| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
truckin42 Veteran Member
| Subject: Re: MTD off-road romper build. May 13th 2013, 6:53 pm | |
| - truckin42 wrote:
- Looks like it turned out good.
Nice smooth surface. Thanks took 15 min of grinding. | |
| Subject: Re: MTD off-road romper build. May 14th 2013, 9:35 pm | |
| Ill get back to my tractor this weekend. Im thinking of finishing the quick release latches and hood pin, or I might tackle the rear bumper and fenders. What do you guys think? | |
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4701 Posts : 356
| Subject: Re: MTD off-road romper build. May 15th 2013, 9:27 pm | |
| - motorizedeverything wrote:
- looks good i like the high tech going of the rods a zip tie
('') At this current time its all done but I need to take pics lol | |
MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4749 Posts : 477 Location : Haddock,Georgia
| Subject: Re: MTD off-road romper build. May 16th 2013, 12:46 am | |
| very nice and clean build what kind of grinder disc do you use mine seem to last but a few mins of grinding before there o small to use | |
Age : 26 Join date : 2012-10-04 Points : 5503 Posts : 1070
| Subject: Re: MTD off-road romper build. May 16th 2013, 5:42 pm | |
| - Jay_Rod wrote:
- very nice and clean build what kind of grinder disc do you use mine seem to last but a few mins of grinding before there o small to use
I either use the .045 dewalt cutting disk or a regular dewalt grinding disk. | |
MowBandit Member
Doc Sprocket Site VIP
| Subject: Re: MTD off-road romper build. May 18th 2013, 10:05 pm | |
| Looking good!
Rebarding the DeWalt .045 cutting wheels, I just bought 50 of them on sale. I find they cut a bit more slowly than the Walter Zipcut disks I usually use, but they last a lot longer. I made 4 cuts through the 1 1/4" trailer spindles I just installed with one disk, and had a lot of it left... Like 4 1/2" of the original 5" diameter. | |
| Subject: Re: MTD off-road romper build. May 18th 2013, 10:29 pm | |
| - Doc Sprocket wrote:
- Looking good!
Rebarding the DeWalt .045 cutting wheels, I just bought 50 of them on sale. I find they cut a bit more slowly than the Walter Zipcut disks I usually use, but they last a lot longer. I made 4 cuts through the 1 1/4" trailer spindles I just installed with one disk, and had a lot of it left... Like 4 1/2" of the original 5" diameter. I was cutting pipe and it grabbed in the cut lol, disk was about done but it completely exploded. Was kinda cool! | |
| Subject: Re: MTD off-road romper build. May 18th 2013, 10:52 pm | |
| Iv had a couple cuttting wheels come apart on befour. I use dewalt 0.45 cutting wheels and they do last long longer than i expected, | |
| Subject: Re: MTD off-road romper build. May 19th 2013, 9:50 am | |
| - truckin42 wrote:
- Iv had a couple cuttting wheels come apart on befour.
I use dewalt 0.45 cutting wheels and they do last long longer than i expected, Their great as long as they don't get coughs in the cut lol. | |
MowBandit Member
| Subject: Re: MTD off-road romper build. May 20th 2013, 9:50 pm | |
| Tack the sheet metal in places like in different spots so the previous one can cool down. Then I run a line (not swirling like a bead) really quick from tack to tack, I have the wire speed turned up a bit too | |
MowBandit Member
| Subject: Re: MTD off-road romper build. May 20th 2013, 10:08 pm | |
- Tack the sheet metal in places like in different spots so the previous one can cool down. Then I run a line (not swirling like a bead) really quick from tack to tack, I have the wire speed turned up a bit too
oh ok thanx for he tip | |
| Subject: Re: MTD off-road romper build. May 20th 2013, 10:19 pm | |
| - Jay_Rod wrote:
oh ok thanx for he tip yea no probem, it was really tricky I kept burning thru but figured it it, its quite strong too. | |
MowBandit Member
| Subject: Re: MTD off-road romper build. May 20th 2013, 10:56 pm | |
oh ok thanx for he tip yea no probem, it was really tricky I kept burning thru but figured it it, its quite strong too. it looks really good eather way lol | |
Thunderdivine Veteran Member
MowBandit Member
