| what pulley sizes? | |
tractorboy567 Member
Age : 26 Join date : 2013-01-02 Points : 4452 Posts : 121 Location : PA
| Subject: what pulley sizes? January 21st 2013, 7:27 pm | |
| i plan on taking my tractor off-roading, road riding, hillclimbing, mudding, and something i can just have fun on. I have a couple questions on it. 1.) What is a good speed for it? 2.) What sizes of pulleys should i use for that speed? 3.) For that speed are there any further mods that i can do to help the thing hold together longer or make it safer? | |
| | | Tuffy55 Member
Join date : 2013-01-07 Points : 4364 Posts : 31 Location : MI
| Subject: Re: what pulley sizes? January 21st 2013, 8:25 pm | |
| To make my trans axle hold up for longer i put grease nipples in a few places in between the input needle bearings and on the top of the trans axle so i can add grease more frequently, easier. Also make sure all the bolts are tightened evenly all the way around the trans axle to keep the case from cracking. I have like a 4 inch front pulley and a 5 inch rear or something close to that and it goes about 15 miles per hour. | |
| | | Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4607 Posts : 145 Location : MS
| Subject: Re: what pulley sizes? January 21st 2013, 9:51 pm | |
| A 1 to 1 pulley ratio is pretty popular just guesing you would git about 15mph. You may want to upgrade the brakes and steering . And X2 on the grease fittings for the trans its alot better to just pump in some grease with a grease gun then take it apart to lube it , I would recomend a rubber cap on the fitting to keep water out . | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7777 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: what pulley sizes? January 22nd 2013, 2:00 am | |
| Reinforce the body first off. 1x1 square tube steel will do it.
Clean up your steering so you have less or no slop at all.
A 1:1 ratio is really what you want if you plan on offroading. Unfortunately you cant have both road speed and offroad traction with a belt setup. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
