 84 murray mudding project
THE MTD GUY
alborn401
CornishMorgan
WellThatsSurprising
Mark288
13 posters
Go to page : 1, 2, 3  Next
Mark288
Mark288
84 murray mudding project Empty
PostSubject: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 3rd 2013, 10:16 pm
Just bought a 1984 murray with an 11 hp briggs and 36 inch cut. it sat for a while and mice built up a nest under the shroud and so i took that out and rebuilt the carb...she started right up. So we put a 4 and a half inch pulley on the front and 1 7/8 inch on the rear and in 3rd gear the rear pulley shredded right in half so i plan on doing it with a 9 inch on the front and 3 inch on the rear. Heres some pics from when i bought it...tell me what ya think i will get new pics after the cleanup tomorrow
84 murray mudding project IMG_1375_zps9efe9b2f
84 murray mudding project IMG_1376_zps4bc05229
84 murray mudding project IMG_1377_zpsb070310e
84 murray mudding project IMG_1378_zpsdcf52eed
84 murray mudding project IMG_1382_zps57b72403
84 murray mudding project IMG_1383_zps485c9eef
i plan on doing a front and rear bumper, red led lights under the headlights and a bullnose ring between the headlights and bullhorns on the hood to look mean on the front lol rendeer
Mark288
Mark288
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 9:34 am
Ok got some updates from last night. Got a 2 1/2" pulley welded to my transaxle, and i welded the front end. Ill get some pics tonite and im going to start sanding after i get home (posting from my fone)
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 9:51 am
You... Welded it to the transaxle? Eh, whatever works I guess. What was wrong with the key and nut?
Last edited by WellThatsSuprising on February 5th 2013, 9:56 am; edited 1 time in total
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 9:54 am
Have fun sanding if you are trying to take that paint off. We had one of those and sandpaper pretty much just polishes it. That is some super tough paint!
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Mark288
Mark288
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 10:02 am
Yeah i weld pulleys because i deal with them one time and your done, alot easier in the long run, ive had 2 pulleys shear on me with no weld
WellThatsSurprising
WellThatsSurprising
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 10:14 am
Oh, most of the transaxles I own you have to remove the pulley to take them apart so I would never do that. Plus I use titanium keys so I've never had one shear.
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 10:22 am
Nice project you got going.
I don't understand why you welded the pully but whatever work i guess.
You gonna lock the rear?
Mark288
Mark288
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 3:36 pm
Yeah im gonna lock it eventually, its a peerless 800 series so theres outside locks for it i heard.
CornishMorgan
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 3:59 pm
Nice tractor, you have the same ammeter and same engine as me Very Happy, apart from your engine looks in better condition than mine currently does.
Mark288
Mark288
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 6:26 pm
Does anyone know how i can fix my steering? Its super wobbly after 15 mph and i already welded the front end
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 5th 2013, 6:46 pm
If you intend on going over 15mph I would go with a direct steering setup. Theres no way to get rid of slop in a mower.
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 6th 2013, 10:16 am
I wouldn't go so far as to say there is NO way to remove slop from lawnmower steering. We have gotten ours pretty darn tight with simple mods and we are using stock craftsman steering box. I'm personally not a fan of direct steering for off-roading, as I think it is too sudden/twitchy, and gives serious feedback if you hit rocks and stuff.
Chaos Build
Haspin 2021 thread
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 7th 2013, 1:00 pm
Looks like my 80's agway - i had planned on off roading it but i went back to stock after i bot my GT murray ( way beefier).
Mine has a 3 speed peerless 600 under it - i had swapped pulleys to gain a lil more then 'geriatric ' speed, but switched it back - the pulley was a bit of a pain, mine has a half moon key holding the pulley on.
All my years of hot rodding around and going thru swamps - ive never broken a pulley key on either trans or motor, and i beat the crap out of them . I know on my agway if the pulley and half moon key wernt set right - it wouldnt mesh correctly.
About the steering, look for obvious worn pieces - in steering links, tie rod, front wheels and spindles - being that old im sure most of the steering is well worn.
alborn401
PostSubject: cool i got 18 hp twin bught carb rebuild and fired right up:-)    84 murray mudding project Icon_minitimeFebruary 8th 2013, 12:52 am
Cool
alborn401
PostSubject: cool i got 18 hp twin bught carb rebuild and fired right up:-)    84 murray mudding project Icon_minitimeFebruary 8th 2013, 12:55 am
Cool
I got old 18 hp twin need pulley swap junkstar builds sade 5 to 5 how bout 4 to 6
Mark288
Mark288
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 20th 2013, 9:38 am
Went rompin in the snow last weekend...with the 4.5 inch pulley in front and 2.5 in the back i got a top speed of around 35 mph. Getting a welder this weekend so i will be doing the extended spindles, atv rack, locked tranny, ram bars etc.
THE MTD GUY
THE MTD GUY
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeFebruary 21st 2013, 9:59 am
that sucker sounds reall fast! how many times have u rolled it?
Mark288
Mark288
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 6th 2013, 9:59 am
Well i bought a welder last weekend...after a few practice welds i went to work. I welded the extended spindles on and put the big wheels on the front i also did a straight pipe out of 1" gas pipe. Heres a pic of it so far
84 murray mudding project Image_zps2672bcf1
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 6th 2013, 10:21 am
Looks good.
Stack looks like it will hold up.
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 6th 2013, 10:28 am
You'll probably want some support on that stack though, if you tip it over, it might break the block.
Chaos Build
Haspin 2021 thread
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 6th 2013, 4:20 pm
This. Just get some thin round stock or a bolt and weld it onto the hood, and off the front of the stack weld a bolt. Then bend a loop in the round stock off the hood, hook it over the bolt and tighten it with a nut.
Mark288
Mark288
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 7th 2013, 9:37 am
Hey you guys if you got any ideas what else i should do then post em on here i need some ideas. Im gonna do front n rear ram bars tonite i think.
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 7th 2013, 9:45 am
Two words.... Gas. Pedal.
You got a pretty nice start there.
Chaos Build
Haspin 2021 thread
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 7th 2013, 12:51 pm
I would put a gas pedel on it.
Also mabe leg guardes.
joshualee3d
joshualee3d
PostSubject: Re: 84 murray mudding project   84 murray mudding project Icon_minitimeMarch 8th 2013, 8:55 am
[quote="Mark288"]Well i bought a welder last weekend...after a few practice welds i went to work. I welded the extended spindles on and put the big wheels on the front i also did a straight pipe out of 1" gas pipe. Heres a pic of it so far
Looks great! This might be a weird question but what welder did you get? I'm looking to get one this weekend so I can get some of this stuff done I'm just not sure what to get.
» Extreme Craftsman mudding project!!!!
» Offroad, all terrain, Mudding Murray atv mower."citrus"
» Project: M&M's "military Mud Mowing Murray"
» Murray/ Lawn Machine Project
» My Murray project AKA "The Night Train" (PICS!)
