 water in trans
tman9114100
7 posters
tman9114100
tman9114100
water in trans Empty
PostSubject: water in trans   water in trans Icon_minitimeApril 14th 2013, 9:14 pm
how do i get water out of my transaxle? do i have to take it all the way apart? or is there some way i can do it with out taking it all apart? thanks for all your help
PostSubject: Re: water in trans   water in trans Icon_minitimeApril 14th 2013, 9:30 pm
How is there water in it?
PostSubject: Re: water in trans   water in trans Icon_minitimeApril 15th 2013, 9:09 am
I would strongly recommend taking it apart... there isn't any way to be sure you got it all out if you don't.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
tractorboy567
tractorboy567
PostSubject: Re: water in trans   water in trans Icon_minitimeApril 15th 2013, 9:38 am
when you put it together, tighten all the bolts to the right torque and put good gasket maker on it
xxXMowerdudeXxx
PostSubject: Re: water in trans   water in trans Icon_minitimeApril 15th 2013, 9:52 am
Yeah, ur gonna need to take it apart
PostSubject: Take it apart.   water in trans Icon_minitimeMay 28th 2013, 6:52 pm
Before you take it apart I recommend you watch FearlessFront's video on YouTube on how to lock a transaxle. You don't need to lock it if you don't want too, but it has pointers on how to take apart and put back together a transaxle.
PostSubject: Re: water in trans   water in trans Icon_minitimeMay 28th 2013, 8:05 pm
Yep- tear it down. Sounds like a great time for some maintenance, too. Clean all the old grease out of there and regrease everything. No not use solvent to clean the bronze bushings, just a rag. If you have a few bucks to spare, new bushings would be a great idea. If it's a Peerless, inspect the shift keys while you're there, and as a general statement, inspect all parts.
When disassembling, don't leave the pulley on and get all Rambo trying to force the case halves apart. Quite often, there's a bolt hiding under it.
water in trans
» What trans
» yay! broke my 1st trans!
» help with trans
» mtd trans help
» Hydrostatic with Transaxle Cooler
