 Minor rusting in cylinder
akcender
8 posters
akcender
akcender
Minor rusting in cylinder Empty
PostSubject: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeJuly 28th 2013, 10:55 am
Just got a new tractor that had been left sitting outside for a while. The water made its way into the valves and a little bit in the combustion chamber. Because of this there are some rough spots towards the top of the cylinder near the head. So my question is: Do I need to tear it all down and hone it? Or do I just smooth it out with some Emory paper? I'll try to post a picture here soon.
akcender
akcender
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeJuly 28th 2013, 11:14 am
Here are some pictures of it.  You can definitely feel it with your fingers.
Minor rusting in cylinder XMYnXKR
Minor rusting in cylinder RPCIZuZ
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeJuly 28th 2013, 12:18 pm
That's beyond honing.
Needs bored, oversized piston and rings. I'd run it just like it is, until it blows, then find another engine.
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeJuly 28th 2013, 3:19 pm
Get it as smooth as possible and run as is till it blows up
http://www.lastdropgarage.com
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeJuly 28th 2013, 4:52 pm
Honing? Can't see the piston walls. But clean it with a scrape and sandpaper and do what stretch suggested. You'll be good for some years.
crafsmankiller
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeJuly 29th 2013, 1:45 pm
My go kart motor is worse than that.
Been running it for years without problems
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeAugust 2nd 2013, 5:50 pm
At this point, you could probably try to clean it up some with a small plain (2") wire wheel. Go pretty easy on it, you don't want to score the bejeezus outta the cylinder wall. The idea here is to take off the rust that protrudes from the surface, to minimize ring damage and hopefully improve sealing. This will leave pitting in the cylinder wall- but all things being equal, it's much better than chunks sticking out of the wall. You could very well get years of service out of it like this, with minimal compression loss, and/or smoke.
Chopperhed
Chopperhed
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeAugust 2nd 2013, 7:15 pm
As Doc said, clean it up and run it.
My self being who I am, I would blast a quick hone through it to knock the high spots down, scuff the rings to take the glaze off, run a shortened break in, and it would likely last a decade
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeAugust 2nd 2013, 9:02 pm
Good words, chopper- I'd give it a light honing too, but I didn't mention it because most folks don't have one, and overdoing it will make the situation worse.
Chopperhed
Chopperhed
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeAugust 2nd 2013, 9:52 pm
Well said and true
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeAugust 3rd 2013, 4:22 pm
Wouldnt a copper/ brass wheel be lighter on the walls? Versus steel.
Chopperhed
Chopperhed
PostSubject: Re: Minor rusting in cylinder   Minor rusting in cylinder Icon_minitimeAugust 3rd 2013, 8:08 pm
Anything softer than the cylinder wall would be good.
brass, fine stainless, composite.
Trick is to be gentle.
I've used a long piece pf 1/4" steel rod, with a slot in the end to old 2 pieces of 80 grit emery cloth back to back, mount it in a die grinder and go.
»  What do you use to protect Magneto and flywheel stators from rusting all overe again ?
» 4 cylinder go kart
» 17.5 hp briggs single cylinder
» Homemade tools and stuff from junk laying around
» Best performance mods for a 20hp single cylinder briggs ic
