 Valve Lapping?
BlackMountian88
BlackMountian88
Valve Lapping?  Empty
PostSubject: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 2:29 pm
So I have reason to believe I burned up my 12hp B&S's valves. How do I go about lapping them by hand (no tool)? I measured, I've got .070 on intake, and 0 on exhaust.
Thanks!
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 5:48 pm
What precisely do you mean with those number?
Get yourself a lapping tool, they're cheap. It's basically a suction cup on a wooden stick. You might be able to improvise one. You will also need lapping compound.
What precisely appears to be the damage to the valves/why do you believe they are damaged.
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 5:54 pm
Is that the amount of valve lash(clearance) you have? Sounds off, did you measure it with the piston on top of the compression stroke?
If so, you need to grind the end of the exhaust valve to gain clearance. I don't have the book right now, but I'm sure somebody here has the correct numbers. That may be all it needs to run.
To lap valves, take the springs and keepers off the valves. You need to have clearance on both valves so they don't bottom out on the lifters.
I'm not sure where you would buy lapping compound, I have some left over from work. Probably want a fine compound. Mix it with some motor oil, till you have a paste. Put this on the valve seat, insert valve, hold it against the seat, and spin. Looking for a shiny ring all the way around the valve and valve seat when done.
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 5:55 pm
The tool doc mentioned makes it much easier, but you can do it without a tool. Just a pain to spin the valve.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 6:06 pm
Shoot, I want thinking of compound. I just spent my last $4 so I'm definitely not getting a tool.
So the basic idea is to get the valve and the seat to seal perfectly? I had 85psi of compression.
Also Doc, I had been running a 4" straightpipe. Finally my engine started stalling out. I have a thread under B&S.
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 6:15 pm
In addition to stretch's good advice-
Be sure to thoroughly clean everything when done. Lapping compound is abrasive, and it probably goes without saying, but you don't want liquid sandpaper floating around your engine...
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 6:26 pm
Check valve lash first, before doing anything else. Do you own a set of feeler gauges? Give me your Model Type Code, and I'll give you the lash specs. Once you have successfully adjusted the lash, THEN perform a compression check. The reason for adjusting lash to spec first is because of the compression relief mechanism on the camshaft. ALSO-
With the compression relief in mind, you MAY get a false compression test result, as the machanism does it's job. For a TRUE read, spin the engine BACKWARDS and check. This defeats the mechanism.
That said, 85 PSI should allow the engine to run decently enough.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 7:32 pm
Ill get the specs for you in the morning. The lash is the space between valve and tappit, right?
Also I couldn't spin the motor backwards fast enough to get a reading. This is an older model (late 80's?) so does it have a compression relief?
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 8:38 pm
I don't need the specs- you do... lol
To spin the engine backwards, try wrapping a rope around the pulley or flywheel.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 5th 2013, 8:41 pm
ell I'll get the model number so we can find the specs. Razz that's nice with the really olf engines, my Kohler says the points gap and valve gap right on the side
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 5:49 am
Get a longer pipe on there bro. 4" Isnt enough unless you put an exhaust on. I would do 12" with at least 1 90" bend in it, and thats still pretty damn short.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 7:56 am
Yup, I learned that the hard way. Here's my model number Doc, If you could find the correct lash that'd be great. It's a B&S 281707
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 9:31 am
Intake- 0.005"-0.007"
Exhaust- 0.009"-0.011"
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 9:39 am
And that's the distance between the valve and tappit, right?
My feeler only goes to .015.
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 9:49 am
Let's back this train up a bit- Just to verify- is your engine an L-head, or an OHV? I think I might have pulled the wrong spec- Gimme a few minutes.
-0.015 is HUGE! You need a thinner gauge set if that's the smallest you've got.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 9:52 am
Yup, valve in block. An older model too. I'll see about the feeler gauge... Maybe I can borrow one.
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 9:53 am
That's what I thought. Okay- spec post edited.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 9:57 am
Alright, I'll be back in an hour to post my results!
Also if the valves do need to be adjusted, how do you do that? It's not like OHV where you just loosen a screw. Razz
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 10:01 am
If clearance is less than specified, grind end of valve stem to obtain proper clearance.
If clearance is too much, replace valve or cut valve seat to obtain proper clearance.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 11:06 am
*facepalm+ My gauge goes to .0015 not .015. Razz
Either way I have no clearance. I'll try to take them out and grind. I've never taken out an exhaust valve, just intake.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 1:32 pm
Doc, you got any tricks for keeping the valve springs compressed?
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 5:10 pm
Without a valve spring compressor, I have used everything from a couple screwdrivers to a big modified C-clamp.
BlackMountian88
BlackMountian88
PostSubject: Re: Valve Lapping?    Valve Lapping?  Icon_minitimeJuly 6th 2013, 5:11 pm
I'm working with screwdrivers. Smile Clamp is a good idea.
Valve Lapping?
» valve clearence
» Removing Valve Retainers
» plastic oil drain valve??? b&s v twin
» B&S Oppy Intake Valve Seals
» 16HP oppossed twin valve adjustment
