 Direct Steering, Caster, Camber + Toe Reference
Direct Steering, Caster, Camber + Toe Reference Empty
PostSubject: Direct Steering, Caster, Camber + Toe Reference   Direct Steering, Caster, Camber + Toe Reference Icon_minitimeFebruary 9th 2013, 8:34 pm
If you need additional help, please look at other threads in the Steering forum before posting a new thread.
Credit to Aaron Crowes (ARMA President) for the following.
Direct Steering, Caster, Camber + Toe Reference Scan0010
Direct Steering, Caster, Camber + Toe Reference Scan0011
Direct Steering, Caster, Camber + Toe Reference Scan0012
Direct Steering, Caster, Camber + Toe Reference Scan0013
Credit to dangeroustoys56 for the following:
Direct Steering, Caster, Camber + Toe Reference Direct10
Direct Steering, Caster, Camber + Toe Reference Direct11
Direct Steering, Caster, Camber + Toe Reference 005-110
Last edited by Doug Fackler on February 2nd 2014, 10:16 am; edited 1 time in total
cumminsbayou
cumminsbayou
PostSubject: Re: Direct Steering, Caster, Camber + Toe Reference   Direct Steering, Caster, Camber + Toe Reference Icon_minitimeFebruary 12th 2013, 10:43 pm
thanks
murrayracer
murrayracer
PostSubject: Re: Direct Steering, Caster, Camber + Toe Reference   Direct Steering, Caster, Camber + Toe Reference Icon_minitimeAugust 14th 2013, 2:40 pm
this is how i plan to setup my direct steer Direct Steering, Caster, Camber + Toe Reference Direct11
i wouldn't have to worry about stops or a tie rod
PostSubject: Re: Direct Steering, Caster, Camber + Toe Reference   Direct Steering, Caster, Camber + Toe Reference Icon_minitimeAugust 14th 2013, 4:25 pm
A bit redundant. There's no need for two drag links. As for a tie rod, you have 2 of them there, too!Direct Steering, Caster, Camber + Toe Reference Sample10
» 101 on Steering! Caster - Camber - Toe and KIP and what it does. (Old Video).
» Direct steering
» Tighten up Direct Steering?
» Direct Steering Tech
» Direct steering setup
