 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12
jsisti845
Angchor
Moose
DirtyD
T-Dub13
Rkeefe99
crafsmankiller
donfordguy
camomanusa
Jedi
TroyBilt Pony
GenevaCustoms
FOSWMT
crazykid1994
matt-man
(509)Mowers
dylansrockinrigs
Marines2621
motorizedeverything
goesman
WellThatsSurprising
MowBandit
Ddwannabe
Kel
greener179
Murray modder
mudmonkey06
xxXMowerdudeXxx
Chopperhed
gearheadmike
49 posters
Go to page : Previous  1 ... 9 ... 14, 15, 16 ... 19 ... 23  Next
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Empty
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 24th 2013, 6:13 pm
Thunderdivine wrote:
prometheusEDI wrote:
yes, I suppose you have a point. Still, Ive never seen an opposed twin idle that high. You mention the leaky intake, I would look there to solve that problem. Otherwise, if it works for you, then it works for you.
Its not leaky as such, and ive seen loads on you tube.
Whats the idle at if you should guess? My guess is max 1500rpm
I got the repair manual, will do a read up on idle speeds since these have many idle settings.
But dont get fooled by the "Look how low mine can go" vids cause they wont get good cooling if below 1000-1200rpm.
Also remeber we have 98 octane gasoline in the pumps, thats racing fuel to you guys so it might just even be a run-in thing.
Anywho i got far more serious things to sort out than a high idle setting Razz
Quite familiar with proper idle adjustments with the opposed twins... I ran them most often at an even 1000 rpm.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 24th 2013, 8:11 pm
I might get to "Waterjet" Cut more parts tomorrow, - Front steering axle support and front A-Arm brackets. Tho ive kinda re-designed the front steering axle support already (in my head). Will use this 'U' Design for both Front & Rear supports, I think.
Rear Steering axle support/ mount,
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 1A325999-5A06-413C-9869-882E9FC6AE8C-19915-0000060250633755_zps18850904
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 24th 2013, 8:53 pm
im very curious how you are doing the front of the steering.... I like how what you have looks
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 24th 2013, 9:17 pm
Why? It will be like this
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 25th 2013, 3:52 pm
My plan for the front, Steering wheel and A-arm mount.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 CE7F392F-EACE-45CE-9A85-E3E33A49B55C-24771-00000782D654CB0D_zps75831851
Side view, Note that Ive angled the A-Arm mounts to give it better handling.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 F389D9C1-464B-4C46-97B2-DC22CC5C5B13-24771-00000782DE6E0A09_zps894d2da6
Chopperhed
Chopperhed
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 25th 2013, 5:11 pm
Btw you can see when i throttle up the clutch engages. And it does engage at 1700rpm so its not that high, maybe 2-300rpm to high. Tho I've read these should not idle below 1200rpm since its splash lubed.
Leaky intake for sure.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 25th 2013, 5:14 pm
Ya think? It is leaky but ive sealed it with a vulcanicing tape. But will look into the whole engine soon.
Chopperhed
Chopperhed
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 25th 2013, 5:31 pm
If the idle adjustments don't work, and it still revs high, its a seriously lean condition. Definitely not a good situation.
Its either leaking between the carb and the engine, somewhere, or a fuel jet is plugged up. Assuming the airfilter is clean.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 25th 2013, 5:33 pm
K thanks. There is a leak in the intake like i wrote. Its broken where the bolts go into the carb. But hoped i mended it.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 26th 2013, 12:24 pm
Found out today:
It kept running lean cause the fuel tank (from the mini ATV) i used didn't wanna feed the fuel hungry engine with gasoline. So hopefully the idle issue is just that.
Here's a progress/ plan video:
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 26th 2013, 1:28 pm
Youre too good at this. Were gonna have to kick you out Thunder. lol
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 26th 2013, 3:20 pm
Happy bday Doug!
Ya I should be over at heymow instead Razz
More pics!
How i'm doing the front steering and Spindle A-arm mounts,
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 2E3EF2BB-75D0-41BA-B6AF-1C84F89085CB-29386-000008DF8FEC6DB0_zps9111d7ec
How i'm doing the disc brake, to get the disc to clear the tire.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 96B4E1B8-DF95-428E-9D82-DB84241211CF-29386-000008DFB3D6616B_zpse8655d50
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 9CEAEC4A-BFB6-4692-8071-93736EF04BB6-29386-000008DFA5052AF7_zps70a3a27e
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 82801803-A063-4EB9-AEF7-88D68AE5404C-29386-000008DF9D9225B2_zps9d3b1d88
How I'm still planning a hitch mount on it.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 7A38230F-234E-4000-B7FE-10C5CBDE6EAB-29386-000008DFF09E1A2A_zps601b9489
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 50099D7C-1F53-4F39-8970-3830E07934EC-29386-000008DFDA4F7115_zps2d1a50bd
New Diesel Tach (cheap one), hope this will work???
