 I.D. This engine.
xxXMowerdudeXxx
WellThatsSurprising
Murray modder
8 posters
Murray modder
Murray modder
I.D. This engine. Empty
PostSubject: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 9th 2013, 9:24 pm
The only info I could fid on the engine itself is "Twin II, Cast Iron Bore, 18"
Its an opposed twin, and I dont need a giant sticker to tell me that. I need a new starter and cant find a model #, I remode the blower housing and didnt find jack.....if it helps its black.
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 9th 2013, 9:26 pm
Is it the original motor that came with the tractor? If so try looking up the actual tractor and seeing what you can find.
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 9th 2013, 9:52 pm
It should be on the blower housing
xxXMowerdudeXxx
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 9th 2013, 9:57 pm
got pics?
Murray modder
Murray modder
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 10th 2013, 11:38 am
No idea if its oringinal, I just bought the damned thing and the guy I got it from had to start it directly from the starter, and he got the idea of turning the old rusty bolt for the positive terminal and Funny over the insides. and its not on the housing..
offroadredneck
offroadredneck
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 10th 2013, 5:40 pm
My opposed twin was the same way, 18HP and I just got a 16HP opposed with the same starter if you want I could give you the model number.
ibdalovely1
ibdalovely1
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 10th 2013, 10:57 pm
ive got a 20 opposed and found out theirs 2 different starters for them a long case 4. somthing inches and one thats 3.75 or something the longer ones are made for the higher hp motors ive fount them both on ebay heres a link the long one less then 40 shipped new [url=http://www.ebay.com/itm/NEW-STARTER-BRIGGS-399928-495100-498148-14-16-18-HP-/360457205390]http://www.ebay.com/itm/NEW-STARTER-BRIGGS-399928-495100-498148-14-16-18-HP-/360457205390[/url]
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 11th 2013, 7:00 am
They've used 3 starter lengths or types all in all. You can tell which one from the length as you say and what the end cap is made of.
Current style starters are 3 5/8 housing with molded plastic end cap.
Also current style starters 4 1/2 housing also with molded plastic end cap,
They can also be stamped steel or aluminum brush end cap.
Then you have the Early style starter which is 3" housing with Die Cast end cap.
BlackMountian88
BlackMountian88
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeMarch 17th 2013, 9:38 am
422707 is my 18hp twin's model number. But the type will be impossible to know without the original plate. They're all similar enough. Just search 422707.
jack9102
jack9102
PostSubject: Re: I.D. This engine.   I.D. This engine. Icon_minitimeJanuary 27th 2014, 8:44 pm
It's a briggs and stratton. I/C and Twin II are all B&S trademarks. The 18hp engine is a 42 cubic inch / 688cc design, and so will have a 42 as the first two digits of the model number. This is all your small engine shop should need. It's a 12v unit [obviously], and it's a 18h Twin II model 42. There are not a billion starter types for this engine. 422707 is a standard model number for these. Your small engine shop should be able to order a starter for it without the type and code numbers. The Twin II series started after type number 1100.
I.D. This engine.
» Honda HT-R 3009 mid engine rider engine swap
» what engine should i buy?
» Need help chosing an engine.
» Which engine?
