| Best way to get your rear Rim off of Transaxle that wont budge. | |
+5TroyBilt Pony dylansrockinrigs muddstir Doug W1ldyOvvnZ 9 posters | Author | Message |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5248 Posts : 499 Location : Winchester, ON, Canada
| Subject: Best way to get your rear Rim off of Transaxle that wont budge. March 30th 2013, 9:59 pm | |
| Hey i was wondering how would i get a tire off my transaxle, the tire doesnt want to move. Here are a list of what ive tried:
-Pulling on the tire and pulling on the tractor at the same time -Penetrating oil between the Axle and the Rim and trying to pull it off again -Heating the Rim up with a torch to expand the metal and then pull on it again -Hitting the Axle and pulling on the rim -Putting a jack between the Frame and the rim and trying to push it off(not alot of pressure, just until i notice it start to flex the rim)
i cant get the piece of Keystock out either so its still in there and the Snap Ring is off:P What other Suggestions do you guys have, the other tire had grease on the axle so it slid of easy... i want to keep the rim and transaxle so i cant really break either one. | |
| | | Doug Site Owner
| | | | W1ldyOvvnZ Member
| Subject: Re: Best way to get your rear Rim off of Transaxle that wont budge. March 31st 2013, 12:00 am | |
| Never though of cooling it, i though if i were to get it hot enough it would be better to keep it warm, if i was to be able to get the Keystock out i think i might have better luck too(i was thinking of welding a piece of clothes hanger to it) but ill give your idea a try first. | |
| | | Doug Site Owner
| Subject: Re: Best way to get your rear Rim off of Transaxle that wont budge. March 31st 2013, 12:26 am | |
| I know shocking it should just knock the rust loose. Get the rim around the shaft red hot and take a 5 gal bucket of icy cold water and dump it on it. Should work. If not you could always try a pulling tool. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | muddstir Member
Join date : 2012-01-22 Points : 5034 Posts : 318 Location : Western,PA
| Subject: Re: Best way to get your rear Rim off of Transaxle that wont budge. March 31st 2013, 12:42 am | |
| Sounds like the same issue I had on one of my F-N-R transaxles, I ended up making a puller and ruined the rim. Since the rim never moved and was now junk, I then plasma torched the rim off by the hub part then took a cutoff wheel to the hub part. Still had to pry the hub off after it was cut in the middle on both sides due to the rust. The only thing I didn't do was get both parts cherry red with heat, I did heat them up but not real hot. | |
| | | W1ldyOvvnZ Member
| Subject: Re: Best way to get your rear Rim off of Transaxle that wont budge. March 31st 2013, 4:59 pm | |
| i just tried heating them red hot then cooling them with cold water, still didn't work, Then i tried heating it red hot again and then i started swinging at the tire(not the rim) and still nothing, im thinking the only option left would be to cut it off or take the keystock out and try everything again | |
| | | dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5035 Posts : 306 Location : Silk Hope N.C.
| | | | TroyBilt Pony Established Member
| | | | Creepycrawler Established Member
Age : 37 Join date : 2013-07-02 Points : 5016 Posts : 731 Location : Logan Ohio
| Subject: Re: Best way to get your rear Rim off of Transaxle that wont budge. July 3rd 2013, 12:42 am | |
| I have a couple tricks that usually work. Step 1 Go buy a can of pb blaster, as you will use at least half a can,
Step 2 Use a torch and get the wheel cherry red where it slides on The axle, then spray the axle with pb. It will smoke like crazy And occasionally catch fire so have something to put out the flames if they get to big. Keep spraying the axle till the smoking stops. This "cracks" the rust and let's the pb get down where it needs to be
Step 3 repeat steps 1-2 at least 3 times.
Step 4 get a medium size ball peen or small sledge and a 3/4 inch punch Have a friend with gloves put his feet on the tranny and pull the tire like he was trying to pull it off. Put the punch on the shaft and hit it fast, as in your not hitting it as hard as you can, but your trying to make the hammer hit the punch at max speed. Make sure you do step 4 after heating and before pb | |
| | | Hillbilly Homer Member
Join date : 2012-04-22 Points : 4837 Posts : 197 Location :
| | | | Doc Sprocket Site VIP
| Subject: Re: Best way to get your rear Rim off of Transaxle that wont budge. July 3rd 2013, 5:49 pm | |
| I usually use the shock method Doug described. The heat (concentrated on the outer hub) begins to expand the outer material, and then when you quench it with the cold water, the rapid contraction at differing rates tends to break the rust bond.
For really stubborn stuff like that, I will soak in PB, Liquid Wrench, or similar penetrant multiple times over a few days. This gives it time to penetrate. Without time to penetrate, you're just oiling up the outside.
As mentioned above, I also apply more penetrant while heating.
Somebody 'round here (I think it mighta been FF, forgive me if I'm wrong) has also made use of the wax method. This involves again concentrating heat on the hub, and touching a small tea-lite type candle to the join allowing the wax to melt and wick it. I still haven't tried this, but apparently it is an old mechanic's trick and quite effective. | |
Age : 49 Join date : 2012-04-23 Points : 5698 Posts : 1091 Location : Galion, OH
| | | | Sponsored content
| Who is online? | In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests
