| Home made pull start help! | |
+4thatrandomguy Chopperhed W1ldyOvvnZ 13mudman13 8 posters |
13mudman13 Member
Age : 26 Join date : 2012-09-20 Points : 4538 Posts : 67 Location : Wirt County, West BygodVirginia
| Subject: Home made pull start help! January 27th 2013, 10:38 pm | |
| Could some of u show met rough videos or pictures somehow to put a pull start on my tractor, it's an lt1000 12hp briggs | |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5248 Posts : 499 Location : Winchester, ON, Canada
Chopperhed Moderator
13mudman13 Member
| Subject: Re: Home made pull start help! January 28th 2013, 7:01 am | |
| Thanks for the pics, helped a lot! And it's a lip 12hp briggs shouldn't b too bad trying to start it | |
thatrandomguy Member
Age : 27 Join date : 2012-03-28 Points : 4690 Posts : 56 Location : netherlands
| Subject: Re: Home made pull start help! January 28th 2013, 9:29 am | |
| i pull start my 18 hp twin all the time. its has lots off compression. i broke a couple ropes pullstarting it | |
W1ldyOvvnZ Member
| Subject: Re: Home made pull start help! January 28th 2013, 11:54 am | |
| when you think of it, they have 800cc snowmobile motors you pull start, but they are 2 strokes so your not opening the valves, etc. | |
| Subject: Re: Home made pull start help! January 28th 2013, 6:42 pm | |
| The 11HP briggs on my agway has a recoil pull start - the 11HP on my junked snapper RER also had one - i dont see why it couldnt be adapted to a 12HP when its virtually the same motor.
The agway pulls a lil tough, but easier then hooking a battery up. | |
13mudman13 Member
W1ldyOvvnZ Member
| Subject: Re: Home made pull start help! January 28th 2013, 10:47 pm | |
| - 13mudman13 wrote:
- How could I put a pulley on there?
What do you mean by a pulley lke the pctures i posted? im pretty sure you can buy them or i just thought of this(it would be more of a back-up idea). i think someone posted it but i didn't understand it right away, like the same idea of the pictures i posted but use the mower deck drive pulley to rap the pull cord up on. | |
tractorboy567 Member
Age : 26 Join date : 2013-01-02 Points : 4454 Posts : 121 Location : PA
| Subject: Re: Home made pull start help! January 29th 2013, 10:37 am | |
| - W1ldyOvvnZ wrote:
What do you mean by a pulley lke the pctures i posted? im pretty sure you can buy them or i just thought of this(it would be more of a back-up idea). i think someone posted it but i didn't understand it right away, like the same idea of the pictures i posted but use the mower deck drive pulley to rap the pull cord up on. If you are really adventureous you can weld to it but thats last resort. what happened to electric start? | |
13mudman13 Member
W1ldyOvvnZ Member
| Subject: Re: Home made pull start help! January 29th 2013, 10:29 pm | |
| for me why i like pull start is because i jump start all my lawn tractors(they all have dead batteries) and when they run out of gas or stall out from being on to much of an angle i cant start them again. i could get batteries or a booster pack, but it would cost about $500 for new batteries, or $100 for the booster pack(which i should get but i dont want to buy it until i get my Toro done) | |
| Subject: Re: Home made pull start help! January 29th 2013, 11:10 pm | |
| If you must go with the manual elbow. Use a larger diameter pulley. A larger pulley means an easier pull, but you need a longer reach. | |
| Subject: Re: Home made pull start help! February 2nd 2013, 6:51 am | |
| Yeah batteries arent cheep - im planning on getting a couple large CCA batteries here soon, tired of my old ones needing to be boosted all the time. Suppose i cant really complain tho.
Doesnt make sense to buy batteries for all my tractors when i can only drive em one at a time. | |
Doug Site Owner
| Subject: Re: Home made pull start help! February 2nd 2013, 4:15 pm | |
| Ive seen people wrap clothesline string around their flywheel blower fins and so it that way. Youll have to remove your blower housing to do it though, and it might damage the fins if they are plastic and not die cast. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
CornishMorgan Member
| Subject: Re: Home made pull start help! February 2nd 2013, 5:31 pm | |
| I would be careful starting it from the fins, although most flywheel fins are cast iron, they are weak. | |
Doug Site Owner
| Subject: Re: Home made pull start help! February 2nd 2013, 5:44 pm | |
| - CornishMorgan wrote:
- I would be careful starting it from the fins, although most flywheel fins are cast iron, they are weak.
Pull starting off from it shouldnt damage it though, unless youre pulling it with a truck. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Home made pull start help! February 2nd 2013, 8:05 pm | |
Pull starting off from it shouldnt damage it though, unless youre pulling it with a truck. Even a slight bend throws the balance off. best to use the proper hub bolted to the flywheel. Or just spring for the starter | |
13mudman13 Member
Doug Site Owner
| Subject: Re: Home made pull start help! February 2nd 2013, 8:56 pm | |
| - 13mudman13 wrote:
- Hey chopperhead it's the starter
Might just need new brushes. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Home made pull start help! February 2nd 2013, 9:27 pm | |
| - 13mudman13 wrote:
- Hey chopperhed it's the starter
So how much is a starter worth down there.? I've been known to buy a tractor for a starter and a few parts. I've always done well doing it. I didn't pay much, but hey, it was parts and i got money out of it on the back end. | |
13mudman13 Member
Doug Site Owner
| Subject: Re: Home made pull start help! February 3rd 2013, 12:56 am | |
| Look around on eBay, you might be able to find something cheap or a replacement part. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Home made pull start help! February 3rd 2013, 7:53 am | |
| I got the cap for mine from a Briggs Dealership for £23, a bit pricey but ebay wanted £20 plus £5 shipping so I just got mine from Briggs | |
