 MTD off-road romper build.
ranch king pro 08
Axelsol89
mowerheadder
STUNTMAN JON
Rockinator
WilliesBuilds
98svtcobra
MurrayMayhem
jack9102
802 Customs
untrusty huskee
Carshowkid
rarbaugh07
ZSmachines
Deluxe66
Jerbear0612
Moose
Angchor
B440
jamcco
Craftsman1998
breadtrk
camomanusa
mrkadage
MoWheeler
mzeng100
T-Dub13
GenevaCustoms
muddstir
TroyBilt Pony
cumminsbayou
crazykid1994
xxXMowerdudeXxx
genegillis5
Jamus
MowBandit
1993-Sierra-Z71
motorizedeverything
flamudmower
Murray modder
Chopperhed
Ddwannabe
mudmonkey06
70 posters
Go to page : Previous  1, 2, 3 ... 20 ... 38  Next
MTD off-road romper build. - Page 2 Empty
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 9:50 pm
I like the front brush graud.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 9:53 pm
Looks good, I also like the rat rod look.
Chopperhed
Chopperhed
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 10:02 pm
I luv Rats,
Nice work
Take it out, have it sandblasted, let it sit in the rain, then treat it and clear coat it.
cheers
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 10:05 pm
Chopperhed wrote:
I luv Rats,
Nice work
cheers
What's the trick to end the fire? And still let it look like rust.
Chopperhed
Chopperhed
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 10:26 pm
Thunderdivine wrote:
Chopperhed wrote:
I luv Rats,
Nice work
cheers
That I don,t know.
All the rust rtreatments I have turn the steel black.
May have to try an artificial patina.
Or,
Build it ot of High nickel steel, and let it sit out for 100 years. Like real rats
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 10:29 pm
Chopperhed wrote:
I luv Rats,
Nice work
cheers
That I don,t know.
Yeah same here
Or,
Yea same here, maybe try dilute it some
Chopperhed
Chopperhed
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 10:32 pm
I suppose a real good chemical cleaning, ( carbon tetrachloride or something similar), followed by an etching acid, a good baking soda rinse, a good wipe with 99 % Isopropyl alch, or acetone, and a clear coat might work for a while.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeMarch 28th 2013, 10:35 pm
That would need a good starting point, an old Ford or sum thing Very Happy
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 3rd 2013, 6:53 pm
so I started on a double pully clutch, but for the pullys bearings I need 5/8' bolts in order to make things work. Lock nuts will have to be in place. unfortunately my welders gun isn't working right, so no progress. ugh
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 3rd 2013, 8:22 pm
Yeah a double pully cluch works good.
How thick is the steel you are using?
Murray modder
Murray modder
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 3rd 2013, 8:44 pm
If its jammed, take off the little tip piece, and pull it the wire out...if that doesn't work, and it starts and stops a lot, you welding wire may have rusted.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 5th 2013, 4:57 pm
No shes not feeding at all, I had it on, grinded something, came back with t was still on and the button didn't work on the gun, I changev the .030 tip to a ew one and pulled wire thru and it weslds but idk the gun might have junk in it. ill have to see how to take it apart.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 5th 2013, 4:58 pm
I welded a cupple little strips together, and its like 1"/6"/5/16" maybe. im not shure might be 1/8 thick, I think its stainless tho.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 5th 2013, 5:05 pm
Yeah it should work.
Stanleessteel it wont rust.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 11th 2013, 4:36 pm
[img]MTD off-road romper build. - Page 2 Image_10[/img]
While my welders down, and its looking like im getting a new welder, I went to my friends house and he was remaking a dirt hill and I got this shot while I was recording him, lol. I think on mu tractor im going to cut the old oem pully off the shaft and move the 5 1/2" mow deck pully up. im not shure, but I got to either change the front or the back. I might just suck it up and do the 7" rear pully. I either wasted wasted $6 on the rear or $18 on the front pullys.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 11th 2013, 6:31 pm
I would do both front and rear pullys.
Whats the sheet metel on the front of the tractor??
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 18th 2013, 8:18 pm
Sorry for the late response, it was for a custom plow he had
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 18th 2013, 9:08 pm
Oh ok i thought thats what it was for but was sure.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 23rd 2013, 7:49 pm
I might trade some huge stroll tires for some 14" by 4" wide tires for my mower. My future plans are getting new bushing for those tires (if they work, and these will also be my front tires, much taller) and I might detach the front end and weld it lower so the front of the mower is 2-4" taller (lifted look) but that all depends on when I get a welder. Wish me luck!!
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 23rd 2013, 7:50 pm
Good luck.
sounds good.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 23rd 2013, 7:52 pm
Good luck.
sounds good.
Thanks
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 23rd 2013, 7:53 pm
Good luck.
sounds good.
Thanks
Welcome
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 23rd 2013, 9:59 pm
I think i settled on a new welder, either this one: http://www.northerntool.com/shop/tools/product_200403263_200403263
Or this one: http://www.northerntool.com/shop/tools/product_200332691_200332691
Both get good reviews but a $160 something price difference. I think ill shoot for the 135, i can sell my GM lq4 6.0L engine parts for it. i have $210 saved up.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 23rd 2013, 10:20 pm
Yeah i heard them are good welders.
Murray modder
Murray modder
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 2 Icon_minitimeApril 27th 2013, 9:59 am
If your still saving, I don't know how much mine was, but I got a welder from NT, It works perfect on just about evering. It worked on the 1/2 in thick steel plating I had for my front bumper...took forever to cut that.
flamudmower
PostSubject: front tires   MTD off-road romper build. - Page 2 Icon_minitimeApril 27th 2013, 8:31 pm
hey REDLINE just wandering where did you get those front tires from?
Page 2 of 38Go to page : Previous  1, 2, 3 ... 20 ... 38  Next
» Craftsman 2 (YT16) romper "Basic B#$ch" build attempt
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» SS-16 OFF-ROAD BUILD
» MTD Off Road Build
