| V-twin snorkel/ air filter. | |
theswampmachine Member
| Subject: V-twin snorkel/ air filter. February 10th 2013, 2:39 pm | |
| Has anyone ever made a snorkel on a twin cylinder briggs? It seems like it is going to be alot harder than just a one cylinder motor and I am trying to get ideas on how to do mine. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7776 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: V-twin snorkel/ air filter. February 10th 2013, 3:29 pm | |
| - theswampmachine wrote:
- Has anyone ever made a snorkel on a twin cylinder briggs? It seems like it is going to be alot harder than just a one cylinder motor and I am trying to get ideas on how to do mine.
Wouldnt be too hard since most twins run a single carb. You would have to make a flange, then a pipe going up. With my Vanguard it didint come with an air filter and the parts for my model are hard to find and expensinve. I just plan on mounting a cone filter onto it. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: V-twin snorkel/ air filter. February 10th 2013, 6:03 pm | |
| The problem I'm Having is if I just have like one PVC pipe coming up for the snorkel then I don't think I will have enough air flow I'm just not sure how to do it. I just used a rubber fitting on my single cylinder and that was easy to do. | |
Doug Site Owner
| Subject: Re: V-twin snorkel/ air filter. February 10th 2013, 6:29 pm | |
| If you are worried about air flow just make sure the inner diameter is the same size or bigger than the inner diameter on the inlet of the carb. 2-3" ID should be good enough.
Make sure you also have a way water cant get into the snorkel as well. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: V-twin snorkel/ air filter. February 10th 2013, 9:20 pm | |
| That's the issue I'm having I was just wondering if anyone had pictures of how they did it. | |
Murray modder Member
Join date : 2012-11-23 Points : 4795 Posts : 356 Location : Somewher in Va
| Subject: Re: V-twin snorkel/ air filter. February 10th 2013, 9:48 pm | |
| Might wanna get a T joint and an end cap, one way for an inlet, one to the card, the a small 1/2 section (longways) for a short water collector.
Doug Site Owner
| Subject: Re: V-twin snorkel/ air filter. February 10th 2013, 10:31 pm | |
- That's the issue I'm having I was just wondering if anyone had pictures of how they did it.
Could do like ARMY humvees and Toyota rally trucks did and have a "scoop" at the top with some mesh. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: V-twin snorkel/ air filter. February 10th 2013, 11:31 pm | |
| - Murray modder wrote:
- Might wanna get a T joint and an end cap, one way for an inlet, one to the card, the a small 1/2 section (longways) for a short water collector.
I am totally confused about what you just said. | |
| Subject: Re: V-twin snorkel/ air filter. March 9th 2013, 7:18 pm | |
| [img] [/img][img] [/img][img] [/img][img] [/img][img] [/img][img] [/img] this is how i ended up doing it. what do you think? | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5497 Posts : 1070
| Subject: Re: V-twin snorkel/ air filter. March 9th 2013, 8:04 pm | |
| I took some flat steel and drilled two holes in it and put the pipes through it and siliconed it to seal it up. I also took a piece off the original air filter to seal it between the steel and the black plastic inlet | |
