 Craftsman GT Work Tractor Build
WellThatsSurprising
camomanusa
Moose
10 posters
Craftsman GT Work Tractor Build Empty
PostSubject: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 15th 2014, 7:17 pm
So yesterday I picked up two squarebody GTs, both with 18hp horizontal opposed twins (420000 series) and Hi/Lo 6 speed transaxles (Peerless 6330. One was running perfect, the other a donor parts tractor (an earlier model, but same in every way). The owner said that the donor probably ran, and that he had never tried it since he got it for parts. Well I had to try it anyways, I would kick myself for taking apart a nearly-running machine.
So anyways, the plan is to use this at work. None of our other 4-wheeled equipment is working other than the big tractors, and we need something to pull yard carts, rollers, and sprayers.
Here it is off the truck.
Craftsman GT Work Tractor Build Cam00810
Craftsman GT Work Tractor Build Cam00811
Craftsman GT Work Tractor Build Cam00812
Craftsman GT Work Tractor Build Cam00813
Pics from the head cleaning:
Before:
Craftsman GT Work Tractor Build Cam00819
After (everything was done with WD-40 and a nylon hoof cleaning brush):
Craftsman GT Work Tractor Build Cam00820
Craftsman GT Work Tractor Build Cam00821
Craftsman GT Work Tractor Build Cam00822
And all together, $30 later:
Craftsman GT Work Tractor Build Cam00910
Video of it running, albeit crappy:
Moose
Moose
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 15th 2014, 8:04 pm
nice Very Happy
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 15th 2014, 9:36 pm
Im thinking of what I want to run off that front PTO. Was thinking of finding a generator with a bad engine but good alternator and making a front-facing attachment. Then I could use it to fix fences or trim bushes or whatever.
I need to redo the exhaust too. It needs to be quieter. Will probably try my hand at making custom flanges to have the manifolds join, then go to an actual small tractor muffler. Then depending on how loud it is after that I might make a resonator.
The back end will get a 2" receiver mounted higher than the normal mount so I can pull the one trailer we have that has a ball on it.
camomanusa
camomanusa
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 16th 2014, 11:06 am
Looking forward to seeing this progress!
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 17th 2014, 7:04 pm
Direct steering mock. Got lucky and we still had a 17" piece of 1 1/2" x 1/4 flat stock from a previous repair (same size as the original tie rod arms), so I halved it. The one got a square cutout about an inch and change deep, and just slightly smaller than the OD of the spindle. A few whacks later it bottomed out and I curled the edges over for a semi-press fit.
Craftsman GT Work Tractor Build Spindl10
Doc pointed out that a straight angle on the arm would result in poor right hand steering and that I should angle it. I couldnt understand it and I finally got down and doodled it and it all makes sense. Excuse the messup in the third pic.
Craftsman GT Work Tractor Build Steeri11
Luckily I didnt weld the arm other than a tack so ill fix it tomorrow. Also need to find some pipe that i can sleeve over the original tie rods, I want to halve both of them and use one as a tie rod and the other as the drag link. Ball joints didnt have too much play so I hope it works.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 18th 2014, 5:32 pm
Opposed runs good now! Just needed a carb adjustment.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 18th 2014, 7:23 pm
There was actually a licensed Sears attachment like that back in the day.
Craftsman GT Work Tractor Build Mmmmin10
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 18th 2014, 8:02 pm
No sh*t. Mines basically the same thing but the opposite way.
Moose
Moose
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 19th 2014, 1:18 am
Why not a hydraulic pump? Could run some attachments or even build a 3 point
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 19th 2014, 7:31 am
Ugh, hydraulics. Right now the plan is the genny and a pair of lift arms. Maybe a winch. Also priced out rear ags and front tri ribs.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 19th 2014, 5:46 pm
Rainy day and boss left early so I got to do some more work!
Adjusted spindle and welded it.
Craftsman GT Work Tractor Build Cam00911
Extended the steering shaft 2" with a 3 1/2" pipe and welded a bolt into the end. Also added a tab to hold the arm. Did this so I could rebuild it if necessary.
Craftsman GT Work Tractor Build Cam00912
Craftsman GT Work Tractor Build Cam00913
Gave it a little twist so it wouldnt angle the ball joints so much. Amazing what a yellow bottle torch and a ton of force can do.
Craftsman GT Work Tractor Build Cam00914
Drilled holes 1" apart. For future reference, Marvel air tool oil works great for drilling.
Craftsman GT Work Tractor Build Cam00915
Had to shorten the arm on the steering wheel cause it was hitting the frame. Only had to cut off one hole.
