| 84 murray mudding project | |
+9THE MTD GUY alborn401 dangeroustoys56 Doug CornishMorgan truckin42 TheRainbowBoxer WellThatsSurprising Mark288 13 posters |
joshualee3d New Member
| Subject: Re: 84 murray mudding project March 8th 2013, 7:55 am | |
| [quote="Mark288"]Well i bought a welder last weekend...after a few practice welds i went to work. I welded the extended spindles on and put the big wheels on the front i also did a straight pipe out of 1" gas pipe. Heres a pic of it so far
Looks great! This might be a weird question but what welder did you get? I'm looking to get one this weekend so I can get some of this stuff done I'm just not sure what to get. | |
Mark288 Member
Age : 27 Join date : 2013-01-20 Points : 4405 Posts : 48 Location : Southern Wisconsin
| Subject: Welder March 8th 2013, 8:39 am | |
| [quote="joshualee3d"] - Mark288 wrote:
- Well i bought a welder last weekend...after a few practice welds i went to work. I welded the extended spindles on and put the big wheels on the front i also did a straight pipe out of 1" gas pipe. Heres a pic of it so far
Looks great! This might be a weird question but what welder did you get? I'm looking to get one this weekend so I can get some of this stuff done I'm just not sure what to get. I just bought a cheap welder from harbor freight. Its a 90 amp flux core welder made by chicago electric. I paid 100$ for the welder and got a 2 year warranty with it. Very easy to learn on it and you dont need gas with a flux core | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5509 Posts : 1070
| Subject: Re: 84 murray mudding project March 8th 2013, 9:07 am | |
| Yeah i bought the same welder about 2 months ago and it works great welds everything i need it to. | |
Join date : 2013-02-15 Points : 4336 Posts : 23 Location : centerville,IN
| Subject: Re: 84 murray mudding project March 8th 2013, 2:36 pm | |
| Awesome! That's the welder I was looking at getting. I just could'nt see paying $300-$400 on a Hobart or Lincoln if a $100 welder would do the same! Thanks for the info. Harbor freight is having there "parking lot" sale this weekend and they have that welder for $80! | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5260 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: 84 murray mudding project March 8th 2013, 3:31 pm | |
| I have one of those. I hope they've improved since I got mine. The one I have was the only 1 I could find on two pallets full that was actually functional.
To this day it still doesn't work right.
I'm planning a DC conversion and some wire feeder tweaks to get a steady feed and consistent weld from it. | |
Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 5019 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: 84 murray mudding project March 8th 2013, 8:58 pm | |
| I use the tried and true Lincoln AC/DC buzz box welder. Has never let me down and welds great. These suckers last forever. I've used an older Miller engine driven stick welder powered by an opposed twin Onan engine and it still worked great. | |
| Subject: Re: 84 murray mudding project March 8th 2013, 9:51 pm | |
| One of my best friends is a certified journeyman red seal welder with B pressure, Mig Tig, Sub arc and Stick rating.
He is qualified to weld anything in Canada, no matter the material.
When I met him he was running a wwII issue welder from a jeep mounted to a V twin briggs.
He built a business as an ironworker and has gone on to be a really good local welding shop.
He's the guy that welded up my bike.
You can never go wrong with good used tried and true equipment.
Even if it costs a few bucks to fix it. It is still good solid equipment.
Mark288 Member
Mark288 Member
| Subject: Re: 84 murray mudding project March 11th 2013, 8:24 am | |
| - truckin42 wrote:
- Looks like fun.
I like the front bumper. Yeah thanks im thinkin i need to swap my peerless for my locked foote soon. Got stuck alot! | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7788 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: 84 murray mudding project March 11th 2013, 8:30 am | |
| Be sure to support that stack before you twist if off.
I like how far that bumper comes out. Weld on an upper section and some expanded for a brush guard and you can mount halogen utility lights behind it. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Mark288 Member
| Subject: Re: 84 murray mudding project March 11th 2013, 9:06 am | |
| - Doug Fackler wrote:
- Be sure to support that stack before you twist if off.
I like how far that bumper comes out. Weld on an upper section and some expanded for a brush guard and you can mount halogen utility lights behind it. Once i go back to my moms house ill work on it | |
Mark288 Member
| Subject: Re: 84 murray mudding project May 17th 2013, 9:06 am | |
| Well its been a while but i did a bunch of things to it, pics in a bit but heres what i did 5" pulley on front 3" on rear 22x11x8 atv tires on back New 12hp power built engine Paint job Decals Taped up seat Locked transmission "Cab" lights on the hood lol | |
Mark288 Member
| Subject: Re: 84 murray mudding project May 17th 2013, 9:09 am | |
| Underneath this is a picture from 2 or 3 days ago nothing has changed. Those tires on the back are from a yamaha tri moto 3 wheeler. 22x11x8
Mark288 Member
MowBandit Member
Age : 28 Join date : 2013-03-15 Points : 4755 Posts : 477 Location : Haddock,Georgia
| Subject: Re: 84 murray mudding project May 22nd 2013, 8:11 am | |
| Looks good i like the rear tires. I also like the stickers that are on the head lights makes it look cool. | |
MowBandit Member
Mark288 Member
| Subject: Re: 84 murray mudding project May 22nd 2013, 2:53 pm | |
| - Jay_Rod wrote:
- what are all those wires for lol?
Head lights, and the cab lights on the hood. I hve stock wiring just safety junk is cut | |
Mark288 Member
| Subject: Re: 84 murray mudding project May 22nd 2013, 2:55 pm | |
| - truckin42 wrote:
- Looks good i like the rear tires.
I also like the stickers that are on the head lights makes it look cool. Thanks man by the way lol the black on the headlights is actually paint believe it or not lol. | |
MowBandit Member
| Subject: Re: 84 murray mudding project May 22nd 2013, 3:17 pm | |
| - Mark288 wrote:
I also like the stickers that are on the head lights makes it look cool. Thanks man by the way lol the black on the headlights is actually paint believe it or not lol. lol ow did you get it to stick to the glass and not run | |
Mark288 Member
| Subject: Re: 84 murray mudding project May 23rd 2013, 8:27 am | |
| - Jay_Rod wrote:
- Mark288 wrote:
I also like the stickers that are on the head lights makes it look cool. Thanks man by the way lol the black on the headlights is actually paint believe it or not lol. lol ow did you get it to stick to the glass and not run Well i taped the rest of the light off, and lightly sanded it and went with light coats of some 96cent cheap black spray paint | |
MowBandit Member
| Subject: Re: 84 murray mudding project May 23rd 2013, 1:44 pm | |
| - Mark288 wrote:
- Jay_Rod wrote:
- Mark288 wrote:
I also like the stickers that are on the head lights makes it look cool. Thanks man by the way lol the black on the headlights is actually paint believe it or not lol. lol ow did you get it to stick to the glass and not run Well i taped the rest of the light off, and lightly sanded it and went with light coats of some 96cent cheap black spray paint would of never thought you could sand glass i always thought it would crack or sumthing | |
Mark288 Member
| Subject: Re: 84 murray mudding project May 23rd 2013, 10:52 pm | |
| - Jay_Rod wrote:
- Mark288 wrote:
- Jay_Rod wrote:
- Mark288 wrote:
I also like the stickers that are on the head lights makes it look cool. Thanks man by the way lol the black on the headlights is actually paint believe it or not lol. lol ow did you get it to stick to the glass and not run Well i taped the rest of the light off, and lightly sanded it and went with light coats of some 96cent cheap black spray paint would of never thought you could sand glass i always thought it would crack or sumthing Well this thing is more like plastic than glass headlight lens, haha. I finished my clutch tonite and got a brandnew belt on it should do real good. Brakes are toast idk what to do cuz this tranny (peerless 800) is squealing real bad its wore way out, what would you guys get thats cheap too? | |
MowBandit Member
| Subject: Re: 84 murray mudding project May 24th 2013, 12:44 am | |
| - Mark288 wrote:
- Jay_Rod wrote:
- Mark288 wrote:
- Jay_Rod wrote:
- Mark288 wrote:
I also like the stickers that are on the head lights makes it look cool. Thanks man by the way lol the black on the headlights is actually paint believe it or not lol. lol ow did you get it to stick to the glass and not run Well i taped the rest of the light off, and lightly sanded it and went with light coats of some 96cent cheap black spray paint would of never thought you could sand glass i always thought it would crack or sumthing Well this thing is more like plastic than glass headlight lens, haha. I finished my clutch tonite and got a brandnew belt on it should do real good. Brakes are toast idk what to do cuz this tranny (peerless 800) is squealing real bad its wore way out, what would you guys get thats cheap too? how much are you willing to pay because you can get a peerless 820-037 it has 1" axles so you could get 1" hubs and get some bigger rear tires plus those transaxles are bullet proof or you could go cheaper and get a spicer 4360-149 for under $100 i recomend the 820 because it has bearings insted of bushings like your normal transaxles | |
Mark288 Member
| Subject: Re: 84 murray mudding project May 24th 2013, 12:28 pm | |
| - Jay_Rod wrote:
- Mark288 wrote:
- Jay_Rod wrote:
- Mark288 wrote:
- Jay_Rod wrote:
- Mark288 wrote:
I also like the stickers that are on the head lights makes it look cool. Thanks man by the way lol the black on the headlights is actually paint believe it or not lol. lol ow did you get it to stick to the glass and not run Well i taped the rest of the light off, and lightly sanded it and went with light coats of some 96cent cheap black spray paint would of never thought you could sand glass i always thought it would crack or sumthing Well this thing is more like plastic than glass headlight lens, haha. I finished my clutch tonite and got a brandnew belt on it should do real good. Brakes are toast idk what to do cuz this tranny (peerless 800) is squealing real bad its wore way out, what would you guys get thats cheap too? how much are you willing to pay because you can get a peerless 820-037 it has 1" axles so you could get 1" hubs and get some bigger rear tires plus those transaxles are bullet proof or you could go cheaper and get a spicer 4360-149 for under $100 i recomend the 820 because it has bearings insted of bushings like your normal transaxles Well i think i might save for the peerless820. Now with the 1" axles what kind of wheels do i use/where do i get them etc | |
