| | Home made wire wheels | |
Kel Member
![Kel](https://2img.net/u/2812/37/66/46/avatars/678-48.jpg)
Join date : 2013-03-06 Points : 4285 Posts : 75 Location : New Franken
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Kel Member
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | Subject: Re: Home made wire wheels March 31st 2013, 8:11 pm | |
| [img] ![Home made wire wheels Kkel_010](https://i.servimg.com/u/f73/18/17/54/77/kkel_010.jpg) [/img] Then you're ready to cruz. The frame has been stretched 6 inches and lowered 4 inches. Briggs modified cam to give a loppity idle. | |
| ![Go down](https://2img.net/i/empty.gif) | | Doug Site Owner
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | Subject: Re: Home made wire wheels March 31st 2013, 10:14 pm | |
| How do you make them? Bolts through the rims welded in? They look pretty cool, very showy. Looke great on that lowered. ![](https://i.servimg.com/u/f86/19/98/54/71/separa13.png) Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| ![Go down](https://2img.net/i/empty.gif) | | truckin42 Veteran Member
![truckin42](https://2img.net/u/2812/37/66/46/avatars/462-16.jpg)
Age : 26 Join date : 2012-10-04 Points : 5429 Posts : 1070
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | mudmonkey06 Member
![mudmonkey06](https://2img.net/u/2812/37/66/46/avatars/748-9.jpg)
Age : 28 Join date : 2013-03-18 Points : 4520 Posts : 327 Location : Rindge, NH
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | Subject: Re: Home made wire wheels April 1st 2013, 6:49 am | |
| Cleaned the rims with mineral spirits,
Submerge in paint stripper, (the dull look),
Drilled holes through the rims and a castle nut in the center,(under the washer)
Polish the rims before adding the spokes.
The spokes are made from brazing rod, braze the drilled holes shut to each side. No air leaks.
Add sealer to each rim,to the outside so it stays shiney.
All done. | |
| ![Go down](https://2img.net/i/empty.gif) | | Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6469 Posts : 2101 Location : Norway, Europe
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | truckin42 Veteran Member
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | Subject: Re: Home made wire wheels April 1st 2013, 11:21 am | |
| - Kel wrote:
- Cleaned the rims with mineral spirits,
All done. Oh ok. Sounds like their simple to make. | |
| ![Go down](https://2img.net/i/empty.gif) | | tractorboy567 Member
![tractorboy567](https://2img.net/u/2812/37/66/46/avatars/562-12.jpg)
Age : 26 Join date : 2013-01-02 Points : 4383 Posts : 121 Location : PA
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | TheRainbowBoxer Moderator
![TheRainbowBoxer](https://2img.net/u/2812/37/66/46/avatars/326-23.jpg)
Age : 49 Join date : 2012-04-23 Points : 5627 Posts : 1091 Location : Galion, OH
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Thunderdivine Veteran Member
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![Home made wire wheels Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Home made wire wheels | |
| Who is online? | In total there are 51 users online :: 0 Registered, 0 Hidden and 51 Guests
