| cant use a key to start tractor??? | |
+7MurrayMayhem MowBandit redneckcarrow Stretch44875 TheRainbowBoxer xxXMowerdudeXxx fletch6393 11 posters |
fletch6393 Member
Age : 28 Join date : 2013-05-15 Points : 4268 Posts : 48 Location : salt lake city utah
| Subject: cant use a key to start tractor??? May 15th 2013, 10:26 am | |
| in order to start my lawn tractor i have to put a screw driver accross two terminals (one of them leads to the starter). thats the only way i can get it to start. turning the key has no effevt. i put in a new ignition but it didnt do anything. the key has to be in the on position for the mower to start and when running the key will turn the mower off. i dont know what to do. will i have to completely rewire the mower?? | |
xxXMowerdudeXxx Established Member
fletch6393 Member
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
fletch6393 Member
| Subject: Re: cant use a key to start tractor??? May 15th 2013, 10:50 am | |
| ok i searched online and yes thats what im shoving a screwdrive accross. however, i pulled this engine from another mower wich had this problem and i pulled the all of the wiring harness ACEPPT for the solinoid out of the old mower and put it into another mower,(a craftsman) , using the craftsmans soliniod.( the engine in the craftsman was blown). now the craftsman has the starting problem wich leaves me here. idk??? | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5701 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: cant use a key to start tractor??? May 15th 2013, 11:17 am | |
| Solenoid needs to be bolted against clean metal so it has a ground. They it needs a 12 volt positive to the small wire to click, and send power through the larger wires to the starter. | |
fletch6393 Member
| Subject: Re: cant use a key to start tractor??? May 15th 2013, 11:23 am | |
| ok so all i did to the solinoid was take the wire off the starter for the old engine and then put it on the new engines starter. the solinoid is in its original stock position. | |
redneckcarrow Member
Age : 54 Join date : 2010-12-22 Points : 5124 Posts : 30 Location : maine
MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4749 Posts : 477 Location : Haddock,Georgia
| Subject: Re: cant use a key to start tractor??? May 16th 2013, 12:41 am | |
| lol ummmm did you check your fuse that is with the wiring harness it leads to the ignition switch and if its blown it wont turn the engine over but it will kill the engine because it still has a ground connector the fuse is only there to protect it from over voltage | |
fletch6393 Member
MowBandit Member
| Subject: Re: cant use a key to start tractor??? May 16th 2013, 3:29 pm | |
| lol ive done the same thing before replaced almost everything but that fuse then one day i just checked it and well it was popped | |
MurrayMayhem Member
Age : 25 Join date : 2013-01-03 Points : 4458 Posts : 99 Location : 820 Opposed Twin RD. AxleBreaker City
fletch6393 Member
vancrasher New Member
Age : 79 Join date : 2013-05-22 Points : 4217 Posts : 10 Location : Anglesey North Wales UK
| Subject: will not start with key May 22nd 2013, 3:36 pm | |
| I have a 1997 murray ride on mower, I too have the same same problem with not start on key but will if I put a spanner across the solenoid. and I have been trying to get a wiring diagram for it with much luck. It has a briggs & stratton 12.5hp engine with thease numbers on it, Modle 289707. type 0121-01. code 970307zB, and under ste seat it has the following murray inc, jackson, tennessee, 38301 usa. designationdu, type 40304x76, serno/ 732970871J05533 1997 prod code 730208. Can anyone help me with a wiring diagram or how to locat whats wrong. I was given the mower by a widow and I am not sure if the wiring is correct as there is all sorts of tape on it. I have put in a new solenoid and still nothing. I also don't think the seat switch is wired up properly. I have a rough idea on wiring on 1960 cars as I have restored a 1960 Morris !000. I live in Wales Great Britain. | |
MowBandit Member
| Subject: Re: cant use a key to start tractor??? May 22nd 2013, 4:21 pm | |
| - vancrasher wrote:
- I have a 1997 murray ride on mower, I too have the same same problem with not start on key but will if I put a spanner across the solenoid. and I have been trying to get a wiring diagram for it with much luck. It has a briggs & stratton 12.5hp engine with thease numbers on it, Modle 289707. type 0121-01. code 970307zB, and under ste seat it has the following murray inc, jackson, tennessee, 38301 usa. designationdu, type 40304x76, serno/ 732970871J05533 1997 prod code 730208. Can anyone help me with a wiring diagram or how to locat whats wrong. I was given the mower by a widow and I am not sure if the wiring is correct as there is all sorts of tape on it. I have put in a new solenoid and still nothing. I also don't think the seat switch is wired up properly. I have a rough idea on wiring on 1960 cars as I have restored a 1960 Morris !000. I live in Wales Great Britain.
check the fuse and make sure its not blown | |
MowBandit Member
| Subject: Re: cant use a key to start tractor??? May 22nd 2013, 5:01 pm | |
| - vancrasher wrote:
- already checked the fuse, that was the first thing i tried and its ok.
have you replaced the key switch? | |
| Subject: Re: cant use a key to start tractor??? May 22nd 2013, 5:29 pm | |
| There should be a ground wire, a kill wire (goes to motor) and a solinoid wire. Make shure they are all there and working. Talk to therainbowboxer, he is great with this stuff. | |
Doc Sprocket Site VIP
MowBandit Member
| Subject: Re: cant use a key to start tractor??? May 22nd 2013, 9:17 pm | |
| - Doc Sprocket wrote:
- Here is a fairly typical wiring diagram. Should give you a starting point.
thats very helpful now i understand how my stator hooks up lol | |
the beast Member
Age : 25 Join date : 2013-04-25 Points : 4308 Posts : 59 Location : Rio Rancho, NM AKA "The Catbox"
