 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start
AcreFarm
MurrayMayhem
6 posters
MurrayMayhem
MurrayMayhem
12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Empty
PostSubject: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 13th 2013, 6:54 pm
Its a 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start. ive tried doing everything using the choke and starting fluid, but it won't idle by itself, i have no idea why please help.
AcreFarm
AcreFarm
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 13th 2013, 7:13 pm
Spark, Compression & fuel. That's what your engine needs to run.
You say it won't idle by itself... does that mean it will run on starting fluid? If so you've likely got a fuel issue.
If the fuel itself is good it's probably time to clean the carb
Chopperhed
Chopperhed
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 13th 2013, 7:18 pm
what he said.
gearheadmike
gearheadmike
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 13th 2013, 7:53 pm
is it getting fuel? Does it have good spark? It could be a dirty carb
Marines2621
Marines2621
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 18th 2013, 3:24 pm
Safety switches in the mower? are they bad. killswitch not bad and grounding the motor off? Just some ideas.
Marines2621
Marines2621
Killswitch wire*
Chopperhed
Chopperhed
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 18th 2013, 3:38 pm
If it runs on starter fluid, but not without it, then the carb is dirty/plugged, or it may be bad gas
Marines2621
Marines2621
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 19th 2013, 12:17 am
Didn't see that clearly
tractorboy567
tractorboy567
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeJanuary 23rd 2013, 10:27 am
see if air is coming out of the carb. i just had the same problem.
MurrayMayhem
MurrayMayhem
PostSubject: Re: 12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start   12.5 hp briggs and stratton flathead and i turn the key over and the motor spins but doesn't want to start Icon_minitimeFebruary 19th 2014, 8:58 pm
I don't even remember posting this, but I found out that the spark plug had stuff on it. I put it in the wire wheel, slapped it back in, and the motor fired on gas, smoked for a couple seconds, but it started and ran fine, still does to this day.
» 15.5 hp turbo cooled craftsman briggs and stratton wont start
» what is the best briggs and stratton motor for offroading?
» briggs 20hp no start/hard start
» Briggs and Stratton 11hp Syncro-Balanced (flathead) - Pullstart?
» DIY Briggs and Stratton Recoiling Pulling Start
