 MURRAY WHAT DO I DO????
murray man 17
MURRAY  WHAT DO I DO???? Empty
PostSubject: MURRAY WHAT DO I DO????   MURRAY  WHAT DO I DO???? Icon_minitimeSeptember 18th 2012, 12:14 am
i Suspect have a murray it ran good and everything but one day the stock exaust fell off it was a circle type of exaust it fell of now it wont run what do i do?
Junkstarbuilds
Junkstarbuilds
PostSubject: More info needed..   MURRAY  WHAT DO I DO???? Icon_minitimeSeptember 18th 2012, 3:39 am
For a good diagnostic we would need some more information:
1. Will it still turn over? meaning does the flywheel turn?
2. If it does turn does it get compression? remove sparg plug and rotate the flywheel to quick check..
3. were you able to place the muffler back on?
4. Do your own ten point check, 1. spark 2. fuel flow 3. battery 4. solenoid 5. air flow/ choke 6. compression 7. shut off switches/ safety switches 8. remover the PCV breather and look at the rods. 9. make sure the power line isnt grounding itself anywhere. 10. confirm you have good gas
Do that and relay the results and I can help more...otherwise..Id be shooting in the dark on what could be wrong..
F150F250F350
F150F250F350
PostSubject: Re: MURRAY WHAT DO I DO????   MURRAY  WHAT DO I DO???? Icon_minitimeSeptember 18th 2012, 10:33 pm
I have never had a muffler fall off but I have had one burn through the wire that kils the engine before it to forever to figure it out that was back in my begining years I will never forget that.
» murray racers 35mph murray
» Murray Monster Mudder
» the murray
» The 84 murray
All-Terrain Lawn Tractor Forum :: General Tractor Talk + Pictures/ Videos :: Pics and Videos-
