 Drive train Concept
CornishMorgan
Junkstarbuilds
7 posters
Junkstarbuilds
Junkstarbuilds
Drive train Concept Empty
PostSubject: Drive train Concept   Drive train Concept Icon_minitimeOctober 28th 2012, 5:43 pm
I was driving into work today, and I am always thinking of ways to make the 4x4 on a mower, but doing it the most convient way possible and easiest..
but, I began thinking about this and it got in my head, so, please take a look and let me know your thoughts!
here is the link to a photo I posted. should be self explanitory, but, If not,
The idea is to add a centrifical clutch to a horizontal engine, and run a pulley underneath direct into a rotated transaxle. then adding a shaft brake!
let me know what you think..
Concept sketch
CornishMorgan
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeOctober 28th 2012, 6:12 pm
Nice concept, i like it Very Happy
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeOctober 29th 2012, 10:44 am
Cool idea! I wonder about the possible issues with lubrication on the transaxle in that position, but I guess if you are using grease it would probably be fine.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Chopperhed
Chopperhed
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeNovember 21st 2012, 2:00 pm
Actually had an idea similar to this the other day while working out the driveline concept for my dozer project
Theoretically, you could rotate the transaxle 90 degrees to give it a horizontal input shaft, slap a belt or chain on it and drive to a horizontal engine above it or off to the side. Or as JSB mentiond running a drive shaft from in front or behind. Or a flex coupler directly off the engine into the transaxle
A grease filled trans should still get adequate lubrication. and oil filled unit should still lube but oil changes would be a pain,
If you had a reasonable small pulley/sprocket on it there wouldn't even be a ground clearance issue.
dagr8tim
dagr8tim
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeDecember 17th 2012, 10:16 am
I was thinking something similar, but not rotating the transaxle 90 degrees. Instead turn it 90 degrees so that you could still run a vertical shaft motor with it. Then use some old steering shafts as drive shafts. I know the steering shaft from my 98 Cherokee had some nice U joints built in. Then just figure out your axle's to run off a gear on the end of the steering shaft.
There's an outfit that builds little buggy's around a Honda FWD drive train, but they turn it sideways so that one of the CV's drives the rear wheels and the other drives the front wheels.
http://buckeyejeeps.com
Junkstarbuilds
Junkstarbuilds
PostSubject: haha! similar ideas   Drive train Concept Icon_minitimeDecember 17th 2012, 10:43 am
I had a sketch of what you are talking about..I think it might be posted to on my FB, but I figured, take a Hydrostatic transaxle and center it, turned where the axles are front and rear, then attach another transaxle FNR to the rear rotated 90% and have shafts connect directly to the input drive.. then a FNR for the front with shortened axles to work around steering..
Oh well, Its a big project, I wouldnt get into anytime soon on my part..
dagr8tim
dagr8tim
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeDecember 17th 2012, 11:04 am
I just got a new partial tractor with these old school heavy gears that are cut at a 45 degree for the steering. I think two of those on a straight shaft for an axle would be great. The only real issue would be you would have to do a small universal at the end of the front axle so that the wheels could still turn. Personally I would use a transaxle that was manual and not hydro so that you could still shift gears. I would also stay away from locking the transaxle.
As it stands with this design, both front would be locked and both rears would be locked. If you left the transaxle open, it would allow the axle's to spin at slightly different speeds so nothing would bind and grenade.
Really for this project, other than a donor, you'd need some HD steering gears (my dynamark has some nice ones), and probably some steering shafts from something with good U joints. If you wanted to get crazy, you could easily use this setup to add some suspension to the front and the rear tires.
Junkstarbuilds
Junkstarbuilds
PostSubject: the reason fo rthe Hydro   Drive train Concept Icon_minitimeDecember 17th 2012, 11:13 am
The reason for the Hydro is to reduce the need for multiple clutches. since the hydro can be directly belt driven, doesnt need one..
There are so many ways to "skin a cat"
I would like to see some frankenstein built projects! but, If if you were to do it right then there are plenty of products to just use..
dagr8tim
dagr8tim
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeDecember 17th 2012, 11:20 am
I just got a new "project" yesterday. I may try to flesh out some of these ideas.
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeDecember 19th 2012, 12:20 am
Easiest way to convert to a 4x4 is to use a noma 4 wheel steer trans up front - im fiddling with the notion of hand fabbing a steering setup for a standard trans for a future upgrade on my GT murray. It wont have any suspension.
On my old GT5000 i wanted to use a horizontal shaft motor and a 3 hi/low trans up front - just have to remount the motor sideways in order to run the drive setups - both transmissions would have side input setups.
Ive seen a differential type go kart axle used up front with heavy duty ujoints and chain drive but can break easily.
Only way i could see making a independent 4x4 setup up front is using either atv stuff or hubs and CV joints/axles off a small car .
Wvburban
Wvburban
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeJanuary 27th 2013, 9:55 am
Soo your pretty much doing a bolens drive terrain. .
dagr8tim
dagr8tim
PostSubject: Re: Drive train Concept   Drive train Concept Icon_minitimeJanuary 27th 2013, 11:41 am
I've often thought of getting a steering shaft (part that runs from the steering box to the steering wheel) from say a Jeep or truck that has some U joints and using that to fab up some axle shafts that would flex. 4 Wheel stear sounds like a similar setup.
Drive train Concept
» rear end drive train help!!!
» Drive train ideas for community
» Troy Bilt with Pedal Drive/Vari Drive Setup (Best Way to Speed Up?)
» 100$ Dation 16HP MTD 990 "Mud Train"
