| | how complicated is this.. | |
![TroyBilt Pony](https://2img.net/u/2812/37/66/46/avatars/942-63.jpg)
Join date : 2013-06-01 Points : 4736 Posts : 578 Location : West Virginia
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: how complicated is this.. June 7th 2013, 9:52 pm | |
| Ive been thinking about putting a craftsman garden tractor axle in my troybilt pony.. (yes I used a 800 dollar mower for my mudder ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) ) anyhow I put a 12hp flathead in because the 17 had a cracked block But. anyhow this 5 speed has 1 inch axle so im assuming it will be tougher instead of 3/4.. I was thinkin of just keeping the varidrive so act ac as my clutch and leave it in 7th for max tension. Share your thoughts. Thanks. | |
| ![Go down](https://2img.net/i/empty.gif) | | richie thomas Veteran Member
![richie thomas](https://2img.net/u/2812/37/66/46/avatars/156-8.jpg)
Age : 29 Join date : 2011-08-04 Points : 6326 Posts : 1434 Location : east dublin georgia
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 7th 2013, 10:02 pm | |
| once you get everything lined up the hard part is over, and if you leave the vari drive the you could potentially have a 35 speed | |
| ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 7th 2013, 10:28 pm | |
| I hated my varidrive system. It works better for others I guess. I swapped for a 5 speed peerless and double clutch. the double pully vari drive doenst really have anything to do with tighter belts its how big the belt gets on that pully so it goes faster, like a syntrifical clutch | |
| ![Go down](https://2img.net/i/empty.gif) | | TroyBilt Pony Established Member
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 7th 2013, 10:33 pm | |
| I understad but my vari drive was modded for allot of belt tension but I want a granny gear aswell. My mtd has done ok even with oversize tires. Ive only burned belt. And the nice thing about mine being an 03 is parts support
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 7th 2013, 10:34 pm | |
| mines a 96 but I make everything so I don't need parts, its just what you want. Check it out if you havnt already
| ![Go down](https://2img.net/i/empty.gif) | | Doug Site Owner
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 8th 2013, 12:42 am | |
| I would put in the new transaxle (which is probably an 820, great axles), and ditch the vari drive for a standard 2 pulley clutch. From my experience I have had nothing but trouble with a vari drive, from belts hopping onto the other channel to them eating belts.
Plus it would end up making things a bit more complicated. Each gear would be split into 7 speeds. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 8th 2013, 12:46 am | |
| Yah but my ultimate goal is a granny gear which I was hoping to achoeve meanwhile upgradeing my axle | |
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 8th 2013, 1:38 am | |
| I think you should be set for a granny gear. Im running a 1:1 right now and my 1st gear on my 206 is still as slow as a snail. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | Subject: Re: how complicated is this.. June 8th 2013, 6:46 am | |
- the double pully vari drive doenst really have anything to do with tighter belts its how big the belt gets on that pully so it goes faster, like a syntrifical clutch
Actually, there's nothing centrifugal about it. The vari-drive system is akin to a CVT, or Continuously Variable Transmission, like you see in snowmobiles and some ATV's and golf carts. The difference is that a CVT is fully automatic, whereas the vari-drive requires you to select the ratios. And you're right- it's not a tension thing, it's a pulley-diameter thing. | |
![how complicated is this.. Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | how complicated is this.. | |
| Who is online? | In total there are 124 users online :: 0 Registered, 0 Hidden and 124 Guests
