertion of two thin washers. I have also noticed some aluminum shards coming off this seems to have stopped. Is this normal? | |
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5015 Posts : 232 Location : fairhope Al.
| Subject: Re: Briggs and Straton Starters September 25th 2013, 1:00 pm | |
| - FOSWMT wrote:
- Have my starter working turning over with the insertion of two thin washers. I have also noticed some aluminum shards coming off this seems to have stopped. Is this normal?
What i think your describing is the starter gear is stripping out. It may be stripping out because the washers on it are making the gear to far away from the fly wheel. Did the motor the old starter came off of have the washers? Did the motor your running them on have them? | |
FOSWMT Member
| Subject: Re: Briggs and Straton Starters September 25th 2013, 1:21 pm | |
| - cumminsbayou wrote:
What i think your describing is the starter gear is stripping out. It may be stripping out because the washers on it are making the gear to far away from the fly wheel. Did the motor the old starter came off of have the washers? Did the motor your running them on have them? It jammed up after i put it in without. I think it has settled down I have posted a video here: https://www.atltf.com/t2704-wiring-up-a-modern-key-switch | |
cumminsbayou Member
| Subject: Re: Briggs and Straton Starters September 25th 2013, 1:34 pm | |
What i think your describing is the starter gear is stripping out. It may be stripping out because the washers on it are making the gear to far away from the fly wheel. Did the motor the old starter came off of have the washers? Did the motor your running them on have them? It jammed up after i put it in without. I think it has settled down I have posted a video here: https://www.atltf.com/t2704-wiring-up-a-modern-key-switch May be the gear isn't the right one? I'm not sure but if the old motor didn't have the washers i would run them | |
FOSWMT Member
| Subject: Re: Briggs and Straton Starters September 27th 2013, 8:28 am | |
| Am really hacked off now. I cant find a replacement gear or flywheel in the UK second hand as this part is £200. I joined this group support forum to get support not to get laughed at when things go wrong. Now I have a redundant motor just because someone didn't bother to tell me to check the flywheel to see if it was aluminum. I even posted pictures of my gearing and no one said this would destroy the gears. | |
Doc Sprocket Site VIP
| Subject: Re: Briggs and Straton Starters September 27th 2013, 9:50 am | |
| I understand your frustration, but you have to understand that if no one here has come across your problem before, they simply won't have your answer. I myself am not aware of differing tooth pitches. As far as ring gear/pinion gear materials go, aluminum/steel/nylon/whatever will no matter IF the gears are meshing properly.
I should probably point out that you are a member of a forum populated largely by young backyards bashers, not old mechanics. Nothing really wrong with that, but do keep it in mind. Many of these folks have yet to learn the tricks of the trade- and learn they will- but you gotta start somewhere. | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5695 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Briggs and Straton Starters September 27th 2013, 11:12 am | |
| I mentioned before in another post, that I had a steel gear briggs starter, that had a different tooth count than plastic ones. No idea what it would fit, did not use the gear because of the different count. | |