Im trying to connect it to the AC out from the Opposed alternator.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 FBDF2ADB-081B-41A5-A690-E8F595B96680-29386-000008DFFE9AE037_zps3e3dee1c
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 26th 2013, 3:28 pm
Heymow? HEYMOW? This place is for real do-it-yourself'ers, heymow is for people who buy rather than build.... and spend more on paint and shiny rims than anything.
But thats only my opinion - and your build continually impresses me - such attention to detail!
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 26th 2013, 3:29 pm
I know it was a joke, and thanks.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 26th 2013, 3:31 pm
a good joke at that lol... you almost had me fooled
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 28th 2013, 9:56 pm
It bloody worked as they say in the UK!
Installed the Diesel Boat Tach today, "Installed" hooked up 3-wires.
Also not doing much with the front physical now tho i got the front rear mount cut today and it was finally correct, tho the spot welds need to be ground down before it will fit Razz
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 414EDB52-9936-4019-95EF-D933820EF9D1-41460-00000C8A26D28472_zps5feb75d3
Realized im running out of space in the front, A-arms, shocks, fuel tank and exhaust is going there...
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 6F870DB2-ECC3-4AAB-B561-5DD4A4D4F8FA-41460-00000C89FF49D9B7_zps09786e28
Soo.. Ima try make an exhaust chamber that sits inbetween the frame, that will save me some space, or alot actually. And it should also sound sweet.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 69942259-A9EF-4D74-B7BE-7A7C094E7FDD-41460-00000C89EB425068_zpsad262c85
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 5DC2D75A-2332-4DAA-9681-5F25D62D0734-41460-00000C8A0D1318B5_zpsea7c620c
3" Pipe between the frame then two 1-1/16 i think up as headers. And 2" out on each side as straight pipes.
Catch can for the 820 breather nipple! I said nipple!
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 426BDBB4-241D-423D-BE01-B540DC47971A-41460-00000C8A35AE8D48_zpsaf2162ec
goesman
goesman
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 29th 2013, 11:33 am
Are you locking the diff in your trans. I am wondering because if you do not and put only one brake disc in the rear technically you will only have brakes on one rear tire.
It looks really good so far sure wish i had the resources you have for my builds.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJune 29th 2013, 4:40 pm
Thanks for the heads up and im not gonna lock it now, but maybe later. And the main brakes will be on the front.
Like 70% Front and 30% Rear. And the plan was to keep the stock 820 brake aswell, but more as a handbrake / slave.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 4th 2013, 5:11 am
Waiting for more important parts being watercut Very Happy  - Sooo little progress, but on the exhaust.
Was a lot more difficult than I first thought, with all the thin sheet metal fab. and to figure out what angle it needs to be cut in.
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 4th 2013, 5:00 pm
3 Hours later... getting there.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 7AEBFEBA-07F8-48AA-867D-71B6C235375B-65171-000013B0FDE1C3AD_zps1b3423a4
Dual of these,
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 328A1729-F047-4AC6-B013-D655E7FE3169-65171-000013B0F6020789_zps7a7dcf73
Angles look a bit weird it will be more horizontal once mounted,
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 92231E42-78F5-4616-9D44-A18D1C2BFD3F-65171-000013B1034D4D08_zps60512377
Tommorrow I will do the small pipes up to the engine, thats the hard part.
And happy Fourth you guys cheers
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 4th 2013, 11:00 pm
Hey nice progress. I know that I said this a few times and other people say it too but I really like this build I
think it is one of the cleanest mower builds....kudos to you.
Happy fourth to you to!
dylansrockinrigs
dylansrockinrigs
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 5th 2013, 4:11 pm
Ive got to see this finished
xxXMowerdudeXxx
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 5th 2013, 8:52 pm
man this thing is turning out awesome, im going to make you fly it out to me so i can drive it!! lol, i love it man
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 5th 2013, 9:06 pm
Awesome job can't wait to see it finished
http://www.lastdropgarage.com
motorizedeverything
motorizedeverything
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 5th 2013, 10:26 pm
when can i order my water jet parts to build mine
PostSubject: Re: 92mph? My new Project, Racing mower! Craftsman / Jonsered LT12   92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 Icon_minitimeJuly 6th 2013, 6:26 am
Haha thanks guys.
I got to change the 820 parts eventually,
Now the rear sprocket will sit nice and low, also swapped the shifter rod and fork.
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 54CFC890-3B1F-44A3-A6E5-D76A7E8581BB-68409-000014A9D4681D56_zps0f4a2b75
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 D0B3EC9B-00F7-47F9-A0BD-889BB9E4498C-68409-000014A9BAEFBF9E_zps38d1f8fb
92mph? My new Project, Racing mower! Craftsman / Jonsered LT12 - Page 15 9D84BA5A-B4FF-4A3A-B18F-B05900C3349B-68409-000014A9E3365D4D_zpsf215128c
Page 15 of 23Go to page : Previous  1 ... 9 ... 14, 15, 16 ... 19 ... 23  Next
» racing mower project
» Murray Select Racing Mower Project
» Stallion Racing Mower (Project Yeah Buddy)
» Mod XR Racing Mower (Craftsman)
» craftsman racing mower
