well......i cant help it, the lifted one needs parts, and i aint got the money for them at the moment so ima start fab work on this, im getting a chopper bike frame from my girlfriends lil brother and im mounting either a 7 hp briggs or a 16 hp briggs twin on it, i need help figuring the gearing cause i want it to be able to cruise at about 50-55, doc sprockett, you deal with carts right, can you help me lol
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7295 Posts : 2914 Location : Ontario Canada
Right up my alley! 55 is f'ing suicide on a minibike, though.
Meanwhile- for calc purposes, I will need the overall diameter of the rear tire. Now- does that 7hp have a 3/4" shaft, or 1"? Clutches and CVT's for a 1" shaft tend to be quite a bit more expensive than 3/4". Or, you could do a mower-type belt-tensioner clutch...
the motor has a centerfugal sprocket clutch on it already, im taking it off and rung a belt back to a jack shaft, going to run a 3"- 7" pulley, then i need help with the sprockets, im prety sure the tire is either 20 or 21"
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6377 Posts : 1434 Location : east dublin georgia
Why take the centrifugal clutch off? I would leave it unless you are going with a torque converter like Fearlesses go-kart.
Is it one of the newer Schwinn Stingrays? Those things are sweet dude, I saw a video of one on YouTube and they fit a Harbor Freight engine almost perfectly and look just like a mini chopper.
yea, i got her had to modify the frame to fit in the 7 hp, so i just went a head and stretched it a foot she is strong, no flex, and the rear tire is a 22"
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7756 Posts : 3044 Location : Lebanon County, PA
Have a look 'round the engine, there's bound to be some numbers on there somewhere- and we can put the mystery to bed. Why are you looking for a new carb? The video was a bit dark- is the carb missing? If it's there, surely you can repair it.
Look for a can of Rust Oleum (I think0 Metallic Blue. Its expensive as poopie, but my friend is using that on the inside of his 1963 F100 with some aluminum (basically silver) paint and it looks classy. If I see his truck ill try and snag a picture.
well guys, im picking up some metal tomorrow, going to start designing a custom seat pan, and gas tank, but m not sure what design i want to go with, any ideas?
yea, ill do that one, it will be easier, the whole build is like a prototype for me, im building this one for experience, then im going to build a custom frame and do a full size one powered by the 16 hp oppy, ill get the tools and do that one round , but im picking up some parts tomorrow, and i mught have a carb i can use on this motor
Doug Site Owner
If the tank thats on the carb doesnt get in the way of anything, you could make your tank, and using a barb fitting tap the tank/carb and have more fuel capacity.
i had thought of doing that, however, the carb that is on it doesn't have seperate controls for the choke and throttle, so i want one that does, and i just dont want the ugly tank there lol
