oh i was wondering if i could use it on my peerless 700 if it was larger than the original.
I have not directly compared them, but I'm betting they are identical. There's a lot of interchangeability between gearboxes, saved money for the company.
I'm talking about hitting a croquet ball with rackets, or shortened hockey sticks, while riding.
Not hitting a ball with the machine.
It would be like polo but with tractors instead of horses. Or maybe more technically correct, tractor hockey. (With a ball instead of a puck.)
No, I got what you're saying. I'm talking about hitting the ball with the machine like they were doing in the video, just using a ball instead. But it couldn't be a soft ball like a yoga ball or it would go under the bumper and flip the machine.
Age : 23 Join date : 2014-01-22 Points : 4571 Posts : 546 Location : north carolina
hi doc great built i like the idea with the compressor im sure it would be very handy on my tractor, but i was just wondering what is the size of the bore for the input pulley of the transaxle ? (the peerless 920)
Doc Sprocket Site VIP
Hey Doc, Are you running two or four shift fingers? My 920 is skipping a lot in 1st and 5th. I haven't gotten into it yet, but assuming that the fingers are rounded off and maybe the inside keyways in the gears are damaged... I bought a set of two fingers to replace. Just wondering. Hope all's well!
4 shift keys. But I may conduct an experiment sometime in the future. Despite the logical conclusion (4 keys being better than 2) I have heard reports of 2 keys outperforming and lasting longer than 4. Dunno. Food for thought. In a perfect world, 4 keys is better. Maybe in reality, twice the engagement means twice the DIFFICULTY in engagement (no synchro), so... ?
I haven't done anything by ways of mods lately, just using it for it's intended purposes (go figure). But I still have some tweaking to do. I can't get into 6th gear, so I need to make a linkage adjustment, and I have bugger all for brakes, either. Again, linkage. I'm strongly leaning towards doing away with the brake/clutch combined thing, and putting the brakes on a separate pedal. I like what the Mowrons have done with this, likely doing similar.
I really really like the concept of having the brakes on a separate pedal.
If you are like me and loathe to put a bunch of money into a whole new brake setup... And you understand that the factory brakes actually work pretty good, if you aren't racing... Then it makes sense to put them on a separate pedal, which means you have positive braking that has nothing to do with anything else.
You push the brake pedal, the brakes are activated. Period. And like I said, if you separate them out, and check out how well they work as a separate function, you may be surprised.
I am glad I have taken the ariens all the way down to the frame. Also glad that I found out that I can swap the clutch pedal from the right, back over to the left, where I like it. And it looks like putting in linkage to do a completely separate pedal for the brake is probably feasible to do before I actually start getting things back onto the frame.
Now you have me inspired again. I am off to research what the mowrons have done!
Yep- mostly. For stock or near stock speeds, the factory brakes aren't bad. Anything faster, is another story.
After the last transaxle met God, I took the opportunity to install a mechanical go kart caliper and a 6" rotor. Initial test runs had showed the ability to lock those Carlisles up at full bore. Bueno.
Since re-arranging and reinforcing the rearend, I've had some issues with the linkages. This is what is prompting me to rework them.
Having had enough of the whole brake/clutch thing, I scalped a brake pedal from a parts ATV, and scabbed it on. Ran a link rod back to the caliper, and boom- brake pedal.
I'd like to thank Stretch and TRB for the pedal placement. I never would have thought to put it behind the throttle, but it works!
I also got rid of the lawn tractor battery. I roasted another one, winching. ENOUGH! Time for a 1000CA car battery! There she is, bolted all snugly in the trunk.
And here's more detail on the whole thing, and a cool wheelie, too!
You gotta remember a basic thing here- a battery does not "deliver" current- it makes it available. An electrical device will draw what it needs. I could hook up 12 of these batteries in parallel- for a total of 12 THOUSAND avaliable crank amps- and NOT burn up the starter.