Craftsman GT Work Tractor Build Cam00916
All in.
Craftsman GT Work Tractor Build Cam00917
I cut the old tie rods in half and threaded the ends to make a new single tie rod and drag link tomorrow.
Craftsman GT Work Tractor Build Cam00918
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 20th 2014, 7:17 pm
So did tie rods today. I used 16ga 1/2" OD square tube. Figured it would be more rigid than round tube. Then I just welded 3/8-16 nuts on the end so I have even more adjustability.
Craftsman GT Work Tractor Build Cam00919
Craftsman GT Work Tractor Build Cam00920
Sorry for the weird angle, but there they are all set up.
Craftsman GT Work Tractor Build Cam00921
Pitman arm. Switched the one bolt for a longer one as a steering stop. Its a little off but it prevents rollover.
Craftsman GT Work Tractor Build Cam00922
Turned all the way right, its not as sharp as left but itll work. The rods end up rubbing but it shouldnt be an issue. I might add another lock washer just to space it that much more. Also want to take the spindle back off and shorten the arm to just 3 holes.
Craftsman GT Work Tractor Build Cam00923
Craftsman GT Work Tractor Build Cam00924
Everything works ok, but its really hard to turn. Going to use a handlebar instead for more leverage. Will have to finish off tomorrow.
Craftsman GT Work Tractor Build Cam00925
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 20th 2014, 7:58 pm
"Everything works ok, but its really hard to turn. Going to use a handlebar instead for more leverage."
LOL... Girlyman....
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 20th 2014, 8:01 pm
The stock plastic steering wheel wasnt working too well, flexed too much.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 20th 2014, 8:04 pm
put a 22 inch wagon wheel on it (grin)
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 20th 2014, 10:49 pm
Just curious as to why you went with direct steer, were the gears stripped out on the steering? or do you just prefer direct steer?
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 21st 2014, 6:33 am
The front arm the tie rods came off of was siezed and the main gear was missing. Had no other choice really.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 21st 2014, 8:48 pm
I finished the handlebar today. Totally slipped my mind to take a pic of the mount finished upl close but whatever. Either way, it works great. Room for improvement, but I can steer now. And yes, I was totally using that 6x6 as a seat.
Craftsman GT Work Tractor Build 99836310
Craftsman GT Work Tractor Build 15081110
Craftsman GT Work Tractor Build 19597710
Gas tank is just temporary, although it seems to work ok. Might just make the angle mount longer so it gets both holes and reinforce the firewall. Also plan on hooking up a diaphragm pump again. Dont really need it since its gravity fed right now, but itll help keep the right pulse.
Craftsman GT Work Tractor Build 13959110
Slapped the tins on and it looks ok! Have to do some tweaking to the mounts on the hood, and some new screws for the side panels. Also need bolts to connect the fenders to the floorboards, and a new seat. REALLY needs a new seat. Not sure if im gonna buy a new lowback or get a pan seat. Then itll be time for paint prep.
Craftsman GT Work Tractor Build 10114110
Craftsman GT Work Tractor Build 19772610
View from the drivers perspective (kinda).
Craftsman GT Work Tractor Build 19201410
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 22nd 2014, 7:32 pm
OK I need more help with this friggin thing. Its still running rich and just about flooding. I have tried adjusting it but it still looks like a gasoline tornado in the carb when it runs. Any ideas? Would rather not have to buy a new carb but if thats what it comes to ill do it.
83ratrodmurray
83ratrodmurray
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 22nd 2014, 9:47 pm
make sure the carb is clean especially the needle and seat and make sure the float has no holes in it.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 22nd 2014, 9:52 pm
It was pretty clean when I pulled the top half. Float has no holes. Probably the needle seat.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 26th 2014, 6:30 pm
Ordered a carb overhaul kit. Should be here tomorrow and work on it Friday. Fingers crossed it solves it.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 26th 2014, 6:36 pm
Saw one of these in the local mower graveyard, pretty rough looking. 100 bucks would probably get it. I don't need it, too much to do....
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 26th 2014, 8:00 pm
Take it and mail it to me piece by piece.
PostSubject: Re: Craftsman GT Work Tractor Build   Craftsman GT Work Tractor Build Icon_minitimeMarch 28th 2014, 9:07 pm
Purrrrrrrrr goes the oppy. Rebuild kit did it!
» My Craftsman tractor + the build
» 1989 craftsman mud tractor build up
» Dustin M's Wood-ED (Craftsman Electric Drive Woods Tractor) [2019 Build-Off Entry]
» For Sale: Snow Blower Craftsman for Craftsman lawn tractor for parts
