| 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 | |
+45jsisti845 Angchor Moose DirtyD T-Dub13 Rkeefe99 Lawren Wimberly crafsmankiller donfordguy camomanusa 1997 Murray Jedi TroyBilt Pony mr.modified GenevaCustoms FOSWMT crazykid1994 matt-man (509)Mowers Stretch44875 k2500life dylansrockinrigs Marines2621 LAWN MOWER MUDDER motorizedeverything craftsmancole goesman WellThatsSurprising Doc Sprocket MowBandit Ddwannabe Kel TheRainbowBoxer greener179 redlinemotorsportts Murray modder mudmonkey06 Ariens YT11 truckin42 xxXMowerdudeXxx richie thomas Doug Chopperhed gearheadmike Thunderdivine 49 posters | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6537 Posts : 2101 Location : Norway, Europe
| | | | LAWN MOWER MUDDER Established Member
Age : 23 Join date : 2013-04-08 Points : 5203 Posts : 913 Location : Central Pa
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 9th 2013, 5:07 pm | |
| - LAWN MOWER MUDDER wrote:
- AWESOME I really like how this is coming together.
Thanks, it's getting there. Got the steering shaft lengthened today, extended about 2-3inches, just cut and welded on a bolt. That way i also got the threads for "free". | |
| | | | redlinemotorsportts Moderator
Age : 27 Join date : 2013-03-18 Points : 7477 Posts : 3131 Location : raleigh nc
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 16th 2013, 1:00 pm | |
- im guessing it doesn't mount like you want to because of the reservoir? Why not make the mount on the a-arm taller and just make a taller shock hoop?
Nah I dont wanna mount it the normal way. Takes to much room like that. I'm going to try mount it Formula 1 style. Like this. In the + there will sit a ball raced hub. So need to waterjet cut this now for test, just hope it works. | |
| | | goesman Member
Age : 45 Join date : 2012-01-18 Points : 4847 Posts : 119 Location : Salem, Mo.
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 22nd 2013, 9:16 am | |
| - goesman wrote:
- boy that seems like alot of complicated geometry to get wrong with a suspension like that. Good luck with that.
It's not that complicated. Its very well used in Formula 1, cause of low design and you can tuck away the actual shock. It's strange its not adapted for more cars, quads and so on. But it's even less space on mine since the angles are so sharp. | |
Age : 49 Join date : 2012-04-05 Points : 5695 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 22nd 2013, 10:17 am | |
| I'm guessing your using this style shock system for space issues? Looks like you have plenty of room for a conventional shock tower, unless you are trying to keep everything under the hood.
On the steering, is the front bearing on the steering shaft getting some bracing? I don't have a good picture in my head of how you are hooking the steering to the spindles, but the front shaft brace looks weak.
I love the engineering and water jetting, makes for a clean setup. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 22nd 2013, 6:36 pm | |
| - Stretch44875 wrote:
- I'm guessing your using this style shock system for space issues? Looks like you have plenty of room for a conventional shock tower, unless you are trying to keep everything under the hood.
Ya, but also I need the tank to be above the shocks, also I need to find room for the battery. - Stretch44875 wrote:
I love the engineering and water jetting, makes for a clean setup. And I see what you mean, but the front steering shaft is getting its strenght from the rear brace. The only way it will move as a standalone is back and forth, when the steering shaft is inserted and tightened with the rear brace, it will be locked. - If it dont work as planned i will add an angular pcs. But then I will add weight, so fingers crossed, and thanks for the inputs. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 22nd 2013, 6:43 pm | |
| Got the exhaust finnish'ed, but not tested. Also I almost didnt get it to fit after I welded those pipes from the engine lol. I Tig welded the pipes from the motor, then I remembered how nice it welds. This was w/o filler material, also I remembered how friggin hot it gets. I kinda regret that i tacked it with the mig (those lumps), if not it would be perfect, but who cares right. Wrapping an opposed flat head is the best thing you can do to it I guess, keep the exhaust REAL HOT! | |
| | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5365 Posts : 1135 Location : Southern Florida
| | | | xxXMowerdudeXxx Established Member
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 24th 2013, 2:14 pm | |
| - xxXMowerdudeXxx wrote:
- u outta see my welds with flux core, lol, i hate the stuff ansd it hates me, XD
I want a flux core welder so bad. And my welds was fair I would say, Haven't welded with Tig in ages. And there was 3 seams in those pipes. And Ive started designing the gear shifter plate and chain guards in CAD now , but photobucket phone app. wont work atm. | |
| Subject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 July 25th 2013, 5:09 am | |
| I ordered this, I might go the easy way out on the front suspension at this point in time. - then change it later, since I really wanna drive it before winter comes... Will look like a mini car, or a big RC Car with these shocks:P Also ordered this, A Motorcycle Steering dampener. And this, once I get a shipping quote, Also enquired about Billet parts from Eccaburetors.com - but they don't normally ship to Norway. Hope they will, if not it might take 3months to get the parts. | |
| | | | Sponsored content
| Who is online? | In total there are 7 users online :: 0 Registered, 0 Hidden and 7 Guests
