| mini chopper | |
+5motorizedeverything Ariens YT11 Doug Doc Sprocket richie thomas 9 posters |
richie thomas Veteran Member
| Subject: Re: mini chopper May 10th 2013, 11:38 pm | |
| i had thought of doing that, however, the carb that is on it doesn't have seperate controls for the choke and throttle, so i want one that does, and i just dont want the ugly tank there lol | |
Age : 29 Join date : 2011-08-04 Points : 6377 Posts : 1434 Location : east dublin georgia
| Subject: Re: mini chopper May 10th 2013, 11:40 pm | |
| these are the numbers i got off the motor model# 135212 type 000602 code 93101107 | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7295 Posts : 2914 Location : Ontario Canada
| Subject: Re: mini chopper May 11th 2013, 8:38 am | |
| Yup- 5hp Briggs horizontal, 1993 model year.
Can you not seperate the throttle from the choke?
Personally, I hate the Briggs pulsejet carb-on-tank arrangement. If I were you, I'd probably grab an old pre-EPA Tecumseh Series 1 carb off an H40, H50, or H60. Pretty common, and fully adjustable including the main jet. Makes dialling it in for a new engine pretty painless.
My second choice would be a carb off a Honda GX160 or GX200 and build a manifold to adapt it. A chinese clone carb for these engines is common as mud, cheap, and easy to get parts for.
Keep in mind that if you go to a non-factory carb, you will lose governor function. IMHO, you're then obliged to open up the engine and remove the governor guts. No big deal, really.
EDIT- I just noticed my user title... Funny as hell... LOL | |
| Subject: Re: mini chopper May 11th 2013, 1:29 pm | |
| i got to looking through my junk yard, and found another briggs, its on a tiller, but missing the shroud. the carb on it is not attached to the fuel tank, and it has seperate throttle and choke, will it work?
| Subject: Re: mini chopper May 11th 2013, 9:02 pm | |
| - richie thomas wrote:
- i got to looking through my junk yard, and found another briggs, its on a tiller, but missing the shroud. the carb on it is not attached to the fuel tank, and it has seperate throttle and choke, will it work?
Depends- If the engine it came off was similarly sized (within a couple of hp), it's a good start. You may have to buy or build a manifold to adapt it. You quite likely will have to rejet. | |
| Subject: Re: mini chopper May 11th 2013, 9:06 pm | |
| well, i got to looking and i has a hole in the side of it,..... i have one on a 12 hp teccy that will bolt up to it tho lol | |
| Subject: Re: mini chopper May 11th 2013, 9:30 pm | |
| Odds are good that the carb off the 12hp won't work. The venturi is likely too large, which causes a loss of intake velocity and will not draw enough fuel. | |
| Subject: Re: mini chopper May 11th 2013, 10:25 pm | |
| darn , well ill keep searching
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4678 Posts : 356
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7756 Posts : 3044 Location : Lebanon County, PA
| Subject: Re: mini chopper May 12th 2013, 8:28 pm | |
| You should do a flat olive green with black army markings. And tassels. Lots of tassels. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: mini chopper May 12th 2013, 8:56 pm | |
| Tassels on an Army-themed bike? | |
| Subject: Re: mini chopper May 12th 2013, 9:02 pm | |
| idk, im still thinking bout metallic colors, but aint completely sure, i think it would look good with leather tassels tho lol | |
| Subject: Re: mini chopper May 12th 2013, 11:22 pm | |
| small update, i made a trade for a briggs 8 hp carb
| Subject: Re: mini chopper May 15th 2013, 11:46 pm | |
| getting the metal to make the tunnel in the tank tomorrow, wont get to work on it till sunday tho -_-, and got the stock carb repaired so the motor is running now going to mount the motor plate sunday and im still trying to find a rear tire for it.....things i need to buy and/or fabricate 1.jack shaft, going to build this, 2 5/8's pillow blocks 3. metal(seems im always needing it lol) 4. a 1 1/2 in steel coupler with inside threads and a plug. 5. lots of welding wire | |
MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4726 Posts : 477 Location : Haddock,Georgia
| Subject: Re: mini chopper May 16th 2013, 1:10 am | |
| good luck on the 5/8's pillow block bearings i cant lift sarge till i buy 1 and im not paying $35.99 for that bearing and i wish welding wire last because im sick of having to buy a role everytime i run out lol i wonder if i could fit a 10lb roll in my welder i think lots of modding would be required | |
| Subject: Re: mini chopper May 16th 2013, 1:32 am | |
| i found em at tsc for 18, and surplus center has them for 8 lol, i might be about to get another welder soon tho | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5678 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: mini chopper May 16th 2013, 10:32 am | |
| - Jay_Rod wrote:
- good luck on the 5/8's pillow block bearings i cant lift sarge till i buy 1 and im not paying $35.99 for that bearing and i wish welding wire last because im sick of having to buy a role everytime i run out lol i wonder if i could fit a 10lb roll in my welder i think lots of modding would be required
I've got a small century welder, and another old small welder, both will take 10 pound spools. | |
MowBandit Member
| Subject: Re: mini chopper May 16th 2013, 3:46 pm | |
| lucky my welder only hold 4lb spools lol and richie i dont have a credit card so the only pillow block bearings i could find are at acehardware for $38 | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5480 Posts : 1070
| Subject: Re: mini chopper May 16th 2013, 9:28 pm | |
| My welder will only use 2lb spools. I can only get pillow blocks a Tsc. | |
| Subject: Re: mini chopper May 16th 2013, 9:43 pm | |
HOLY F***! 36 buck for a lousy 5/8" pillow block bearing??? You got a Tractor Supply nearby? | |
| mini chopper | |
