| Big wheel mini chopper | |
Trcustoms Member
Join date : 2010-09-19 Points : 5409 Posts : 225 Location : Bear,De USA
| Subject: Big wheel mini chopper October 14th 2010, 7:09 pm | |
| I don't know if any of you watched the video of my mini bike or not, but if so you know what it looks like. I added on to it again today, i cut the forks off and welding the forks off a 26" bicycle along with the wheel and welded them on.
It's fricken crazy, i would like to get a 20" bike wheel and tire cause the 26" is just a bit to much. | |
Trcustoms Member
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 15th 2010, 1:11 pm | |
| Well, i did some toher stuff to it. I don't think it's a mini chopper or mini anything anymore. | |
Guest Guest
| Subject: Re: Big wheel mini chopper October 15th 2010, 6:27 pm | |
| looking good man! did you bend the frame your self or was it stock like that? |
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 15th 2010, 7:44 pm | |
| - bigbleuboy wrote:
- looking good man! did you bend the frame your self or was it stock like that?
I bought the mini bike frame the way it is, but everything else i did. I will be able to make my own frames soon cause i'm buying a pipe bender probably next weekend. | |
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 15th 2010, 11:50 pm | |
| Update! I bought a 12" 3/4" shaft to make a jack shaft today on the computer. I'm running #41 to the jack shaft off the clutch and then from there it will all be bicycle chain and sproket going back to the wheel. I did a calculation on a go kart website and it should go around 70mph top speed. But i'll gear it down even lower. | |
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 19th 2010, 3:41 pm | |
| Update! I got the shaft today! My jack shaft is all made, it's got pillow block bearings.
All i need to get her going is two sprockets and some bicycle chain. | |
Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5468 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: Big wheel mini chopper October 19th 2010, 3:49 pm | |
| That's a hilarious rig!!!! have you been able to test-drive it yet ? | |
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 19th 2010, 4:44 pm | |
| - Ford Boi wrote:
- That's a hilarious rig!!!! have you been able to test-drive it yet ?
As i typed above. I will be able to drive it once i get the two sprokets and chain. | |
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 20th 2010, 2:39 pm | |
| Almost there! Just need one chain link and shes ready to test drive. Here's some pics of the jack shaft i made. | |
DICE464 Member
Age : 28 Join date : 2010-07-30 Points : 5361 Posts : 129
| Subject: Re: Big wheel mini chopper October 20th 2010, 7:18 pm | |
| i started a biuld like this but after awhile i got bored with the idea...its sitting in the one corner of my little shop | |
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 20th 2010, 7:21 pm | |
| I think i forgot to mention, the bicycle shifter will be hooked up so it will have five gears. The engine is a modified honda gx-160. | |
Ford Boi Member
| Subject: Re: Big wheel mini chopper October 20th 2010, 9:10 pm | |
| I like that jack-shaft idea alot!! I just hope you have enough drive reduction for that motor to go! We had trouble on our bikes with reduction... Can't wait to see how your test-drive goes!!
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 23rd 2010, 10:42 pm | |
| I took her for her first ride today! It's like nothing i ever drove before.
I do have to gear it down though, it hardly takes off at all. | |
| Subject: Re: Big wheel mini chopper October 24th 2010, 1:52 pm | |
| I rode my bike once years ago over 40mph - and w/o a motor...... i was going down a super steep hill going to a park at the bottom. At first it wasnt going fast at all, then it took off like a shot - i slammed both brakes on and nearly burnt them off - put both my feet down to try n slow down ( theres a crossroad at the bottom of that hill) - i barely managed to get it stopped.
Needless to say id rather go fast on 4 wheels instead of two.
Cool build - looks like it should move pretty good. Id say go 1:1 ( clutch to jackshaft) - the other gears should be okay.
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 24th 2010, 6:50 pm | |
| - dangeroustoys56 wrote:
- I rode my bike once years ago over 40mph - and w/o a motor...... i was going down a super steep hill going to a park at the bottom. At first it wasnt going fast at all, then it took off like a shot - i slammed both brakes on and nearly burnt them off - put both my feet down to try n slow down ( theres a crossroad at the bottom of that hill) - i barely managed to get it stopped.
I thought a 1:1 could make it higher ratio? | |
| Subject: Re: Big wheel mini chopper October 25th 2010, 5:34 pm | |
| well, the motor is using a 2" sprocket, then its going to a larger set of sprockets ( jackshaft) , then back to a small sprocket - its basically an even ratio- to get speed, the motor needs to have a larger spocket, then smaller tward the back . Id try a 2" and 2" then the larger other side sprocket to the stock bike rear gears. | |
Guest Guest
| Subject: Re: Big wheel mini chopper October 26th 2010, 3:51 pm | |
| is the left hand sprocket (looking from behind from a mount-field ride on lawnmower 3 speed? |
Trcustoms Member
| Subject: Re: Big wheel mini chopper October 26th 2010, 4:10 pm | |
| - bigbleuboy wrote:
- is the left hand sprocket (looking from behind from a mount-field ride on lawnmower 3 speed?
No it was from a old yerfdog go kart. I know why you said that though, my old huffy mower had a sprocket that was identical to it, it's a 60tooth #41. | |
Guest Guest
