 Monster work tractor
greener179
MowBandit
dylansrockinrigs
9 posters
dylansrockinrigs
dylansrockinrigs
Monster work tractor Empty
PostSubject: Monster work tractor   Monster work tractor Icon_minitimeApril 29th 2013, 8:34 pm
Ive got the rear diff trannsmission and transfer case from a 4x4 truck. Im gonna use a pulleys to gear down a 7 horse motor and the out put for the front diff from the truck will be for a power take off or hydraulic lines but thats way in the future ill post some pics in a bit
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeApril 29th 2013, 9:02 pm
Mock Up #1
Monster work tractor 2013-010
Mock Up #2
Monster work tractor 2013-011
Brush Guard and all.
Monster work tractor 310
The Little Pulley Will Go On The Motor. For every 3 1/2 turns of the little pulley the big pulley turns once. Im not sure if this will work but i need new pulleys anyway.
Monster work tractor Pulley10
Tell me what you think two seats like Mock Up #1 or one seat like Mock Up #2
Im going to straiten that brush guard out and put it on there no matter what.
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeApril 29th 2013, 9:08 pm
I would do 1 seat.
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeApril 30th 2013, 5:32 pm
Heres the frame plans drawn to scale too!
Monster work tractor 2013-16
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeApril 30th 2013, 5:59 pm
cant see the pic
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 28th 2013, 7:54 pm
sorry bout that. the rear axle is 5 feet the frount is 4 feet but im going to extend it. the whole thing is going to be about 6-6.5 feet long. and my frame is going to be about 18 inches wide.
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 28th 2013, 7:56 pm
its also getting the steering box from the truck so itll be pretty heavy duty.
MowBandit
MowBandit
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 12:31 am
sounds like a great plan Very Happy also is that a john deere i see lol?
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 7:19 am
yep its got 17 horse briggs that has extreamly high comprssion and wont start
MowBandit
MowBandit
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 5:59 pm
is it a opposed twin or a v-twin/single ? my opposed twin had super high compression with shaved heads and being bored .30 over i had to run 95 octane with some octane booster for it to even start but after i ran it alittle bit i just ran 95 octane for about 4 weeks then i put my stock heads on it and it ran alot better so from what i was told and learned opposed twins dont like shaved heads lol
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 6:01 pm
its a single.
greener179
greener179
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 6:02 pm
If its a ohv check the valve lash that can make them hard to turn over
MowBandit
MowBandit
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 6:03 pm
its a single.
are you sure that it has high compresson and not a weak starter or like greener said check the valves if its OHV
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 6:06 pm
it is an ohv im not sure what valve lash is i know for a fact its not the starter because i can turn my neighbors 18 horse opposed twin over by hand and i used to be able to pull startit this one.. i will post this in the engines section when i get around to working on it. for now its the tractor. does anybody have any advise for removing the rear axle from the truck?
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 7:13 pm
Don't count on it. Your neigbour could have low compression. Your starter's bushings could be dry and dragging, bad brushes, whatever. Lotsa possibilities.
It's very likely the valve lash has gone outta spec or the starter is ailing. Hell, could even be a poor electrical connection.
Quote :
Yes- bring a torch!
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 8:06 pm
Quote :
Yes- bring a torch!
I dont have a tourch but ive got everything disconnected except the drive shaft.
MowBandit
MowBandit
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 8:17 pm
Quote :
Yes- bring a torch!
-_- i hate starters just because there a pain in the a** to rebuild and fix for me lol
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 8:56 pm
You've already got the springs off? Good- that's the hard part. The driveshaft's easy.
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 9:01 pm
Oh okay. The springs were easy for me to get off with an impact wrend and som WD 40. I just need to disconect the drive shaft then its out. But the driveshaft is being a pain.
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 29th 2013, 9:14 pm
Quote :
Yes- bring a torch!
Torches make a mess, just leaf spings and driveshaft and some parking brakes are all your fighting.
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 30th 2013, 5:58 pm
And are sometimes the only option with 30 year old suspension bushings that have permanently fused to bolts that have permanently fused...
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 30th 2013, 6:38 pm
I guess, I would only use one to cut something up for scrap. I like cordless angle grinders a lot.
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 30th 2013, 6:43 pm
I'm not talking about cutting, just gobs of heat.
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeMay 30th 2013, 8:17 pm
i have used torches before and getting hit with acycetlen (doubt i spelled it right) tourch slag is not fun
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: Monster work tractor   Monster work tractor Icon_minitimeJune 18th 2013, 5:37 pm
After 4 grueling hours of sweating swearing grinding and hammering i finally got the rear end out!
» This.. Is how you work on a tractor :D
» new mudder/work tractor
» Ford YT 16 Work Tractor
» Craftsman GT Work Tractor Build
» 1990 AGWAY work/off road tractor
