| I need info on this mower please | |
TheEquineFencer Member
Join date : 2013-02-19 Points : 4418 Posts : 90 Location : Farmville,NC, USA
| Subject: I need info on this mower please February 24th 2013, 10:58 am | |
| I need info on this mower please. I really do not know who actually builds it to start with. The Data tag says 917.270810. It's a 19.5 L-head OP Briggs with a 42 inch cut. I've not torn aything down yet , but suspect the rear axles are the type with a round shaft with two flats on the side that fit into the wheel hub withan e-clip. What rear end does this have? Is there an easy way to install a sprocket onto the axle end for a chain drive? BTW, it's a craftsman.
| | | Chopperhed Moderator
| Subject: Re: I need info on this mower please February 24th 2013, 11:29 am | |
| Sears Parts Direct shows it as a Foote/Dana 4360-122 6 speed, from the parts diagram I found it looks like it has the flats on the axle, It only took a couple minutes to fing that. | |
| | | | Sponsored content
| Who is online? | In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
