 Is it a good idea to put a pull start on a tractor?
canadianromper
canadianromper
Is it a good idea to put a pull start on a tractor? Empty
PostSubject: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 4th 2012, 7:01 pm
i was wondering if it was maybe a good idea to have a pull start on my tractor, so if my battery dies i can just pull start it. let me know if its a good idea
Crazymudder
Crazymudder
PostSubject: Re: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 4th 2012, 8:51 pm
Yah thats a Great idea i actually have one one mine it doesn't have a a recoil its a pull rope pretty simple let me know if you want pics
gearheadmike
gearheadmike
PostSubject: Re: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 4th 2012, 11:52 pm
i got my old sears with a rewind on it and its a electric too im taking int off but going to use it on another project i think its a great idea to have
canadianromper
canadianromper
PostSubject: Re: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 5th 2012, 6:53 pm
yeah please if you can. and what is better weld it on or just bolt it on i was thinking about it and im not shure
Crazymudder
Crazymudder
PostSubject: Re: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 5th 2012, 8:35 pm
I Pretty much just bolted mine on and Took off the leaf guard i didn't weld, simply because i was to young to weld yet so I put the pull start on when i was ten.Also Wouldn't weld because once you weld it is never going to be the same but maybe welding would work better.
Crazymudder
Crazymudder
PostSubject: Re: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 5th 2012, 8:37 pm
I'll make a video tomorrow if thats alright with you affraid
canadianromper
canadianromper
PostSubject: Re: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 5th 2012, 9:01 pm
thanks. yeah i might just bolt it on bc the only welder that is close that i wont have to trailer my tractor is my pappa and its not really worth it to drive up there just for a weld that will take maby five minutes. only problem is the bolts that hold on the cover over the flyweel fans are striped and i dont really want to cut it off bc i dont want to cut the fans.
Crazymudder
Crazymudder
PostSubject: Re: Is it a good idea to put a pull start on a tractor?   Is it a good idea to put a pull start on a tractor? Icon_minitimeMarch 8th 2012, 7:51 pm
Maybe heat it up really hot since metal expands when it hot so heat it up. Hopefully its just the nut and buy a new nut but if its the bolt threads maybe rethread it
» Anybody have a good idea on mounting gopro to tractor?
» Block heater...good idea, bad idea, just plum stupid?
» Pull/Recoil starter on 14.5 hp briggs and stratton?
» How to Build a Pull Start!
» PULL START/DITCH BATTERY?
