| Cleaning out a rim. | |
+3Murray modder Doc Sprocket D.U.B.S. 7 posters | Author | Message |
D.U.B.S. New Member
Age : 28 Join date : 2013-03-19 Points : 4299 Posts : 22 Location : Central N.H.
| Subject: Cleaning out a rim. June 7th 2013, 6:43 pm | |
| I just got three front lawn mower rims from the dump They are filled with grease, and are dirty. Can I flush them out with water? Or will this prohibit them from working further? One of my mowers did not come with grease fittings, so I plan on using these. Thanks D | |
| | | Doc Sprocket Site VIP
| Subject: Re: Cleaning out a rim. June 7th 2013, 6:48 pm | |
| Water isnt very effective on grease. Try a degreaser or solvent. | |
| | | Murray modder Member
Join date : 2012-11-23 Points : 4798 Posts : 356 Location : Somewher in Va
| | | | Guest Guest
| | | | Doug Site Owner
| Subject: Re: Cleaning out a rim. June 7th 2013, 8:13 pm | |
| Gas/fuel / alcohol will work well to clean anything. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Hillbilly Homer Member
Join date : 2012-04-22 Points : 4837 Posts : 197 Location :
| Subject: Re: Cleaning out a rim. June 7th 2013, 9:43 pm | |
| As prometheus said diesel.
diesel won't evaporate like gas not as volatile and can filtered to be used over and over... | |
| | | truckin42 Veteran Member
| Subject: Re: Cleaning out a rim. June 7th 2013, 9:56 pm | |
| Also try karoseen it work good for cleaning up grease and things like that. | |
| Subject: Re: Cleaning out a rim. June 8th 2013, 6:54 am | |
| - truckin42 wrote:
- Also try karoseen it work good for cleaning up grease and things like that.
Kerosene works well, but ('round here anyway) can be pretty expensive. Since kerosene and diesel are VERY close in composition, you my save a bit using diesel. | |
| | | goesman Member
Age : 45 Join date : 2012-01-18 Points : 4850 Posts : 119 Location : Salem, Mo.
| Subject: Re: Cleaning out a rim. June 8th 2013, 12:05 pm | |
| Try regular charcoal lighter fluid or mineral spirits. It's the same stuff. I worked maintenance at a plant that made charcoal briquets and that is all we used for a degreaser. It's my first choice when I need toclean parts up. | |
| | | D.U.B.S. New Member
| Subject: Re: Cleaning out a rim. June 9th 2013, 5:49 pm | |
| Thanks, I see that the rim will still be able to work. I will give a few suggestions a try. | |
| Who is online? | In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
