| Stuck rear pulleys | |
Guest Guest
| Subject: Stuck rear pulleys June 23rd 2010, 7:46 pm | |
| I have a really bad stuck on pulley on one of my mowers, i normaly can get them off with my puller but i can't and other times i just cut them off but i always mess up the shaft a bit. Any body have an idea? |
| | | motorhead45102 Member
Join date : 2010-03-07 Points : 5700 Posts : 244 Location : Ohio
| Subject: Re: Stuck rear pulleys June 23rd 2010, 9:35 pm | |
| well my shaft on my mudder was froze just like yours, but luckily, i had a hydraulic press at my high school, and i asked to use it, and it had a gauge to tell how much pounds of pressure i applied and it took 2,130 pounds of pressure to get it out. | |
| | | Guest Guest
| Subject: Re: Stuck rear pulleys June 23rd 2010, 9:41 pm | |
| - motorhead45102 wrote:
- well my shaft on my mudder was froze just like yours, but luckily, i had a hydraulic press at my high school, and i asked to use it, and it had a gauge to tell how much pounds of pressure i applied and it took 2,130 pounds of pressure to get it out.
WOW, i wonder where i could use of of them! |
| | | Chunk Established Member
| Subject: Re: Stuck rear pulleys June 24th 2010, 3:34 am | |
| YOU tried heating the pulley up with a blow torch? It'll expand the metal and hopefully free it up! | |
| | | Guest Guest
| Subject: Re: Stuck rear pulleys June 24th 2010, 11:29 am | |
| - Chunk wrote:
- YOU tried heating the pulley up with a blow torch? It'll expand the metal and hopefully free it up!
For a minute i did but my torch ran out of gas! |
| | | CMHN Member
Age : 47 Join date : 2010-04-11 Points : 5479 Posts : 127 Location : Northeastern, PA
| Subject: Re: Stuck rear pulleys June 24th 2010, 2:47 pm | |
| Do the blow torch idea, heat the pulley up until it get cherry red. This expands the metal and loosen the rust. Try to pull the pulley while it is still hot. | |
| | | Guest Guest
| | | | CMHN Member
| Subject: Re: Stuck rear pulleys June 25th 2010, 3:19 pm | |
| - bigbleuboy wrote:
- NOT with your finger's!
Unless you dont like your fingers I wouldnt suggest using them. Take a rid and strike the shaft to break the pulley loose. Or use a puller. | |
| Subject: Re: Stuck rear pulleys June 25th 2010, 8:53 pm | |
| i know if your pulley is still in the trans axle and you pull hard enough you will snap the snap ring of and the gear will fall in the tranny and your input shaft will come out, so best to tear down and remove the input shaft, unless you already have. | |
| | | Guest Guest
| Subject: Re: Stuck rear pulleys June 25th 2010, 8:55 pm | |
- i know if your pulley is still in the trans axle and you pull hard enough you will snap the snap ring of and the gear will fall in the tranny and your input shaft will come out, so best to tear down and remove the input shaft, unless you already have.
I got it off by letting sit over night in PB blaster than useing my puller and beating it with a hammer! |
| Subject: Re: Stuck rear pulleys June 26th 2010, 10:39 am | |
| Thats how i got my wheels off my mild mod MTD- PB blaster, a puller and beating em with a hammer...... was a cheep puller anyway, but still works. | |
| | | Guest Guest
| Subject: Re: Stuck rear pulleys June 26th 2010, 7:26 pm | |
| - dangeroustoys56 wrote:
- Thats how i got my wheels off my mild mod MTD- PB blaster, a puller and beating em with a hammer...... was a cheep puller anyway, but still works.
THats how i got my wheels off too! Can't beat beating it. |
| Subject: Re: Stuck rear pulleys June 26th 2010, 7:34 pm | |
| Only thing we get over hear is PlusGas, its basically PB Blaster. Would like to compare the two though. PlusGas is readily available over hear, and beats any other UK dismantling spray, PB is hard as heck to find over here | |
| | | Guest Guest
| Subject: Re: Stuck rear pulleys June 26th 2010, 7:44 pm | |
| - Chunk wrote:
- Only thing we get over hear is PlusGas, its basically PB Blaster. Would like to compare the two though. PlusGas is readily available over hear, and beats any other UK dismantling spray, PB is hard as heck to find over here
If i know shipping wouldn't be to much i would send you a few cans. Does anyone have a clue what it might cost? |
| Subject: Re: Stuck rear pulleys June 27th 2010, 1:30 am | |
| Well i calculated shipping cost to international shipping and its not cheap, and its threw usps(united states postal service) its about 42 bucks paid online, and 44 bucks at a postal office. and shipping is 6-10 business days. Now ups im not sure, but this is with usps with a medium flat rate box to fit a few cans of pb. | |
| Subject: Re: Stuck rear pulleys June 27th 2010, 4:16 am | |
| Ouch, that isnt great! I dont get how they can charge so much for int'l shipping. Doesnt make sense to me. THanks for the offer though! Appreciate it! | |
| | | Guest Guest
| Subject: Re: Stuck rear pulleys June 27th 2010, 1:49 pm | |
- Well i calculated shipping cost to international shipping and its not cheap, and its threw usps(united states postal service)
its about 42 bucks paid online, and 44 bucks at a postal office. and shipping is 6-10 business days. Now ups im not sure, but this is with usps with a medium flat rate box to fit a few cans of pb. MAn.......... that sucks, if it was 10-20 bucks i would do it but not no 44 bucks! |
| | | CMHN Member
| Subject: Re: Stuck rear pulleys June 28th 2010, 5:39 pm | |
| Has anybody tried acetone and atf. I read somewhere that a mixture of these two can make a penetrating chemical that is better then PB blaster. I don't know I have never tried it. | |
| | | noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5370 Posts : 252 Location : DFW Texas
| Subject: Re: Stuck rear pulleys January 15th 2011, 8:32 pm | |
| idk if anyone has tried this but it work amazingly for me. What you do is find i thin tube of metal like rebar or something get one person to put the rebar in the center of the pulley(on the shaft) and tap with a hammer while you pull up on the pulley. it works great | |
| | | canadianromper Member
Age : 25 Join date : 2011-11-30 Points : 4857 Posts : 114 Location : ontario canada
| Subject: Re: Stuck rear pulleys December 17th 2011, 8:16 pm | |
| my pulley was stuck and i heated it up then used a puller and it came off easyer (pull on it when it is hot) | |
